Question about Acer eMachines 520-2890 Notebook
How long should the battery stay charged when the lap top is not plugged in.
Where do i buy a battery for my lap top
I suggest you Google the Internet for a replacement battery for your model laptop. You will get various suppliers and prices.
Mar 05, 2013 | HP Computers & Internet
Lap top will not charge battery
Sounds like the charging circuit on your motherboard is defective. Also check the AC adaptror by switching it with other Vostro.
Jan 30, 2012 | Dell Vostro 1014 Laptop Computer (Intel...
Hp pavilion Dv 7 won't power on even when the lap top is charged.
Pull the battery and plug it in to the wall (in other words rule out the battery). If it still refuses to come on, check out this troubleshooting link:
http://www.techspot.com/vb/topic55208.html
Jan 15, 2012 | HP Pavilion dv7-1130us laptop
Dell 620 lap top does not stay on. when i turn on then it stay for second then turn off itself
theres a start up driver missing you will need your back up disc on this one.or theres a problem with your battery it not takeing charge.
Mar 30, 2011 | Dell Latitude D620 Notebook
My acer laptop will not charge, if the ic port connector is moved then sporadically the lap top will charge. But then dies soon after
start the machine up with the power cord in it, and after it starts remove the battery, the pc should stay on, and be usable. if not then the port is bad. if it does, then its the battery that will not charge.
Jan 06, 2011 | Computers & Internet
Lap top not charging . purple light is not on. is it battery or charger?
the charger lasts longer than the battery .you need another lap top battery
Oct 16, 2009 | Computers & Internet
Battery charger fine but lap top shows not charging
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 10, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Battery not charging.when it is connected its work on pc but not charging
Let me get this straight. The lap top works when the power adapter is plugged into it but the battery will not charge. If that is the case you would probably need a new battery.
Dec 09, 2008 | Computers & Internet
Charging lap top battery
The battery will charge automatically when the ac adapter is plugged in.
May 28, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
Acer eMachines 520-2890 Notebook Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
