Question about Craftsman Garden
Trouble with carburetor,runs after priming then shuts off.sears push mower model917.382730 installed sears kit need soloution.problem occurs every time it is started.have replaced primer kit which works, it will start but wont run.after priming motor runs for a few seconds and cuts off.
  • Craftsman Master
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
After cleaning and before you reassemble the carb, be sure to "set" your float level, turn the carb upside down and make sure the float is LEVEL and not tilting up or down
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Posted on Aug 23, 2010
Dynamark 3.5 Model 20211X18A. Looking for manuel, I prime 2 times to start. Engines starts then dies. If I continue to push prime button it will keep running, barely, however, dies as soon as I stop...
Could be 2 things: a restriction in your fuel line/coming out of the tank, or 2: a dirty carburetor needing to be removed, cleaned and possibly rebuilt and reinstalled. Hope it's one of those.Start with pulling the fuel line loose from the carburetor. If you have fuel flowing freely, plug the hose with a golf tee and move onto removing the carburetor. Carb kits are cheap and easy to install. It's best to rebuild while you have it off to avoid similar problems later.
Sep 30, 2013 | Briggs & Stratton Briggs Stratton...
Mower only runs on choke, air filter is clean
Please rate me,
Thanks
Good Luck,
I hope this helped
Aug 14, 2010 | Mtd 22" Yard Machine Push Mower
I have a 2 year old push mtd lawn mower , it wont ...
Sometimes you can get by with priming it a few times, and letting it
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
When you clean your carburetor and remove the jet screws, count the
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
May 20, 2010 | Mtd 22" Yard Machine Push Mower
Lawn tractor runs fine then shuts off then runs fine then shuts o
they were in/out.
May 23, 2010 | Sears Arnold Lawn Mower Replacement Eager...
Havte to keep pushing prime to keep running when cold and restarting
they were in/out.
May 20, 2010 | Craftsman Front Propelled Rear Bag Lawn...
Mower runs at slow speed only
they were in/out.
Please rate me, Thanks
May 13, 2010 | Poulan "Poulan" Push Mower
My push mower starts but then dies after a few seconds. please help.
they were in/out.
May 11, 2010 | Craftsman 675 Torque 190cc 21" RearBag...
Totr model #20479 GTS 5 motor, when you push prime
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Nov 16, 2009 | Toro Lawn Mower With Toro Power Tools
I can prime with bulb and runs a couple seconds then shuts off
You need to clean the carburetor. Or, you need a new carb. kit. If you need tips on how to best do this, just let me know.
Jim
Jun 03, 2009 | Craftsman Garden
Will crank but will not remain running
Need to remove carburetor and clean out jets install new kit and replace.
May 05, 2009 | Garden
Garden Logo
181 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
