Question about Dishwashers
Bauchnecht GSF 5343 dishwasher
I have a Bauknecht GSF 5343 dishwasher and have lost the instructions manual. The LED next to the star shapped symbol on the top left hand side of the panel lights up red when I switch on the machine. Can anyone help me by telling me what this symbol means
I used to work for Bauknecht years ago.
I dont remember that machine, but it could be an indication that your salt dispencer needs refilling.
Posted on Jun 10, 2008
Bauknecht gsf 4481
The timer is not advancing to the next cycle. Replace the timer.
Mar 13, 2014 | Bauknecht Dishwashers
My Bauknecht GSF 6550 dishwasher is stuck with error F4. Whar does it mean ? What can I do?
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/PUMP MOTOR/DRAIN to work when it is commanded .If this does not happen then the voltage at these points must be checked or the fault relates to no voltage/drive from the controller. This means the controller is a suspect. The error indication can be a short in the circuit, check the heater circuit and the pump motor.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.espares.co.uk/advice/dishwashers/a/3
Thank You for using Fixya
Sep 03, 2011 | Bauknecht 24 in. GSF8984 Free-standing...
What do the Tecnik dishwasher symbols mean? I have a unit not working with a warning light on I cant find in the manual.
The little star means you've run out of rinse-aid. See the flap that's next to your tablet dispenser, it has the same star on the lid, inside there you can refill the rinse-aid by pouring it into the tiny gap next to the dial! The dial setting allows you to change the flow of rinse-aid...the light will then go off. However, I've yet to find out what the light with the two directional arrows means! Ill post when I know!
Mar 12, 2011 | Dishwashers
Have got a bauknecht dishwasher model no gcx 5521. had the same problem last year. water is not going into the machine it looks like the water stop device activated. I think its something to do with a...
have got a bauknecht gsx4756 which when started beeps continually and start light flashes. it automaticaly then flashes the rinse button as well. I have reset holding down start and mode selection button next to the start button the fault keeps recurring. just wanting to know what the problem is before paying an engineers extortionate call out fees
Jul 31, 2008 | Bauknecht Dishwashers
GSF 3152 S
Fehler gefunden und repariert, vielen Dank und Gruss !
Apr 02, 2008 | Bauknecht 24 in. GSF8984 Free-standing...
What does F7 Means?
The F7 means that the drain filter is blocked or your water pressure is low. Check and clean filters. Good luck !
Apr 25, 2007 | Bauknecht 24 in. GSF8984 Free-standing...
Dishwashers Logo
1,745 people viewed this question
Top Dishwashers Experts
