Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
I read among your "unsolved problems" the same one I have. I have a Poulan 331 string trimmer, and the pull rope is broken. I have it disassembled down to the drum assembly, but I can't get that off to remove the plastic casing to get to the spool to put a new cord on. How do I do that?
  • 183 Answers
In the center of the drum (where the drive cable goes) is a torx screw. Usually it is a size T15 or T20. You will need a way to lock down the cylinder. If you don't have a cylinder lock, remove the spark plug, lower the piston down, fill the chamber with a long piece of clean rope or tubing (leave some sticking out), then raise the piston to lock the cylinder. The screw in the drum turns counter-clockwise to remove. After you get the drum off, then you will need to remove the clutch. It also turns counter-clockwise to remove. Use large slip-joint pliers on the clutch. DO NOT REMOVE THE OUTER PART OR SPRINGS FROM THE CLUTCH. They are very tricky to get back on. With the clutch removed, the rest should be relatively easy.
Posted on Aug 23, 2010
My weed eather is frozeen and pull rope wont move to start
unfortunately it's time to trash it and buy a new one. it would cost more to fix that one than to buy a new one
Jul 16, 2012 | Poulan 25cc 2-Cycle Gas Powered String...
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Fuel mixture for poulan pro heavy duty brushcutter 331 sn 01254n500330-1is needed asap. lost my manual!!!!!
40:1 mix, 3.2 oz of 2 stroke oil for every gallon of gas.
Link to the manual is below
http://www.poulanpro.com/ddoc/POUO/POUO2001_USen/POUO2001_USen__530088910.pdf
May 27, 2011 | Poulan Pro Pp125 25cc Gas Straight Shaft...
How to repair a poulan pp 136 trimmer? The rope to start won't rewind.
Most likely you have a broken return spring.whitch will involve removing the blower cover and putting in a new spring,and then reloading the tensionon it.there is trick to that but its hard to explain....you have to tuirn the rope holder the oppisite direction you want it to pull the rope in ,then you feed in the rope while holding the spring loaded then tie the string in and let go...Normally 4-5 rounds will do for a good recoil..Hope it helps
Aug 27, 2010 | Poulan Garden
When i tried to pull the starter string it wont come out.why?
The starter/recoil design for these machines isn't the best. Sometimes the pulley the rope is in binds up...sometimes the rope will catch a notch in the pulley (the rope pulley is plastic)..and sometimes the crankshaft bearings in the engine become loose and worn and the alignment for all the parts on the shaft is skewed. This includes the flywheel and the clutch and the flexible drive shaft and the starter recoil unit. You will have to disassemble to get down to the heart of the problem.
Aug 26, 2010 | Poulan Garden
Starter rope will not retract
Either you have a broken rewind spring, or the starter mechanism is dirty to the point where the force of the recoil spring is not sufficient to pull the rope back in.
WEAR SAFETY GLASSES while disassembling your starter mechanism to see what the problem is. Upon reassembly, it is a good idea to lube the post in the starter housing (the one the pulley slides over) with some graphite or teflon lube.
Oct 25, 2009 | Troy -Bilt String Trimmer/Blower...
How do you change the pull rope on a poulan 31cc gas trimmer
You have to take the unit apart. Seperate the shaft from the engine. Then take the engine off the back side. This will allow access to the starter spool, where the rope goes. If you get that far, be careful when you wind the spring. Good luck...Lee
Sep 25, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Replace pull cord Big Wheeled weed EaterString
First, remove the recoil assembly but dont disassemble!
You'll need about 3 1/2 ft. of the same size rope. Tie a knot into one end of the rope. While holding the pulley in place observe the direction the pulley moves when rope is pulled. Release pulley and cut and remove old rope. Continue winding pulley in direction rope would pull it. Do no wind too tight. Line up holes in recoil housing and pulley then push rope through pulley and out housing. Tie on handle and install recall in reverse order.
Jul 02, 2009 | Garden
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
124 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
