Question about Xerox 5665 Copier
I haven't access to xerox 5665 via web. - Xerox 5665 Copier
  • yury_kuznets Aug 23, 2010
    Https is disabled and I can enable it via web interface only )
  • 3 Answers
You have to enable HTTP protocole from machine user interface by entring in administrator mode.
good luck
Posted on Aug 23, 2010
  • 1 more comment
    HTTP protocol is enabled. IP address is static. I can ping machine. but haven't access via hhtp.
  • fouadkassi Aug 23, 2010
    chek if the SSL is enabled, if yes tapehttps://ipadress
  • fouadkassi Aug 25, 2010
    sorry for delay, can you activate SSL via UI and try to logon via web withhttps://ipadress?
What is the procedure for dismantling a Xerox 5665 developer unit which is faulty?
That unit is a consumable, you're not supposed to dismantle it.
Dec 18, 2014 | Xerox 5665 Copier
What is a ROS system Failure
ROS stands for Raster Optical Scanner which is the scanner head/lense. This will need some cleaning from time to time depending on how much it is used. consult the printer manual on how to clean it.
Aug 06, 2014 | Xerox Office Equipment & Supplies
How do I get rid of the annoying fault code 07-515.00 The Bypass Tray is empty.
I HAVE A XEROX XC1045 CAN YOU SHOW ME THE SYMBOLS THAT COME UP SO I CAN ASK THE QUESTION ON THE SYMBOL IT LOOKS LIKE A CHECK THE PRINTER WONT PRINT
Apr 30, 2010 | Xerox 5665 Copier
XEROX INSTALL PHASE INCOMPLETE
You needto specify model i have come accross this in 5665 series when board have been replaced there are several dip switches wich indicate the speed of your machine
Dec 30, 2009 | Xerox Office Equipment & Supplies
Where is 3 hole paper punch reservoir
Here is a link that should show you where it is. Just be sure to completely insert it when you replace it.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=23,E=0000000001733360921,K=3118,Sxi=5,Solution=obj(12576)
Oct 15, 2009 | Xerox 5665 Copier
Fault code problem whit xerox 5665
This sounds like a fuser problem, underheat or over heat. On this machine also, it might be related to NVM, or NVM memory corruption. Sometimes the batteries on the Main Board, they just get old and die.
This can be a multiple problem on the machine.
This might require a Xerox service person to visit the machine.
Some ideas are: A bad heat sensor(Thermistor), very fragil and brittle.
A NVM might need to be reset, Over heat or underheat code in the diagnostice service mode. You need a service manual to find it.Very complicated to explain.
A full sump bottle can cause this, the machine enters a code in the NVM and will keep the machine from "Logicly turning on." Or a broken full sump bottle, sensor falls off or not in place will cause the machine to enter a error code in the NVM.
Good luck.
Apr 03, 2009 | Xerox 5665 Copier
342 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
