Question about Haier hwr10xc6 Air Conditioner
My air conditioner frezzses up sometimes. i got it tilted down on back side.some water drips out .but i wonder if i should take a plug out to let more water out to keep from frezzing up.
  • 674 Answers
The freezing is caused by too little airflow over the evaporator coil or a low refrigerant charge. Make sure your air filters and the evaporator coil and condenser coil are clean. If the charge is low it may be cheaper to get a new unit than to charge an old one.
Posted on Aug 23, 2010
Water flushed from unit inside the room instead of beeing flushed outside throw the out let pipe
Possible that the tilt is more to the front that makes the water drip down. Another reason is that the drain pipe can be clogged with dirt build up and so it flushes back.
Finally if the evaporator is dirty and clogged due to dirt accumulation the water might drip down to the front.
So please check you filter, use high pressure air on to clean and reset the panel.
Aug 27, 2011 | LG LSC121PMA Split System Air Conditioner
Portable haier air conditioner drainage. Cannot find drain hole and unable to tilt ac. Water is building up in the bottom of unit.
Here is a thought, received by me from a AC mechanic recently. Window ACs no longer actually drain concensate. Rather, the water is caught in a pan with the idea it will evaporate back into the outside air. The reason for this is the dripping water frequently resulted in the growth of algae below the unit resulting is unsightly stains and sometimes, slippery conditions. Evidently, there were a lot of complaints about being 'dripped on' also. So, AC manufacturers don't put drain holes in the bottom any more. If the pan over fills, it will spill out of many makes. If you want yours to drain, put a hole in the bottom.
Like I said, just a thought.
Thanks for your question @ FixYa.com
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
My air conditioner is leaking water from the front side just below the control panel....what is causing this?
2 things generally cause this.
1. The rear of the unit is not tilted down enough for the water to flow to the drain hole in the drip pan.. 1/4' to 1/2" tilt is the general rule of thumb.
2. The drain hole at the rear of the drip pan is clogged and needs to be cleared. It can be hard to find, as the clog will blend in with the drain. Use a pipe cleaner to clear the clog.
Hope this helped you to troubleshoot and solve the problem. Thanks for choosing FixYa.
Aug 02, 2011 | Fedders AER08F2A Air Conditioner
I was wondering where the water goes or if it carrys any water at all. it is a window air conditionor
On a window a/c unit, the water drips outside, so be sure the unit tilts downwards as it goes out. The water is from condensation, sometimes you will get lots, other times almost nothing, both normal, related to actual relative humidity. The water forms due to temperature, it forms exactly like water on the outside of a glass of ice water...
Jul 06, 2011 | Fedders A6P09S2A Air Conditioner
Why is there no drain hole for condesation to drip out?
Some of the Friedrich units will drip out in the back of the unit. There may be just a small bend in the base of the unit allowing a certain amount of draining just behind the rear coil. Most units require some water to remain in the back of the unit to help cool the unit off. This is why tilting in the window is important. Be sure not to tilt it too much or too much water will drain, causing the unit to overheat. Be sure to tilt it enough to where the water can drain properly or the water may drain in the house, down the wall.
Jun 20, 2011 | Friedrich CP18F30 18000 BTU ThruWallWindow...
Water is dripping into the house from the brand new air conditioner
Make sure the window unit is tilted back. If its not tilted back in the window, it will drain out the front.
Jun 20, 2011 | Haier HWR08XC7 Air Conditioner
Window air conditioner..
It is normal there is a small hole for the water to escape just make sure that when you mounted it you tilted it down a small amount at the back so it can drip out
Jul 22, 2008 | Heating & Cooling
Condensation causing water collection
Hi there!
Make sure the unit is level and not tilted forwards.Tilt back if anything.
There should be a drain hole at the back, but it may be clogged, or there may be an obstruction causing the water to build up.
In times of high humidity, water will condense on the cooling coils, and drip off. This is usually carted away by means of a tray flowing to an outside pipe.
One design uses a flinger to catch any water and throw it onto the evaporator coils - thus improving efficiency, but if there is anything touching the coils, like a feather etc, it will flow down that and leak.
Tip it back as the first action, then investigate if it doesn't drain.
Jul 06, 2008 | Samsung AW0503B Air Conditioner
Haier hwr10xc6 Air Conditioner Logo
62 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
