Question about Hoover Dryers
I need to know how to work the hoover six autostop electronic condenser dryer
  • 249 Answers
SOURCE: hoover family load condenser dryer hdc7fm
maith a colleen] throw stale water out of dryer tray, and run dryer again.eire good luck
Posted on Dec 09, 2007
  • 1462 Answers
SOURCE: hoover six tumble dryer runs
usual cause is water being thrown by the fan onto the heater. after this has happened, remove cover over heater and see if water is present.
the water is there because the water path from condensor box to pump housing is blocked with lint
Posted on Sep 18, 2008
rogrrabbit
  • 986 Answers
SOURCE: Hoover Condenser Tumble dryer HSC 170 not heating up
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Nov 27, 2009
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
SOURCE: Hoover condenser dryer VHC180. Water empty
hoover dryer water leaks when machine is running.
Posted on Jan 26, 2010
Hoover tumble dryer - condenser wont fit back in?
I would need to be there to see what you have going on, sorry,.
Sep 28, 2016 | Hoover Dryers
Could you tell me where the thermal limiter is situated in a DYC8913B please
Ian, Did not find your particular model, links below may help in changing and testing your thermostat.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Condenser Dryer Model No DYC 8913B Product Code 31100391
Hoover DYC8913B 80 Thermal Limiter
Dryer Isnt Heating High Limit Thermostat Testing Dryer Troubleshooting...
How to replace thermostat on tumble dryer how to diagnose the fault
Apr 24, 2016 | Hoover Dryers
Hot point ariston aqualtis condenser dryer fault code f07
F07
Heater relay stuck
Check wiring
Check electronic control PCB
Jun 21, 2014 | Hoover Dryers
My Hoover HD condenser dryer won't give out any
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 19, 2011 | Hoover Dryers
Dec 05, 2009 | Hoover Dryers
Dryer will not start
If it isn't the motor starter capcitor could be a winding burned in the motor. I would replace both together and be done with it.
Mar 25, 2009 | Hoover HDC6 Electric Dryer
Hoover six tumble dryer runs for about 15 minutes then trips the electrics, condenser has been cleaned and water container is always emptied
Sep 17, 2008 | Dryers
Hoover family load condenser dryer hdc7fm
Nov 10, 2007 | Hoover HDC7FM Dryer
Dryers Logo
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
