Question about HP Pavilion Elite M9060N PC Desktop
HP elite 9152p
I want to remove the drive tray to replace the sata drives.
    Sergeant:
  • 221 Answers
Here is a link to the service manual for your computer. It contains step by step information on how to replace every component in your computer.
http://h10032.www1.hp.com/ctg/Manual/c01152947.pdf
Posted on May 04, 2008
How to get device manager to recognize SuperMulti DVD Burner? The player is installed (or was) and worked, but it suddenly vanished from device manager.
You should open the case and see if the power cable and sata cables are secured on the drive..... it is possible that the DVD drive control board has died. Considering there are many DVD burners out there for less than $20 the replacement should be cheap and simple.
Here's how to open and replace a CD/DVD drive from the HP site:
http://support.hp.com/us-en/product/HP-Pavilion-Elite-e9000-Desktop-PC-series/3999455/model/4007356/document/c01761233/
May 19, 2014 | HP Pavilion Elite e9260f (2531370) PC...
Boot failure after power supply replacement
It sounds like its not detecting the hard drive, I would check your power connection and the sata cable that connects the hard drive, you might also trace the sata cable to the board and make sure its completely seated to the port. It might have came loose when you had it apart replacing the PSU
Jan 09, 2014 | HP Pavilion Elite M9600T Desktop PC with...
Hard disk removal
On a desktop computer WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the power lead from the power in put on the computer remove the side panels on on our computer you will see 4 screws 2 either side unscrew these then remove the electrical lead and the sata lead remembering where these are located slide the hard drive out then put your new sata hard drive in placing the leads back to there original position then tighten the screws (do not overtighten) http://www.ehow.com/video_4978913_install-internal-hard-drive.html YouTube video install a second ide hard drive http://www.fonerbooks.com/laptop_1.htm laptop hard drive http://www.ehow.com/how_5451891_remove-hard-drive-ibm-notebook.html Hope this helps. http://compreviews.about.com/library/weekly/aa-diy-motherboard.htm http://compreviews.about.com/od/tutorials/ss/DIYMB.htm How To Replace HP Pavilion Desktop Hard Drive http://www.youtube.com/watch?v=5Cn1N04q804 Hope this helps.
Dec 31, 2012 | HP Pavilion Elite m9426f Desktop
How to remove and replace dvd rom and dvd rewrite in hp m9300t
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3771771
1) Computer off, computer unplugged from power, open the computer case,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01176770&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3771771
FOLLOW Anti-Static Precautions:
2) Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
3) Remove the Front Cover,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01176823&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3771771
4) Removing and replacing a CD/DVD drive,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01176843&tmp_task=useCategory&cc=us&dlc=en&lc=en&product=3771771
The HP Pavilion Elite M9300t Desktop PC, is supposed to come with a SATA type of DVD R/W optical drive, and a SATA type of DVD drive, (Unless you have Bluetooth types of optical drives, of course),
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01492741&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=3771771
This means they use a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note the L-shaped opening. Lines up with the L-shape on the optical drive power connector.
Note that there may be a small lock tab on top, that you depress on the SATA power cable's connector, in order to remove it from the optical drive.
(Some SATA cable connectors have it, some do not. Referring to power cable, and data cable)
The SATA power cable has 15 contact pins. Between it, and the SATA data cable, it has the longer connector.
This is a general example of a SATA data cable's connector.
7 contact pins,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
(Top photo)
Here you can see the L-shaped opening more clearly.
When you are finished make SURE all cables are connected in tightly, on the inside of the computer. Sometimes when replacing hardware they get bumped loose.
Also make sure the Ram Memory module/s ('Stick'), are plugged in tightly. They also get bumped. Doesn't hurt to push down on them/it in the ram memory slot. Also make sure the Locks on each end of the Ram Memory module is locked in towards the Ram Memory module.
When the Locks are engaged, the Ram Memory module is properly seated.
For additional questions please post in a Comment.
Have questions about anything in the HP links, post in a Comment.
Regards,
joecoolvette
Jul 26, 2012 | HP Computers & Internet
I want to replace/install 1.5TB drive in HP Elite Desktop, HOW?
The beauty of SATA is just that,you can definitely do what you have in mind
Mar 23, 2010 | HP Pavilion Elite M9150F Desktop PC
F7 hard drive problem the PC has two 360 gig hard drives. Which one is the primary? Will a WD serial # WCAV 5463220018 3.5 inch SATA hard drive 1000 Gbyte be compatible with my PC?
If your PC has SATA connections yes you can use SATA, but not a SATA 2.5 which only fits a laptop! When you use 2 drives one must be set by jumpers on rear of drive to master..... the slave drive (2nd hard drive) must also be set to slave by same jumpers.
Dec 23, 2009 | HP Pavilion Elite M9150F Desktop PC
Replacement drive for HP DV5000
As per HP, the maximum capacity of Hard Drive shipped with dv5000 series Notebook is 100 GB 5400 RPM SATA Hard Drive.
The Specifications of the Hard Drive compatible with your Notebook are SATA 5,400RPM, 2.5in width, 9.5mm height.
However, you can install a maximum of 160 GB SATA Hard Drive in your Notebook.
You can purchase the reqired Hard Drive for your Notebook from the link below :
http://bixnet.com/12insanohadr.html
Find the requied instructions to remove and replace the Hard Drive in the Notebook from the Manual of the Link below :
http://h10032.www1.hp.com/ctg/Manual/c00700932.pdf
Please go through page number 98 of 260 in the Manual to find the required instructions.
Hope this helps....
Nov 29, 2008 | HP Pavilion dv4000 Notebook
Hoow to install a dv2000 hp pavilion dvd rw drive (internal)
Remove the Phillips PM2.5x7.0 screw (1) that secures the optical drive to the computer
Insert a thin tool, such as a paper clip, into the media tray release hole (2). (The optical drive media tray release from the optical drive)
Use the media tray frame to slide the optical drive (3) to the left.
Remove the optical drive.
ce642a5.jpg You can download the complete manual here:
http://h10032.www1.hp.com/ctg/Manual/c01035657.pdf
Jul 22, 2008 | Compaq Pavilion ZT3280US Notebook
HP Pavilion Elite M9060N PC Desktop Logo
248 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
