Lenovo 3000 N500 Notebook Logo
Posted on Aug 23, 2010
I have lenovo n500 and the touch pad is not responding
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Aug 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
15
Questions
0
Helped
788
Points
28
Below is a link that should be helpful in restoring the use of your touch pad:
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-71738
Thanks.
My touch pad for Lenovo N500 just stopped working; the mouse pointer is stuck. I have to use and external mouse. Please how do i have my touch pad working again
It most likely has something conductive around the edges. Clean the pad with a cloth or paper towel that has 99% isopropyl alcohol on it. Use something like a toothpick to push the cloth or paper right into the edges. Once it is clean, and completely dry, try again. If it still doesn't work you may need to check the connection inside the laptop.
~KenjiFox
The trackpad on my Lenovo n500 has somehow locked. How to get it working again?
HI there press FN key as well as F7/F8/F9 key. One of the F key mark by touch pad. Just press that by pressing FN key. Thanks.
My Lenovo mouse touch pad stack. and i didn't use it what r the posible soulutions
I do. Open the Lenovo 3000 N500 Notebook PC, and un-stick it.
You need the Service Manual.
Lenovo calls it an HMM.
Hardware Maintenance Manual
Below is the Lenovo Support link for the download page, for the Lenovo 3000 N500's Hardware Maintenance Manual. The Top file listed is the one you want.
Either the site is updating right now, or Lenovo no longer offers this manual. Clicking on the file does no good.
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/site.workflow:SimpleSiteSearch?q=lenovo+3000+n500+hmm&cc=us&lang=en
No big deal.
Copy this link, paste it into your address bar, and press the Enter key.
It's a direct link to the HMM file.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles_pdf/45n3577_01.pdf
Regards,
joecoolvette
How do i turn off the touch pad while typing
Hi!
- you can do this thru the Mouse properties
- go to control panel, look for & click the mouse icon
- on Mouse properties, got o the TAP Tab
- near the bottom area, Under Tapping, put a check on "TAP OFF while typing"
Hopr this helps.. :D
I have a Lenovo N500 and the mouse pad surface has worn through after only a years work on this machine - I have managed to polish the surface off with use - does anyone know if you can replace this as its...
Hi richardta683 , since you are using N500 you can call their 24/7 tech support at 1-800-426-7378. They will certainly help you on your concern.
Hope this helps...
1helpful
3answers
Lenovo n500 laptop ... mouse pad not working
The mouse pad maybe faulty or the ribbon cable from the mouse pad to the motherboard may not be properly connected. Reseat this cable.
You can connect an USB optical mouse to the laptop. I prefer you use a USB mouse all the time over the mouse pad.
23helpful
My Lenovo 3000 N500 PC notebook touch pad is dead. What should I do to open it?
I had the same problem. There is a touchpad on the laptop, just above the Pause button, which turns the pad on and off. It is situated on the far right hand side (there are also touch buttons for the volume controls there), between the N500 logo and where the power supply jack fits in.
Mouse is not responding at all
you need to go to device manager...
right click "my Computer"
select "manage"
select "device manager"
click the + sign for "mice and other pointing devices"
select your touch pad...
try to enable it or find what is wrong from there
You'll need a USB mouse or something of that ilk to do it.
good luck
49helpful
3answers
Turning off the mouse pad on Lenovo 300 n500
You have a button just to do that simle task, its un the upper right side and it has a touchpad on it, press it, looks like a display but its a button :)
One image worth 1000 words:
http://www-307.ibm.com/pc/support/site.wss/71738_touchpad.gif
Complete guide found in LENOVO support:
Lenovo Y510 keyboard not responding
first try to search a new material with configuration panel ,if you don't find anything replace it at your resseller
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
