Question about Waring WSB40 Blender
I have 3 waring WSB40 stick blenders either with the blade in the shaft snapped off or loose is this fixable
4 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: We have an old Waring Futura 900 blender that
Yes their is a gasket. However try to tied the hole blade kit a litle harder since it might be loose, it might be also dirty you can loose it clean it and put it back.
Have a visual insections since the glass might be broken a litle bit also.
Good luck
Posted on Aug 17, 2010
vko007us
  • 254 Answers
SOURCE: how to replace a blade assembly on a waring
Hi, plz try this link if it works:
http://www.beveragefactory.com/refrigeration/blenders-juicers/blenders/MBB518.shtml
Posted on Aug 22, 2011
SOURCE: Waring blender - model 51bl25
My Waring 51BL16 is having difficulty blending and some mechanism on the inside keeps spinning once the blender has been turned off...any ideas?
Posted on Aug 28, 2011
Why can't coupler turn blade?
Drive shaft may be stripped
Dec 27, 2015 | Waring RB70 Blender
Replacement end coupling
Possibly an appliance parts supplier can help.
Nov 27, 2013 | Waring WSB40 Blender
How do open a Waring WSB40 Mixer
Blender not working,Power supply is ok.
Jul 26, 2012 | Waring WSB40 Blender
We have an old Waring Futura 900 blender that leaks at the bottom of the glass around the beater blades. How do you repair? Is there a gasket?
Good luck
Aug 09, 2010 | Waring BB180 Work Top Blender
I have a Waring Pro Speciality Blender. After only a few times in use, the jar began leaking and I noticed glass shards around the outer rim of the jar. The blades are fixed on this model. I wrote to the...
If you don't see a physical crack or stress line on the jar, the issue could be either the gasket or blade assembly - Waring doesn't list any parts for sale for this model, but you may be able to call them and get these parts. There are not very many reviews on this particular Waring, so I am working with very limited information (and this is just my opinion), but the few that I have seen suggest that this might be the worst blender Waring ever made (in general, though, their blenders are usually top-notch).
Consumer Guide generally rates it high, but issues this:
"Cons: Strong churning motion requires you to hold the lid in place to prevent leakage through the top and limits the ingredients capacity, especially for hot mixtures"
The sites that invite the most user input into the rating generally give it a 2-star rating.
Waring seems to have escaped somewhat from their usual blender shape - and I have even heard that the shaft is made out of rubber, which is frightening.
Mar 31, 2009 | Waring RB75 Specialty Blender Stainless...
Blade doesn't spin freely
Here's the parts order form from Waring:
http://www.waringproducts.com/ret/parts/
Once you receive the parts, unscrew the collar from the bottom of the jar, and the old gasket and blade assembly will pop out - sometimes you have to peel the gasket apart from blender jar, but not always.
-Tha Mp3 Doctor
Mar 26, 2009 | Waring MX1000R Blender
Mar 15, 2009 | Waring PBB 201 / 204 / 209 / 212...
Waring Pro Blender is leaking and blade assembly is loose
I know this is an old, old post, but I could not find a solution anywhere, so hopefully this will help someone. We have a model 51BL25, similar to scottman55's blender, and it had the same problem. There are two separate nuts in the blade assembly. One holds the blade on, and the other holds the seal tight. When the latter gets loose, the blender shakes and leaks.
To fix it, first you have to remove the top nut holding the blade on. I had to get in there with pliers, but a ratchet with an extension would be perfect. This nut is right-handed ("normal"). Once that nut is loose, you can remove the nut and the blade. You will also want to remove the washer immediately under the blade (take note of which side goes up).
Now, you can pull the whole axle out by the wheel on bottom of the blender. This exposes a really thin, flat nut. In my case, this nut had come completely off, so nothing was really holding the seal together at all. Again, make sure you remember which direction the nut goes -- it is not quite symmetrical. That nut is what comes loose when the blender starts leaking. By the way, it is a left-handed nut, so it screws on counter-clockwise ("backwards"). Screw it in tight, then put the rest of the blade assembly back together, and your done. If you have the right tools, it should take only maybe 5 minutes.
Depending on your problem/model, this may or may not solve your problem. Hope it helps!
Jan 28, 2009 | Blenders
Stopped blending
Exact same problem.  Turned out the threaded shaft that holds the blades was broken so tightening the nut on the top doesn't really help.  Just ordered a new blade assembly from www.smallappliance.com.  Mine was the Waring 007314W Blender Cutting Assembly but there is also an older one for earlier models.  Don't know if it will work yet (assume it will), but cheaper than buying a new blender.
May 17, 2007 | Waring PBB 25 Professional Work Top...
Waring WSB40 Blender Logo
71 people viewed this question
Top Waring Blenders Experts
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
