Question about Fagor 5HA-196 X Single Oven
Gorenje oven is showing F85 - Fagor 5HA-196 X Single Oven
Oven locked !
You will need to press and hold the clear or stop button for at least 3 seconds, if it is locked due to a cleaning function you will have to wait for it to cool down until it allows you to open it. You could do a hard reset and flip your circuit breaker for your kitchen off and then back on a moment later and try again.
Nov 21, 2013 | Ovens
Gorenje EI44A1-T34 or EI44A2-T44 Dear Sirs,we have the oven for quite a while,but never used the oven part of this induction oven. And therefor didn't bother too much with the blinking light showing...
I hope you have found already solution for this... Anyway this may help others: press buttons 1 and 2 together and release. Then use jog wheel to adjust time. Wait 5 seconds and you're done. Gorenje manual sucks, no info about oven controls. I managed even to set on oven child lock (key symbol), only way to take it off was to remove fuses from electric board of our house!
Jun 24, 2011 | Ovens
When trying to start oven for baking. I set the temp & press start. It shows the selected temperature, then, after about 10 seconds shows 100 degrees. Nothing happens after that. Oven does not ignite....
well, at least your door hinges are still working. Let me guess, this is less than 6 months old. Every review of these ovens shows the door function breaking. I wish I had better news...and good luck!
Jan 01, 2011 | GE 24" Built-In Single Gas Wall Oven
I tried to auto clean bottom oven. Showed err
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Apr 05, 2010 | KitchenAid KEBC208 Electric Double Oven
Kenmore oven showing an F3 and later F5
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Nov 11, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
I need a handbook for a gorenje gas hob and fan oven
Hi
You need o call Gorenge and they will send it if they have it.
0845 050 8555 UK
please leave feedback
Feb 11, 2009 | Ovens
Gorenje B3350E
Briefly press the first two buttons simultaneously (the button that says Timer with a picture of a bell and button with a picture of a steaming pot). You should now be able to set the time with the jog dial. It automatically starts the time a few seconds after you release the jog dial.
I have a Kleenmaid TO400 in Australia and it's the same as the Gorenje B3350E. Thankfully I have the manual as this would be impossible to guess
Aug 03, 2008 | Ovens
Fagor 5HA-196 X Single Oven Logo
438 people viewed this question
Top Fagor Ovens Experts
Dan Webster
Dan Webster
Craig Butler
Craig Butler
Bill Boyd
Are you a Fagor Oven Expert? Answer questions, earn points and help others
