Question about Minolta magicolor 3100 Laser Printer
Imaging Unit Missing Error
Received error message "Imaging Unit Missing" after replacing fuser and transfer unit. The fuser and transfer unit were replaced after low life/end of life message. Printer was working fine up to replacing these items. Immedeatly on pwr up received Imaging Unit missing, contacts were cleaned, unit reseated but no change. Could use any advise/suggestions.
Thks
spmcd
  • 1 more comment
  • msorrentino Sep 04, 2008
    Thanks
    mike
  • jeffvojtko Jan 17, 2009
    I had the same problem. I have the Magicolor 3300 and I had gotten a
    thin test piece of paper stuck in the imaging unit. I took out the
    imaging unit and pulled the paper out. Unfortunately, one side of the
    handle popped out and 1/2 of the unit fell and bumped against the left
    side of the pinter. I found this post and found the document (Available
    herehttp://www.jeffvojtko.com/images/mc3300s... followed the
    directions and voila. Fixed.
  • eme jota ce Apr 08, 2009
    Same problem. Magicolor 3300DN displayed a message that we need to order a new imaging unit. Ordered it. Followed installation instructions from manual very carefully, but received the "Imaging Unit Missing" error. Tried replacing the new unit with the old. No luck. This printer has been very costly in toner, imaging units, fuser units, etc.
Hi, I had the same problem. The following Cause and solution may help you fix your machine.
All refereces to left and right are facing the front of the machine as if for normal use.
The cause is due to the connector on thtop left rear of the imaging unit. this connector is mated with a coresponding, retractable connector in the body of the machine. When you open the cover over the top of the imaging unit, this connector retracts back into the body of the machine and when you close the lid it should re-engage with the imaging unit, The problem is that it dosen;t reconnect. I have asumed that it is due wear in the connector operating mechanism. This solution was effective for my printer.
Switch Off!!!
remove the topcover (after removing the colour catridges )and. remove the left hand side panel. You will see a nylon gear mechanism. Sqeeze together the nylon clip inthe centre of the gear wheel, and pull the gear about halfway off. This should allow you to move the vertical geared bar up 1 notch. .Push the gear wheel back on and try the machine to see if it works ok. All covers will need to be closed and if it works ok , reassemle the machine. Job done -about 10 to 15 mins. It tookme alot longer to find it,so some feedback would be appreciated.
Paul
Posted on Sep 15, 2008
Hi.
I had similar problem after removing a paper jam on MagiColor 3300 : "Imaging unit missing". The connector (top left rear of Imaging Unit) was not connected right into the machine. Removing left cover panel was a bit tricky, I believe I didn't use the right way, but get it. Moving the nylon gearwheel left&rigt untill the connector are pluged in has been enough.
Many thanks
Jean-Baptiste
Posted on Oct 21, 2008
How do I reset ms610 imaging unit?
When you get the error message "Replace imaging unit, 0 estimated pgs remain [84.3x]" This means the imaging unit has reached end of life and needs to be replaced. The device will not print, and this message will not be cleared, unless you replace it with part number 50F0Z00
(or 500z)
Vertical streaking. If the imaging unit is near end of life, or the device has had problems with non standard toner, vertical streaks may occur on the page. Replacing the imaging unit will resolve the problem.
Vertical streaks on page
Vertical band at top of page. This typically appears on printed images, but can also appear on text. The most likely cause is toner contamination on the charge roll, however if the band is still visible after printing 30-40 continuous pages this means the imaging unit needs to be replaced.
Vertical Banding on images
Seal failure on the imaging unit. Occasionally seal leaks have been seen from the Imaging Unit.
Toner will be seen on the main frame near the Imaging Unit sides.
If toner build up is excessive, it may even fall into the Tray below. Cleanup with a toner vacuum may be needed.
Replace the Imaging Unit to fix the problem.
Spots, scratches, marks on the page. If they are random, this indicates a problem with toner scatter.If they are repeating patterns, measure the distance between matching marks or spots. If the distance is one of 97mm, 47mm or 38mm, this indicates marks or dents on the imaging unit and it will need to be replaced.
You receive the message Replace defective imaging unit The imaging unit is defective and needs to be replaced. If you just installed it, it will be covered under warranty - contact Lexmark Australia on 1300 362 192
You receive the message Reinstall missing or unresponsive imaging unit and the below instructions don't resolve the problem. Try one or more of the following:
  • Check if the imaging unit is missing. If missing, install the imaging unit.For information on installing the imaging unit, see the "Replacing supplies" section of your device's User's Guide
  • If the imaging unit is installed, then remove the unresponsive imaging unit, and then reinstall it.
