Question about Blenders
As soon as liquid is added it leaks. leak is in base plastic part or seal.What do you recommend?
  • ian_mills290 Aug 31, 2010
    Somehow left out - its a Krups 577 that cost £120, so not cheap hence my wanting to repair
    if possible.Do you know who stocks replacement parts?? Thanks
    Ian Mills
  • 1,675 Answers
Hi, depending on what model you have most of them are not replaceable as these are seen to be so cheep that it would probably be cheaper to replace with a new one than to get it fixed, as i said this depends on what model you have, it normally isn't the seal that has gone but the bearing that the seal covers, if this goes then you may as well throw it away and get a new one...sorry to say.....please vote and rate thanks
Posted on Aug 23, 2010
  • steve morris
    steve morris Sep 01, 2010
    hi ian
    there is one company here in the uk that carries spare parts for krups models, at the moment they say they are out of stock, i can supply the phone number for you if this will help you any, i do not know if you are UK based or USA or other, so the best i can do is give you the UK number for this company...
    0121 200 2740.
    the company is called britcom uk ltd
    the web page is
    http://www.werl.co.uk/index.php?content=...
    hope this helps please can you rate thanks
What can I do about my Vita-Mix Blender which leaks at the bottom?
You will need a special wrench to remove blade assembly.
then the gasket/seal is inexpensive.
you can check here:
Contact Us Customer Service Vitamix
or check here:
Vitamix Wrench
Apr 25, 2014 | Vitamix 34000 Blender
Burning smell in the container and outside when in use
Seal under blade Assembly, on shaft leaks, allows liquid to enter bearing, which then fails, creates heat and overheats rubber, thus the smell. Bearing and seal must be replaced.
Jul 11, 2012 | Breville BBL600XL. 5-Speed Blender
The plastic base the blades are fitted in ,cracked need to order replacement
the part is Black and Decker Blender Base Collar Ring BL5000-11
However these are prone to cracking. I ordered a second after my first cracked, and the second one cracked after just a couple uses.
Jun 09, 2010 | Black & Decker BL1900R Blender
Rubber washer for Model TSK-9368AP Blender
I just fixed mine with a rubber hose washer. I had to cut the washer in half because it was too thick, but it stopped the leak!
Mar 29, 2010 | Blenders
My Cuisinart blender start leaking after a few months of use.
Here is a list of things to check for:
1. Make sure the blender base (black plastic) is tight to the jar.
2. Make sure you have installed the rubber washer between the blender blade assembly and the jar.
3. Make sure your rubber washer is free from any crud that may have accumulated and dried on. You may have to soak the washer and gently scrub with a scrubber sponge. If it's really cruddy you may have to repeat as necessary.
4. Make sure you have not caught any water (or other liquid) when filling it between the base and the jar. When you pour out the contents it will appear as if it is leaking.
Mar 22, 2010 | Cuisinart BFP-703 SmartPower Work Top...
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Oster 6700 Gasket O-ring leaks
Gasket is not the problem.
Square shaft that is pressed into the turning gear is not tight and allows leaking through the connection.
Only repair is to replace the assembly with the gear drive, blades, etc. and this will take care of the leak. The "O" ring gasket is fine and holds the liquids. However the leak is around the center of the shaft that goes through the bottom.
Regards,
Gary
Jun 06, 2009 | Oster 6700 Work Top Blender
Broken Part
Hi, i read your are having trouble with the tap on your blender. We pulled our blender out of the box and used it for the first time and it leaked through the base, through the motor all over the bench top.
At first i thought the tap was leaking too, then I investigated a little bit and found it was leaking through the white tension clips on the inside of the black base.
Then i discovered that there is a recess for an "O" ring, which seals the glass jug to the black base thus solving the leak.
However there was no "O" ring in the recess and now I am trying to find a replacement one.
Hope this helps.
May 22, 2009 | Russell Hobbs 3902US Work Top Blender
Base leaks heavily when any liquid goes in!
make sure the seal gasket is between the base and the blade base- 99% it will solve your problem!
Aug 27, 2007 | Tefal MagiClean Work Top Blender
Blenders Logo
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
