Question about Ovens
Manual for GE oven Model # GRML3500SW-1 - Ovens
Ge double oven f1 error model jkp55wot1
F-1 error code.
Sometimes one or more buttons on the touch panel "get Stuck"
Nothing you can do to reset them, Good Luck.
Many times it means the touch panel needs to be replaced.
Jul 09, 2014 | GE Profile JTP56 Electric Double Oven
Installation instructions and manual
Most of the installation manuals for GE appliances are available on their support page: http://www.geappliances.com/ge/service-and-support/literature.htm . I found several double wall oven models with the JKP27 designation. However, the G0J4BG does not fit as part of the model number. There should be 4 letters after JKP27 in the model number. These letters primarily indicate the color of the exterior. For the JKP27 models, the installation manual says that the cut-out should be 32 1/2" above the floor. The depth has to be 23 1/2". The cutout width should be between 25" and 25 1/4" (these are an absolute minimum and maximum). The cutout height should be between 27 5/8" and 28 1/8".
The direct link to installation manual for one of these ovens is here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=003675840.PDF . See page 6 for the cut-out dimensions.
I hope this helps.
Feb 05, 2018 | GE JKP27 Electric Double Oven
GE electric oven won't stay hot
Google GE electric oven Model number: ? Manual
Jan 15, 2018 | GE Ovens
Looking for an Owner's Manual for a GE Electric Single Wall Oven Model # JKP2OBOF3BB.
I do not see the JKP2OBOF3BB among the GE appliances. The manual for the JKP2OBFBB 27" Single Wall Oven is available here: http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-80475.PDF . Most GE appliance manuals can be found by searching here: http://www.geappliances.com/service_and_support/literature/ .
I hope this helps.
Mar 26, 2011 | Ovens
F7 E6 won't go away on my Ge Trutemp oven
Call GE answer center 1-800-626-2000 ask for tech help.
Have Model # off your data plate ready.
May 09, 2009 | GE JKS05 Electric Single Oven
How to self clean
Depending on the condition of the oven, it could take up to 4 hours.
A couple things to remember is: (1) Make sure you do not turn the light on inside the oven. The clean cycle should disable it. (2) Lock the door if it does not lock itself. (3) Do not open the door during the clean cycle.
Remember the self cleaning temperature is extremely high. Do not allow children in the area while doing it.
Here is a link for your stove:
GE JTP18 Manual
Directions are on page 23.
Dec 13, 2008 | GE Profile JTP18 Electric Single Oven
Ovens Logo
112 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
