Question about Hitachi M12V2 3Router
How do you change the collets on the Hitachi m12v2?
  • 843 Answers
Matt, Remove the collet nut completely. The collet should come right out of the end of the motor shaft. Put the other collet in it's place and replace the same nut. I assume you are switching between 1/2 inch and 1/4 inch tools.
Posted on Aug 23, 2010
  • matt_leafs_1 Aug 23, 2010
    yeah thanks i was able to figure it out. I had the rigth idea all along but the reason i was confused was i couldnt seem to get the 1/2" collet out with my hands, until i decided to get some pliers and then i was able to pull it out
  • Al Kupchella
    Al Kupchella Aug 23, 2010
    It did seem like an odd question. It never occurred to me that it was stuck. Glad you worked it out.
How do I change a router bit on a craftsman router model number 315.174700
lock the collet by turning the on-off switch to off, push the button under the on-off switch to lock the collet then use the supplied wrench to loosen the collet.
Jan 19, 2013 | Craftsman 315.174710 Routers
This hasn't been used in a long time and I'm trying to change the bit/head. Even with the Collet nut loosened, the bit that's in there will not budge. I even took the Collet nut right off to...
Is it possible to grip each part with a pliers and twist and pull at the same time to release the bit? Let some oil run into the collet before you do this.
May 12, 2011 | Craftsman 2.0 amp Rotary Tool Kit
How do I change parts, i.e. from grinding wheel to sandpaper wheel?
There is a collet type on most rotary type tools. This is located on the end of the tool where the grinding wheel is inserted in the device. The collet has a normal thread pattern. Turn counter clockwise to loosen the collet. Some time the collet gets tightened to toght and then just take a block of wood and gently hit the collet to see if this will loosen the bit.
Mar 14, 2011 | Craftsman Single Speed Rotary Tool
Bit wont tighten down in collet
Get a new collet and nut the 1/2" collet is crappy, it is too thin and pushes out of the nut easily.
You may also make sure that the collet did not seperate from the nut. remove the nut completely and if the collet is not attached, remove the collet from the spindle, insert inthe nut and then insert the bit through the collet while holding it and then put the hole thing back on the spindle (mtor shaft) and tighten it.
Oct 19, 2010 | Hitachi M12V2 3Router
Frozen collet nut on Craftsman model 315.175040 router
It is a right-hand thread....heat it with a propane torch and that will loosen the nut
Jun 03, 2009 | Hitachi M12V2 3Router
I cannot get the chuck to tighten the collet
sounds like u are using the wrong collet in the end of dremel the normally have a couple of different collets try changing it for a tighter one also make sure its in the right way
May 29, 2009 | Dremel 750 02 Minimite Cordless Rotary...
How does one change from one collet size to another size. My Freud router came with the 1/2" collet installed and I need to change to the 1/4" size supplied with the router to fit a bit I want to use....
I just did this on my black and decker router. You need to unscrew the nut that holds the collet and remove it altogether. Then slip out the collet in there and replace it with the new size. Take care to notice how it goes in when you take the old one out. Then rescrew the nut that holds it in place and tighten. My router had three collets and only one of them works for each size, so if it doesn't tighten properly, it may be the wrong size. Good luck.
Apr 28, 2009 | Freud FT1702VCEK Router
Router suddenly turns off in the on position
Your cord has a short in it change cord and or check that wall outlet is not faulty .Try plugging into other outlaet with extension card .Please rate.
Apr 04, 2009 | Hitachi M12V2 3Router
Hi I have A freud 2000 and have had it for several years but I only recently removed it from the box (long Story) I was trying to put in the 1/4" collet adapter ad it would not go in at all as long as the...
I have had a similar problem with my hitachi m 12 v. I ground the end of a long flat piece of metal so that it would fit around the collet. Mine had sort of a lip on it that the home made tool would fit under. the thing I made was shaped like an  open end wrench. I had to grind it down so it would be thin enough to fit under the lip and just fit around the collet. Then I hit it with a small hammer. a few times on each side of the collet. I kept going from one side to the other until the collet popped out.
Jan 30, 2009 | Freud FT2000E 3 Router
Laminate Trimmers Troubleshooting
Changing Bits: 1. Unplug the tool. 2. Turn the knobs on either side of the tool to loosen the base. 3. Remove the base. 4. Press the spindle guide to lock down the shaft. 5. Use a wrench to loosen the collet. 6. Remove the bit and collet. You may have to tap on the collet to loosen; careful not to tap on the cutting edges of the bit. 7. Insert the new bit and collet. 8. Use a wrench to tighten the collet into place. 9. Replace the base.
Aug 27, 2008 | Porter Cable Porter-Cable 309 Factory...
Hitachi M12V2 3Router Logo
136 people viewed this question
Top Hitachi Tools & Hardware - Others Experts
John Trevino
yoopertech
bwbconstruct
Level 1 Expert
Are you a Hitachi Tool and Hardware - Other Expert? Answer questions, earn points and help others
