Question about Compaq Presario R3000 Notebook
Presario r3000 shuts down
Hello,when I run the presario r3000 on the batterie there's no prob...whenever I plug the power cord, I intermitenly hear the fan reving really high and then the laptop shuts down. I have just formated and installed win xp corp and all drivers. Unfortunately I don't see any solution on the page I was reading, would it be possible to post a link to the solution please. Thx for your time
I have experienced similar problems. I found that if the fans were REALLY dirty, the system would overheat and shut down with no warning.
Posted on May 06, 2008
My Gateway 7405 randomly shuts down. It does not matter how long it has been running for. It has shutdown during bootup and after running for many hours. Just before it shutsdown the fan accelerates to...
You might try changing the Power Options (its in the Control Panel) Properties so that all windows are set to NEVER. That is, so that it will never automatically turn off monitor, hard disks or go to standby. Also turn off all the alarms. This worked for my Presario R3000 running WinXP Sp2 which would shut off for no apparent reason. Having said that, you should blow out your fan with compressed air occasionally. And check that your power cord is OK. When you pull out your power cord, the battery icon should show operation.
Feb 12, 2011 | Gateway 7405GX Notebook
Power cord has to be held inat an angle to run and
I would suggest it`s a bad solder connection to the board on your laptop or a small break inside the power chord wire right at the neck of the wire plug.If you can find an identical notebook to try the plug in...that may narrow your problem as to the power chord or the notebook plug,good luck:)
Apr 11, 2010 | Compaq Presario R3000 Notebook
Intermittant power when using the power cord.
yup probably the power cord. try replacing a new one if you have or try borrow from your friend just to test if the problem is really in the power cord
Dec 07, 2009 | Compaq Presario R3000 Notebook
It keeps turning off, I have tried my friends power cord incase that was the problem but even with her cord it turns off, and just before that says that I need to plug the charger in even though it is...
ok sounds like your battery has gone bad.
try this test: remove battery plug computer into the wall.
boot computer if it boots up and stays on you will need a new battery.
Nov 13, 2009 | Compaq Presario R3000 Notebook
My r3000 has a tempermental power supply. it
whatabout the lead that plugs into the laptop ? does the plug in the laptop move easily, with the lead in, Sounds like the actual plug in the laptop is breaking away, the solder around the connector. Sadly to fix that you will have to get it repaired for about £50 to £70, maybe more ?? please make sure the lead from power supply is not loose or a bad fitting.
Jun 14, 2009 | Compaq Presario R3000 Notebook
Laptop keeps losing power at start up and shuts down repeatedly
does it run with the power cord plugged in? if so your batterys dead, otherwise harddrive/bios/motherboard fault? is your power supply charging the battery?
May 09, 2009 | Compaq Presario R3000 Notebook
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Compaq presario R3000 Laptop power and fan problems
Your machine is overheating. Try cleaning the vents with a can of compressed air and making sure the heat sync is free of dust. If that doesn't work, you may need to replace the fans.
Jun 07, 2008 | Compaq Presario R3000 Notebook
Compaq Presario R3000 Notebook Logo
281 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
