Question about Copystar CS-1500 Copier
The screen is saying c-6 and won't let us clear it.
  • 29 Answers
If you wait is the 6 followed by 0's after words if so its a C-6000 and is as follows.
Broken fixing heater wire
• In fixing warm-up, the time to reach 50°C/122 °F exceeds 13.5 s, the time to reach 100°C/212 °F exceeds 10 s, the time to reach the primary stabilization exceeds 10 s or the time to
reach the secondary stabilization exceeds
Poor contact in the thermistor connector terminals.
Broken thermistor wire.
Thermistor installed incorrectly.
Thermal cutout triggered.
Heater lamp installed incorrectly.
Broken heater lamp wire.
Solutions:
Check the connection of connector CN4 on the power supply board (KP-5059) and the continuity across the connector terminals. Repair or replace if necessary.
Measure the resistance. If it is ∞ Ω, replace the thermistor.
Check and reinstall if necessary.
Check for continuity. If none, replace the thermal cutout.
Check for continuity. If none, replace the heater lamp.
Something in the fixing assy has gone awry.
Hope this helps.
Posted on Aug 26, 2010
When I turn on HP pavilion windows 8 os it says starting automatic repair and then goes to black screen
this is a commom issue with windows 8 on HPs. turn off your automatic updates then contact windows. the updates usually gets to 13% and then freezes.
Jul 27, 2013 | HP Pavilion Computers & Internet
Ps3 won't work, screen says restore software
take out ur harddrive, turn ps3 on wit no hardrive den put it back in and turn on again,
if this dosent work hold power button and eject button on front of ps3, 1st u will hear 1 beep then 2beeps ,wen u hear 2 leave go,
it will say connect controller with usb, do that and u will get 6 options,
pick option 3,but if that dosnt work pick option 6 ,but option 6 will delete all ur saved data so be warned.
Nov 24, 2012 | Sony Playstation 3 (PS3) Console
My Casio classpad won't give me the correct answer
I am not sure about what you want. The expression is in its most compact form. So I am assuming you want to exapnd it. The command for that is exapnd( . Just type it using the keyboard or look for it under the Action>Transformation menu.
expand((x+5)^6) [EXE]
Here is a screen capture of what you should get. Notice that I cleared all 1-letter variables to erase any value stored in x.
Jul 11, 2012 | Office Equipment & Supplies
After paper jam, printer won't initialize
try to switch it off unplug leave for 15 min and switch back on.
Jun 30, 2012 | HP P2055DN LaserJet Monochrome Printer
I have an E 6 error message on my Kodak i1320. It won't clear out. The cover is closed. I blew compressed air on the sensors. The manual says E 6 means the cover is open, the software says it's a...
The error is the ultrasonic sensor thinking it is blocked , there are 2 sensors one on each half of the transport small round grills approx 8 mm in diameter in the center just after the feed rollers if cleaning these doesnt help they are probably faulty and will need to be replaced , cleaning with compressed air can damage the sensors as they are quite fragile lightly blowing or carefully vacuuming is the best way
Sep 19, 2011 | Kodak i1320
Blue screen, says Bootloader USB Init at bottom, won't restart with power key
1.go to http://www.modmymobile.com
2.download p2ktools zip file
3.extract zip file
4.down firmware for motorola razr v3 zip file
5.extract razr v3 zip file
6.open p2ktools extracted folder open p2ktools exe file
7.read help how to flash your motorola razr v3
Aug 24, 2011 | Motorola Mobility RAZR V3
I get a ink system failure, hp c8180 all in one printer ?
Hi, Its a common error which comes for many individuals and we can rectify by ourselves.
Please perform the following steps. 1]Press and hold the "*" key. 2]Press the "#" key and release both keys. Display should say "Enter Special Key Combo" 3]Press and release in sequence the "1", "2" and "3" buttons.screen will say "support" R0631M 4]Press and release the right arrow button until the display says "System Configuration Menu". 5]Press and release the "OK" button. Display should say "Hardware failure status". If not there already, Arrow Key over to "Hardware failure status", 6]Press and release the "OK" button.Display should say "Hardware failure status: Clear. Press OK to clear". 7]Press and release the "OK" Button. Message changes to "Hardware failure status Cleared. Press Cancel to continue". 8]Press and release the "CANCEL" button as many times as necessary, so that, either the "Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet. 9]Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer 10]11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK. The Printer will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page. 11]The error won be displayed in the printer. 12]Let us print a self test page to check the functionality of the printer.Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report
THANKS FOR USING FIXYA..FEEL FREE TO POST YOUR COMMENTS.. BEST WISHES
Dec 19, 2010 | Office Equipment & Supplies
All Channles locked out
To clear all locked out channels, press the SRCH button, select the bank you want to clear, press the FUNC button, then press the L/OUT button, then press FUNC button,then 6, press 1 to clear all...hope this was helpful...
May 20, 2010 | Radio Shack Pro-97 Handheld Scanner
I have a Thomson DTI6300-16 freeview box. I'm
This could solve problem
1. Select Menu, Set-Up, Help.
2. Press the Green button on the remote control.
3. This shows the Advanced Information screen.
4. Now press the Blue button which will prompt you with a warning box.
5. Now press the Green button if you wish to proceed.
6. The DTR will take around a minute to complete the reformat, and will then automatically restart itself.
Next do a channel rescan.
Mar 05, 2009 | Arris DCT2608
Fix system error
Please click on the below link or copy the URL and paste it in your web browser. Follow the steps..
http://support.lexmark.com/perl/support/support.cgi?ccs=229:1:0:93:0:0&docid=ENUS547
OR
If you are getting any type of 'CLEAR SYSTEM ERROR' on the LCD screen of the printer, please follow these steps:
1) Remove the power cable for 2 minutes and the USB cable from behind the printer.
2) Press and hold down the stop clear button and reconnect the power cable back to printer.
3) The printer LCD screen should clear the memory error.
4) If the same error message persist on the LCD screen, please follow the instructions below.
5) Unplug the power cable for 2 minutes and USB cables from behind the printer and open the printer cover and remove both ink carts.
6) Repeat step 2 and Install both cartridges then the screen will display Cartridge's clean, press start.
Thank you........
Sep 28, 2008 | Lexmark X63 InkJet Printer
Copystar CS-1500 Copier Logo
42 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