  • Note: If the message appears after reinstalling the supply, then the imaging unit is defective. Replace the imaging unit.
You receive the message Replace unsupported imaging unit The imaging unit you attempted to install was either non-genuine, or was from a different region. Buy a genuine Lexmark imaging unit from an authorised Lexmark supplier in your country/region.
You receive a 31.6x error One of the following errors is shown on the display:
31.60 Imaging unit smart chip error
31.61 Imaging unit I2C packet timeout
31.62 Imaging unit I2C packet has been sent but code timed-out on receiving the data (callback)
31.63 Imaging unit security error in the send challenge sequence
31.64 Imaging unit ROM signature error
31.65 Imaging unit stuck busy (status register and/or CRI Arbiter register report busy)
31.66 Toner failed to replenish into the imaging unit
In this case you need to ensure that the imaging unit is properly installed. If yes, check if the imaging unit is supported. Replace with a supported imaging unit if necessary.
If the problem remains, you will need to organise a Lexmark service call (Australia 1300 362 192)
You receive error message 32.11 Imaging unit smart chip compatibility error This could be caused by an unsupported imaging unit (non-genuine or incorrect region). Replace with correct imaging unit to clear this error. If your imaging unit is supported, you will need to organise a Lexmark service call (Australia 1300 362 192).
You receive error message 84 Imaging unit low If expected, replace the imaging unit. If unexpected, call Lexmark Support (Australia 1300 362 192)
Jan 23, 2017 | Office Equipment & Supplies
Error code e1 showing at xerox pro 420? solution..
rror codes If the printer's front panel displays a message Error XX, find the error code in this table and follow the instructions for resolving the problem. If problems persist, check the Xerox web site www2.tek.com/TekSMART/ or contact service.
Error User Corrective Action Error 01
  • Remove and re-install the black Toner Cartridge, then turn the printer off and on.
  • Replace the black Toner Cartridge, then turn the printer off and on.
Error 02
  • Remove and re-install the cyan Toner Cartridge, then turn the printer off and on.
  • Replace the cyan Toner Cartridge, then turn the printer off and on.
Error 03
  • Remove and re-install the magenta Toner Cartridge, then turn the printer off and on.
  • Replace the magenta Toner Cartridge, then turn the printer off and on.
Error 04
  • Remove and re-install the yellow Toner Cartridge, then turn the printer off and on.
  • Replace the yellow Toner Cartridge, then turn the printer off and on.
Error 05, 10, 11,12, and 13
  • Turn the printer power off, then on.
Error 20
  • Remove and re-install the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Remove and re-install the Main Charge Grid. Turn the printer off, then on.
  • Remove and re-install the Transfer Kit. Turn the printer off, then on.
  • Remove and re-install each of the Toner Cartridges. Turn the printer off, then on.
  • Replace the Main Charge Grid. Turn the printer off, then on.
  • Replace the Imaging Unit (make sure that Imaging Unit is locked in place). Turn the printer off, then on.
  • Replace the Transfer Kit. Turn the printer off, then on.
  • Replace the Toner Cartridges. Turn the printer off, then on.
Error 21, 22, 30,and 32
  • If a problem persists for Error 30, clean the sensor. See Cleaning Phaser 750 Printers.
Error 33
  • Check for jammed paper throughout the paper path (especially in paper feeder).
  • Remove and re-install the paper feeder and Transfer Kit. Turn the printer off, then on.
Error 40, 41, 42,and 43
  • Check for jammed paper in the Fuser. Re-install the Fuser. Turn the printer off, then on.
  • Make sure that you have the correct Fuser for your local printer power supply:
    110-Volt Fuser Part Number 016-1839-00
    220-Volt Fuser Part Number 016-1840-00
  • Replace the Fuser. Turn the printer off, then on.
Error 50, 51
  • Turn the printer off, then on.
Error 52
  • Remove the Duplex Unit (if installed).
  • Check for paper under the Upper Tray.
  • Turn power off, then on.
Error 53
  • Open left door and remove any jammed media.
  • Tun the printer off, then on.
Error 60
  • Remove the media from the Multi-Purpose Tray. Turn the printer off, then on.
