Question about Samsung LN-R3228W 32 in. HD-Ready LCD Television
SAMSUNG LCD LA32S8
Hello, when i switch on the tv it comes on for a second or so and then just goes blank? Any idea what could be the problem? I've tried unplugging it and using the DVD player but it does not help?
5 Suggested Answers
SOURCE: optical output on tv through dvd home cinema out of sync
I've finally found the solution to this - after several calls with Samsung.
Basically, the analog audio output is the same signal as the digital, optical output. Both of these signals are sent _ahead_ of the picture, to give a digital amp some time in which to do its audio processing.
Samsung's solution is that I need a digital amp with an 'AV sync' setting, so I can add a bit of delay to the sounds so it waits for the picture to be in sync.
What this means, is that this Samsung TV only works properly with digital amps having 'AV sync', and it cannot work with any analog amp.
Nice.
Posted on Feb 28, 2008
  • 718 Answers
SOURCE: Samsung LNS2641D 26-Inch LCD HDTV lost its picture
Since you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then its one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
Posted on Mar 10, 2009
  • 610 Answers
SOURCE: LE40556P lcd samsung. Screen will not switch on.
usually you can see the tops of one or more capacitors bulged up when the power supply board has failed. VERY common on Samsungs.
Posted on Nov 18, 2009
  • 610 Answers
SOURCE: 32'' Samsung LCD HDTV - will not turn on
needs power supply board replaced. VERY common problem, can call 1-800-samsung for nearest service center.
Posted on Dec 29, 2009
  • 927 Answers
SOURCE: Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Posted on Jan 02, 2010
How to reset samsung LCD tv la32s8 to its factory settings
hi it's usually info, menu, mute, power, make sure the tv is on standby when you do this. hope it works for you
regards
shaun
Mar 06, 2014 | Televison & Video
Screen goes blank on Samsung LCD TV. Comes back on if tilt or move screen.
I'm gonna go out on a limb and say you may have a LCD tab(s) that are failing.
Jan 26, 2013 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung le40d503f7w only displays samsung logo on screen for a few seconds after switching on and then goes blank
have the same problem, one or more of the flourecent light bulbs in the back panel got broken, looking for a supplier who may keep these bulbs in stock, or other wise will see if i can get a used one off ebay for spares.
Jan 24, 2012 | Computers & Internet
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
I VE A SAMSUNG LCD TV/MONITOR SNYCMASTER 932 19
can you see that a capicitor 820/10v is pluked ? replace it.
Feb 21, 2010 | Samsung SyncMaster 932B LCD Monitor
Samsung TV problem - Blank screen after one second.
Ur LCD inverter board is dead.Part and labors about $200-$300 dollars.
Jan 07, 2010 | Televison & Video
LCD TV blanks out when I flick the switch for my room lights
Do you have surge protector installed? If not, you should use one, something like MONSTER CABLE.
Nov 27, 2009 | Televison & Video
Samsung T.V. goes on for 30 seconds then no picture
If this is a flat panel LCD tv, this is a sure sign that the panel itself is bad. I have seen this before. Tv comes on works fine then within 5 minutes goes blank.
Aug 07, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
SAMSUNG LCD WONT TUNE INTO NORMAL TV STATIONS
You need to have a licensed antenna repairer out to fix your antenna. Just because your old tv is receiving enough signal to JUST get a picture doesn't mean your new tv will, A new tv doesn't mean you will get a perfect picture if your antenna is dodgy
Dec 30, 2007 | Televison & Video
Samsung LN-R3228W 32 in. HD-Ready LCD Television Logo
126 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
