Question about D-Link DIR-625 (790069292637) Wireless Router
Hello I have problem with D-LINK DIR 100 and VPN connect. I have 2 comp with 2 diferent VPN connection (PPTP and L2TP) to SQL server but one comp with PPTP connection have problem to download data from server and second comp have no problem with that.
  • Aris C.
    Aris C. May 11, 2010
    If you connect using the computer with the PPTP client configured without the other computer with the VPN client connected through the server are you still experiencing the same problem, this is just for isolation if it does work, your router only support single VPN client passthorugh(most SOHO routers only supports single VPN passthrough not simultaneous).
Try this link http://support.dlink.com/supportfaq/DisplayTemplate.aspx?TemplateId=1443235
Posted on May 31, 2008
Hi, my dlink dir 600 is funished as an access point and i cant connect to the pptp vpn server from my university. What do i have to do?
the problem is most likely that your university blocks the pptp ports so you cannot connect to the VPN. are you able to access it if you plug your computer directly into the wired connection?
Sep 27, 2013 | D-Link Computers & Internet
I have a D-Link DVG-G1402S router, I'm trying to setup VPN connect for a windows VPN server, which inside the network. I tried use modem directly connect to the server, it work, so it process my...
The router's PPTP passthrough and IPSec settings assume that you're connecting to an external VPN server on the public side of the network, but it sounds like you're hosting your VPN server inside your local network. If this is the case, you may just want to have your windows VPN box in a DMZ, or get a router that you can exert more control over. Be wary, if you're doing this at a residential location, your internet provider will probably block or "shape" this type of incoming traffic to your local network.
Mar 05, 2011 | D-Link DVG-G1402S Wireless Router...
I am having problems connecting VPN Connection on my Windows 7, it says there need to be a machine certificate installed before i can connect using L2TP/IPsec. error code :766
"Error 766: A certificate could not be found. Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate."
"Error 766: The L2TP connection attempt failed because the security layer could not authenticate the remote computer."
Cause: Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate. You will see this error message when such a certificate is not available.
Typically, this error is generated on a remote access server that has active L2TP ports configured, the remote access service started but there is no certificate in the computer certificate store. This generates an event log message that tells the administrator that L2TP ports will not be able to accept calls until a certificate is acquired and RRAS is restarted.
Resolutions: 1. If you use PPTP VPN, select Automatic in Type of VPN.
2. If you use L2TP, check the remote access server and make sure there is certificate in the computer certificate store.
Sep 18, 2010 | Computers & Internet
Use 2 wire to run laptop
Yes you can use the laptop with this router because this is a wireless router.
Details of the router are:-
Manufacturer: 2wire Product MPN MPN 1000-400108-001 Key Features Router Functionalities dtrquestion.gif Wireless Access Point • DSL Modem • Firewall • DHCP Server Connectivity Wireless Interfaces Built-In 4-port Built-In Switch LAN Interfaces 10/100 Base-T Additional Interfaces 1 x USB Standards and Protocols LAN Standards IEEE 802.3 CSMA/CD or Ethernet • IEEE 802.3u 100 Mbps (Fast Ethernet) Protocols dtrquestion.gif AAL5 • ARP • ATM • DHCP • ICMP • IP • PPPoA • PPPoE • TCP • UDP Remote Management Protocol dtrquestion.gif SNMP • HTTP Firewall / VPN Firewall Features Stateful Packet Inspection (SPI) • NAT VPN Protocols IPSec Pass-Thru • PPTP Pass-Thru • L2TP Pass-Thru Authentication CHAP Wireless WLAN Standards IEEE 802.11b 802.11b Data Rates 11 Mbps, 5.5 Mbps, 2 Mbps, 1 Mbps Modulation dtrquestion.gif CCK • DBPSK • DQPSK • DSSS Security dtrquestion.gif WEP Antenna Type dtrquestion.gif Internal / Integrated Antenna x 3 Modem DSL Standards ADSL Lite (G.Lite ITU G.992.2) Other Features LED Indicators Power • DSL • Link Additional Features Auto Crossover (MDI/MDI-X) Dimensions Width 2 in. Depth 10 in. Height 8 in. Weight 1.4 lb. Miscellaneous Release Date December, 2003
May 03, 2010 | 2wire (1000-400108-001) Router
VPN issues
First check to see if your brand of router will allow you to connect via VPN not all do..
Mar 02, 2010 | Intuit QuickBooks Pro 2008: Windows
Problem connecting to VPN (PPtP) via DIR-655
pimrakers
Since it work when directly connected to your modem then most likely it is an IP issue. With VPN you router can not be in the same subnet as the one you are connecting too. So alot of places do not change the IP's the equipment unless they have to you just got lucky and a router with the same default settings. If you change the IP address then you should be able to connect. Note you should only have to worry about the last 2 number sets. Example if your routers IP is 192.168.1.1 then I would change it to 192.168.5.1. Just remember what you changed it to. Also you can use any number between 1 and 254.
Let me know if you have any more problems or questions.
Issken
Jan 15, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Belkin F5D9230-4 won't allow a connection to M Exchange server
Login to your Belkin router and check to see if there is a firmware update available for your specific model. If so, download and install it as this may resolve the problem without doing anything else. (Be sure to save your configuration first)
The specifications for a F5D9230 state that it supports VPN passthrough so you shouldn't need to configure anything in the router itself. It may be necessary to open a few incoming ports but only as a last resort.
Would you also reply to this post and specify...
  1. What OS are you running on your pc?
  2. What VPN client are you using on your pc?
  3. Ask the administrator of the Exchange server if they're using PPTP or L2TP for VPN connections.
Another option would be to use OWA (Outlook Web Access) to access your email if it has been installed on the Exchange server.
Aug 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
How to connect to my PIX 501 and use Windows Remote Desktop?
Here's a real simple problem to your remote access problems.
Go to: http://www.logmein.com
Sign up for a free acct, download/install their free software on your Server.
Now go over to your laptop, login to your new logmein acct.
In the next page, you'll see your Server listed. Click on it - follow instructions to connect.
This will tunnel through whatever stuff you have on your network!
Trust me - esp. in your scenario, this is *by far* the *simplest remote connect you'll ever perform! And it just .... works! Everytime.
gurutim
Mar 16, 2009 | Cisco PIX 501 Firewall
VPN drops when using a D-Link Dir655 router
Hi! Try to logon to the configuration page of your router. then go to Advanced tab and click on Firewall settings on your left side.
At the bottom part you could see the Application Gateway Level section, Uncheck all the boxes under that and click on Save Settings at the top.
Mar 06, 2009 | D-Link Xtreme N DIR-655 Wireless Router
VPN Access does not work
Use should add arp proxy setting as the following:
Go to Interfaces and then click on PPTP/L2TP server from the PPTP/L2TP Page go to the Add ROute Tab.
Allowed Networks should be : All Nets
under Proxy Arp you have 2 Boxes:
One is: Available and the other is Selected.
Under Available click on LAN and move it to Selected.
now save and activate and it should work.
Dec 18, 2008 | D-Link Netdefend DFL-210 (DFL210)...
D-Link DIR-625 (790069292637) Wireless Router Logo
368 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
