Question about Sony Cyber-shot DSC-W70 Digital Camera
When i turn my camera on its saying access and lense goes in and out how do i fix?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 23, 2010
"lense error, restart camera"
on the camera bottom by the battery theres is a little niddle size reset button press it wit niddle when camera is on then it will restart to factory setting you can try more then ones pushing it.please leave comment,vote,note.thankyou
Sep 13, 2009 | Canon PowerShot A470 Digital Camera
My EX-S5 says lense error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 10, 2009 | Casio Exilim EX-S600 Digital Camera
Sony camera
ok to fix this just switch on
gently pull and twist the end of the lense you may here it click but dont pull or twist to hard till it pops
then switch camera off and on again and you should have solved the problem.
hope this helps
Sep 10, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-Shot DSC S90 lens problem - fix or buy new?
its better to replace a new one than to repair it and besides you will cost alot if you decide to repair it. although if the cost is not that much then go for repairing it.
CHARCOIS
Aug 27, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Access error
turn on take hold of the end of the lense then gently pull and twist you may hear a click but dont force it then turn off and on again and the problem should be solved
Aug 09, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cybershot
turn on
gently twist and pull the lense you may hear it click but dont force it then turn on and off and this may solve your problem
Aug 05, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Dsc w7
While turning in off softely press the lense in and out a couple of times. The lense would retract. If not fully, but most of the way, push the lense a little harder in until completely retract. If you turn it on, I should work fine. The reason the lense does not retract is most likely some dust in there somewhere. If it did not help, you would have to open the lense and clean it and close the lense.
I hope it helps,
Jul 13, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
22 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
