I have an Electrolux stackable washer and dryer. Model: MEX 731CAS3 It is in a tight place but I would like to pull it out and "unstack" it for removal and sale. Does anyone know if indeed, the dryer and washer can be separated and if so, how? I would like to know if I can finish the job on my own before starting. Thank you. Ian
    President:
  • 670 Answers
Typically stacked washers and dry are attached with a bracket in the back of the machine. Pull your machine out and you should see the brackets. Undo the screws and the dryer should lift off the washer.
Posted on Aug 23, 2010
How to use stackable washer and dryer if unstacked
stacking was just a gimmick to save space
put the drier on a suitable stand , table or it is possible that there are holes in the back section for a mounting bracket to hang it on a wall
Sep 30, 2016 | Washing Machines
Need washer timer knobs for mex 731 cas3
did you find any? can you help me find a site that can help the same prob?
Jun 06, 2010 | Electrolux EW1200i Front Load Washer /...
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer agitator
Remove the agitator cap and the bolt in the middle that holds the agitator. Reach underneath the sides of the agitator and pull up. Try gently rocking it around as you pull, I'm sure it's going to be stuck pretty tight.
Mar 12, 2009 | Kenmore Washing Machines
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Frigidaire stackable washer-dryer
I would check the manual.
Mar 22, 2008 | Washing Machines
How to unstack a dryer
I have a Kenmore 417.69042990 stackable dryer and had a similar problem. To unstack it, in the front of the dryer there are two screws that are covered by round caps. They are easy to miss unless you look for them. Remove the caps, and the screws underneath it. Now, voila, you can lift the front of the dryer and pull as to unlock it from the two brackets in the rear of the dryer. Hope this helps... I took me and my husband over an hour to figure this out...
Nov 11, 2007 | Dryers
HOW TO UNSTACK A WASHER AND DRYER
Chainsaw, no seriously the dryer is bolted to the washer and not all of them can be unstacked. Remove the front panel of the dryer to expose the bolts holding it down. this only works if your washer is of the front loading type. if it is a top loader there should be some sort of frame the dryer is bolted to. after removing the dryer from a front load stack washer, the washer may or may not have a top panel on it
Sep 02, 2007 | Dryers
Washing Machines Logo
217 people viewed this question
Top Washing Machines Experts
