Question about Fedders Heating & Cooling
My unit is a A6V10S2B and is making a very loud noise, had to shut it off
    Genius:
  • 1,478 Answers
There are many reasons why an air condition produces noise. Sometimes loose hardware is the culprit. Air conditioner noise could be caused from the refrigerant tubing that has a bend in it that produces rattling because it's too close to other parts of the air conditioner.
You can correct this by carefully bending it back into it's original place. Take a look at the unit and see if there are any loose parts that could be banging around causing the noise. It may be the fan blades have gotten bent over time. To remedy this simply bend them back to their original position.
Is you portable air conditioner mounted properly in the window? While the unit is making noise and rattling carefully apply pressure to the window sash and listen for any changes in the sound. This can be remedied by inserting shims between the air conditioner frame and the sash. Another good idea is to check the screws on the front panel of your air conditioner. If loose they'll need to be tightened.
There may be more serious problems that would require a service technician such as compressor issues. Refrigerant floodback occurs when the liquid enters into the compressor crankcase. This noise would usually occur when the compressor starts up. Another issue could be oil leaks causing a low oil level in the compressor but it would probably be pretty rare.
Check the front cover to ensure it is snug and not loose. The front cover can be noisy if not put on correctly. If the prongs are broken and the front cover will not fit snugly one can use tape here as well to quite it down.
The air filter when dirty can cause a restriction in the system which can cause the unit to freeze. This in turn can cause melting water to hit the fan and become quite disturbing. Keep the filter changed on a regular basis to prevent this from happening. This can happen too if the drain is stopped up. The solution for this is to unstop the drain or drains in the air conditioner with a pipe cleaner.
Check the fan that is located inside the air unit. Make sure the fan turns freely without hitting the sides of the unit. Simply take the cover off and turn the fan by hand. The fan should spin freely and unobstructed.
Air conditioner fans seem to attract all kinds of debris and sometimes it is a mystery as to where it comes from. General maintenance of this item would be to check it once a year before start up. It is a good ideal to keep logs or checklists for mechanical items in ones home.
Take care.
Posted on Aug 23, 2010
My unit outside is working fine but it is making a lot of noise. All my neighbors are telling me that this is not normal. What can I do to reduce the noise. It is spinning fine but it makes loud noise.
Is the condenser coils clean..... If not take a hose and wash the condenser coils But make sure you shut the Main power off to it. Has the unit been charged with Freon lately??? If so they may have gotten it overcharged which will cause High head pressure and make the compressor noisy..... Or is it out of level and not setting on a stable surface. causing a vibration noise. You can put rubber pads under the AC if it is a vibration noise...... Also the Compressor may be going out..... It is hard to tell with out hearing it first hand....Hope this helps If you can't get it to quite down I would setup a Service Call to have them Service the AC and that you are having a loud noise coming from the unit....
May 05, 2011 | Goodman CLT48AER48 Air Conditioner
The unit makes a noise. sounds like a pressure relief when the unit shuts off
If this is a heat pump when the unit shuts down it de-energizes the reversing valve causing it to shift and make a loud swishing noise, which equalizes the pressures causing that sound.
If it's an air conditioner you are probably hearing a pressure flow thru an orifice or a txv opening.
Jun 29, 2010 | Heating & Cooling
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
it sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Nov 17, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Fan noise loud, bulb burst. Replaced with new bulb. Noise even louder! Unit shuts itself off.
the bulb may have burst from overheating from a fan not working to cool it down. and it can be replaced. it does take, however, a while to replace it because you have to take half of it apart. but make sure it's the fan first. take the lamp door off and remove the lamp. use something small and thin to push in the switch that the lamp door usually activates. turn the projector on and see if the lamp fan and the colorwheel (the multicolor glass disk) are spinning. if the fan spins, the noise may be from the colorwheel motor going bad. the fan can be purchased through an infocus authorized service center. check the website for the closest one. but the colorwheel for the x1 cannot be purchased seperately from the optical engine, and that costs a fortune. but here is the part number for the 80mm fan- 526-0152-00.
May 23, 2009 | InFocus X1 Multimedia Projector
Brand new unit, compressor noise.
Since I could get no one to tell me about new freezer compressor making buzzing noise while on, I had the store come a pick it up and give me my money back.
Apr 28, 2009 | Frigidaire 12.8 cu. ft. Chest Freezer...
Frig makes a very loud booming noise/ratteling what is the cause?
The noise is coming from the compressor and is a result of a broken support spring inside the compressor. When the unit shuts down, the inner casing rattles against the outer casing because the spring is not there to keep them apart. The only fix is to replace the compressor but otherwise it is just bothersome.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Refrigerators
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Sub makes loud noise when car is shut off
Does it make noise if the RCAs are unplugged? If not, the RCA shield on your head unit may be burned open.
If the amplifier is set to signal sense, it will take longer for the power light to go off.
Nov 13, 2007 | Jl Audio 250/1 Car Audio Amplifier
Heating & Cooling Logo
65 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
