Question about Kenmore HE3T Washer
My Kenmore HE3t was run for more than 10 minutes with water valves turned off. Now it will not reset. How do I reset the machine?
  • 5,911 Answers
UNPLUG the washer for at least 30 minutes. This will reset the Central Control Unit (CCU), which is the main control board for the washer. Make sure the water valves are on and plug the washer back in. If the washer still does not clear after a CCU reset, there is a diagnostic procedure you can run that, not only checks all the basic washer functions, but will also clear most momentary program glitches. Each one of these washers comes with a tech sheet inside. The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
Read through the information provided and if you have questions, please post back with your complete MODEL NUMBER and let me know. I hope you find this information helpful.
Posted on Aug 23, 2010
Testimonial: "Leaving it unplugged for the day did the trick. Previously, I had waited only 10 minutes. So, I did not need to open it up or expend any money. Thx!"
Washer starts and runs for about 10 minutes. Then stops and gives error message HF
Hello & Welcome to FixYa
FH error code is displayed when the control detects no water entering the machine. To clear this error press and hold the PAUSE/CANCEL button twice. You can then check if the water inlet valve is fine and not clogged with foreign particles, try to clean it. If the water inlet valve appears to be fine then check if the pressure switch hose is properly connected to the pressure switch & tub. Please get back to me if you have any questions.
Kevin
Mar 07, 2011 | Kenmore HE3T Washer
HF error flashes, then after 7 min. drains machine, but won,t go in wash cycle
Kenmore HE3T front loading washing machine. About every 2 minutes the cycle stops and flashes an "f" then an "h" on the display over and over again. **
That error code can be the result of no water detected entering machine after 30 seconds or pressure switch (water level control) activation not detected after 8 minutes of filling.
If there is no water in the machine at the time, make sure that both water taps are turned on, check for kinked fill hoses or plugged sediment screens in them and verify the water fill valve operation.
If there is water in the unit, verify drain pump and water pressure switch are operating properly, the pressure switch hose is in good condition and properly connected to the pressure switch. Also, make sure the water is not siphoning out of the machine prematurely due to an improperly installed drain hose
That error might also be caused by too much suds in the wash water like can result from using non-HE detergents
Nov 29, 2010 | Kenmore HE3T Washer
How do you fix a FH code ( water inlet problem) on a Kenmore Elite HE3t front load washer
The FH indicates a fill failure and this is usually caused by a bad water valve, flow meter or pressure switch.
One key to determining the cause of the FH error is how fast the error comes up in a cycle. If the error appears within a1 or 2 minutes then the most likely cause will be the water valve or flow meter.
If the error doesn't appear foe several minutes then the pressure switch can be the source of the problem.
Both water valves must be turned on and working. Even if a cold wash is selected at some point during the fill the hot water valve will be energized and if there is no water then the FH error will show up. Sometimes a consumer will turn the hot water valve off to save energy but you can't turn one valve off on this washer.
Nov 28, 2010 | Kenmore Washing Machines
Kenmore washer HE3t won't turn on but is making beeping error sound when pressing power button. Is there a reset button to press or common problem
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%$@@
Jun 20, 2010 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Kenmore elite washer he3t- beeping F02
"F/02"
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 13, 2010 | Kenmore Washing Machines
I keep getting the F21 code on my kenmore HE3t washing machine. What does it mean other than call for service?
The f21 code means that you need to clean the filter.
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
If the drain time exceeds 8 minutes the water valves turn off.
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Sep 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
He3t washing machine bleach dispenser if full of water after a load of wash.
Pull disp out. Check to see if its clean. Put into sink and run a sead stream of water into bleach cup till overflows and syhpon tube begins to drain water. Turn of spicket while holding disp steady and level. If the water drains cold water valve is faulty or screen is restriced reducing water preasure. Poor water preasure will prevent proper syhponing. If disp doesn't syphon or drain water out while in sink its either faulty or dirty.
Jul 17, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My kenmore elite he3t showed an error code f02, i unpluged it and plugged in back in i tried to run a drain/ spin and the machine make a strange noise i suspect the motor filter is clogged and the moter is...
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
***You stated that there was a noise when you started a manual drain. This may be a damaged drain impeller. in this case, replace the entire pump(drain).
Jun 07, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Washer fills with water when the machine is not running
Either the hot or cold water valve is not closing completely. In either case, the mixing valve assembly will require replacing.
Feb 04, 2009 | Kenmore 42924
Kenmore HE3T Washer Logo
159 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
