Question about Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer: red error light blinks (3 sec on, blink, 3 sec on, etc) and no print. Green power light is on.
  • 10 Answers
SOURCE: My Printer EPSON TM-U220 does not print....HELP!!!!!
if you are using lpt1 we expect that your printer is using a parallel cable. make sure that your printer is indeed using parallel cable and then check if there's a communication in between the 2 devices. to find out open your command promt then type in, dir>lpt1, your printer should print with or without a printer driver. if it will print, then possible issue is port configuration.. just make sure from the printer properties that you are using lpt. you can use esdprt lpt1 with bi-dir or lpt printer port without bi-dir support. you should be good to go from there. otherwise you may uninstall and reiinstall your printer driver..
Hope you can now use your printer..=)
Posted on Feb 23, 2008
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
acdr
  • 1913 Answers
SOURCE: i m unable to install the epson tm-u220 printer in windows 2003
http://www.barcodesinc.com/epson/tm-u220-drivers.htm
download driver and install from here
Posted on Jan 24, 2009
SOURCE: Epson printer TM U220 (User Intervention Required)
I spent a good week trying to find an answer to this problem... and finally I HAVE THE SOLUTION!!
it's to do with the Port settings.
go to BIOS and change the port settings on your computer.
there are a number of different options that can be selected, just try them one by one, the one that worked for me was "Normal" try that one first, but it may be differnet depending on the printer.
if your LPT port is using it's own driver (not using BIOS to run) you cant change the settings using the BIOS. see if you can change it useing the settings for the dirver. if not try updating the driver. if that doesn't work, and nothing else works, reinstall Windows, that should fix the problem as a last resort.
good luck.
Posted on Jul 23, 2009
c-hom
  • 150 Answers
SOURCE: Epson TM-U220 Receipt Printer M188D Drivers
The driver for Epson printer has been
Warm regards,
Anirban Mazumdar
Posted on Oct 08, 2009
Epson TM-U220 hard reset
When a USB interface change interface idn flashing error red light
May 23, 2012 | Epson TM-U220 Matrix Label Printer
The power light is blinking and not printing anything
Here's the manual. There could be a possible fix for your problem. Perhaps factory reset instructions.
CLICK HERE!
Hope that helps, give me thumbs up please!
Aug 23, 2010 | Epson TM-U220 Matrix Printer
Epson TM-U220 not working with window 7
download this driver APD-406aE i did it and it is working perfect with my windows 7 on a TM-U 220B
Jul 07, 2010 | Epson TM-U220 Matrix Printer
RE: Epson TM-U200 printer with error (2 Flashes)
programmer can be used. example Makefile is included for LED flashing sample project in ..... but gives no such newsgroup error after specify the title. ...... Uses two-wire serial data communication through printer port. ...... The simple emitter-follower does not have a gain of exactly one,
May 27, 2009 | Epson TM-U220 Matrix Printer
http://www.icscale.com/TECH%20MANUALS/TMU220_TRG_RevD.pdf
Oct 27, 2008 | Epson TM-U220 Matrix Printer
Epsom TM-U220 Error Codes
From the manual its probably one of this item.
-printer temp is too high
-cover is not properly closed
-print head is not in the correct position
-paper cutter is not in the correct position
-paper jam
Try turning off the printer, remove the power cable, turn it on again for 5 seconds to reset it. Connect back power cable, press the feed button and turn it back on. The printer should do a self test, turn it off and on again after the self test. It should make the red light go away.
Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
TM-U220 printer is not printing anything.
do a self-test first. Perform by holding down the feed button then powering on the printer. if it prints then it is not a printer issue, but a driver or cable issue.
May 09, 2008 | Epson TM-U220 Matrix Printer
Epson u220b printer
service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
Apr 08, 2008 | Epson TM-U220 Matrix Printer
Epson tm u220
What type of interface card are you using to connect printer to your computer?
Mar 14, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
761 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