  • Reinstall the media. Make sure you do not overfill the tray.
Error 61
  • Remove and re-install each Toner Cartridge. Turn the printer off, then on.
  • Replace each Toner Cartridge. Turn the printer off, then on.
Error 62
  • Check for jammed paper throughout the paper path (especially in the paper feeder and Fuser).
  • Remove and re-install the Fuser. Turn the printer off, then on.
  • Slide out and re-insert the paper feeder. Turn the printer off, then on.
Error 63
  • Remove and re-install the Imaging Unit. Turn the printer off, then on.
  • Replace the Imaging Unit. Turn the printer off, then on.
Error 70, 71, and72
Error 73
Error 74
Error 80, 81, 82,83, and 84
  • Make sure that all four toner cartridges are installed in the printer.
Error 01p through
Error 47p
  • Make sure that installed memory DIMM(s) are compatible with printer's image processor board and that they are installed in the proper slot(s).
  • you can helpful
Oct 09, 2014 | Xerox Phaser Office Equipment & Supplies
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
How to reseting hp laserjet printer ETB
59.XY
PRINTER ERROR
For help press
alternates with
59.XY
PRINTER ERROR
To continue
turn off then on
None A printer motor error has occurred.
X Description
0 motor error
1 motor startup error
2 motor rotation error
3 fuser motor startup error
4 fuser motor rotation error
5 print cartridge motor startup error
6 print cartridge motor rotation error
9 ETB motor startup error
A ETB motor rotation error
B developing disengaging motor
startup error
C developing disengaging motor
rotation error
Y Description
0 no color/black
1 cyan
2 magenta
3 yellow
1. Turn the printer off and then
back on.
2. This message might also
appear if the transfer unit is
missing or incorrectly
installed. Ensure that the
transfer unit is correctly
installed.
ETB motor error
1. Clean the ETB unit
intermediate connector, J36.
If the connector is damaged,
replace it.
2. Reconnect the connetors J38
for the ETB motor and J1111
on the DC controller PCB.
3. Replace the ETB motor.
4. Replace the DC controller
PCB. Calibrate the printer
after replacing the DC
controller.
Jun 25, 2010 | HP LaserJet 5550 Printer
HP Color LaserJet 2840 keeps showing 50.2 Fuser error message. Nothing helps correct problem. What to do? Have tried repeatedly turning printer off, waiting several seconds and turning on again. Each time...
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
Jan 12, 2010 | HP LaserJet 2840 All-In-One Printer
Error code: color registration error and ultra-light, smudged printing on right side of paper
have you replaced all of the consumables?
drums X2 black and color
developer units X4 CMYK
transfer imaging belt X1
Fuser unit X1
if the unit has over 60k prints it will need to have these items replaced and once that is done the color registration will come back inline.
Jul 28, 2009 | Ricoh Aficio CL3500N Laser Printer
Error message on Dell Printer 3200cn 010-397
go to this link and go into the first Support Forum at the top off the page might help you out,if not just scroll down the page and you might find something to help you out.. Error message on Dell Printer 3200cn 010 397 Google Search
Oct 27, 2017 | Dell 5100cn Laser Printer
Xerox Phaser 7300 Error U20
1. Contaminated or damaged Imaging unit contacts. - Remove and clean the contacts and inspect for damage.
TROUBLESHOOTING TIPS AND HINTS:
Imaging Unit Failure message occurs because the printer cannot detect imaging unit motion, up-and-down. The Transfer Belt drives this motion, and the Drum Contact Assembly detects it. 1. Swap the Imaging Unit Cotact blocks between two imaging unit positions. If the problem follows the Contact block, it should be replaced. 2. Open the Top Cover and defete the top cover interlock switch. The color imaging units should raise in succession, cyan, magenta, then yellow, and then all lower at once. If one or more imaging units do not raise smoothly or drop prematurely then replace the Transfer Belt assembly.
Apr 29, 2008 | Office Equipment & Supplies
Error message "engine firmware" code 72
Most likley the problem is a faulty Imaging unit. The chip on the unit has failed. You can try reseating the Imaging Unit and if that doesn't work replace it.
Here are the other listed causes.
Cause:
Corrupted NVRAM Possible Causes are Imaging Unit, Fuser, EEprom Board or PE/MCU Board
Feb 12, 2008 | Xerox Phaser 6200N Laser Printer
Minolta magicolor 3100 Laser Printer Logo
1,137 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
