Question about Kenmore 62602 Electric Dryer
Kenmore 90 series electric dryer
Turn knob to select setting, click start, it clicks like it wants to start, but it doesn't start
  • marycbabe Jan 05, 2009
    Not the door switch. Where do i find the motor start relay ?
    Problem Solver:
  • 14 Answers
Check the door swithch first.. won't start if its shot....
tthen look to motor start relay...??
Posted on Jun 13, 2008
My Kenmore series 90 Gas dryer doesn't heat up.
This dryer is what I like to call a 4 wheel drive model. Because it has wheels on the front as well as the back. To access the gas assembly you pop open the bottom panel. Strat the dryer and observe the gas assembly. You should hear a click and then the ignitor should glow. Next the flame sensor should trip and cause the ignitor to shut down. The gas will now be allowed to come out and fire off a blast.I have 2 home videos. on shows the operation and replacement of the coils. The other is of an electric model but shows how to put the dryer together.
Sep 21, 2012 | Kenmore 73052 Gas Dryer
Kenmore 90 series electric dryer qiuet pak 1 101649022200 the lights are on when you open the dryer but the dryer itself will not turn on or do anything!
There's thermal fuse on the blower that blows when the cycling thermostat malfunctions or the lint/vent duct are blocked. This thermal fuse is wired in series with the dryer motor and if it blows, power to the motor is terminated causing the dryer not to start and no dryer function works. Check to make sure that the lint filter is always clean and the vents are clear. Click on the link below for the detailed troubleshooting of the dryer, particularly the thermal fuse, when it doesn't start.
Troubleshooting Not Starting Whirlpool and Kenmore Dryers with Lint Filter on Top
Feb 09, 2011 | Dryers
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
Kenmore series 90 dryer(5 years old). Power ok
have you checked the start button?
Jan 30, 2010 | Dryers
Dryer will not turn on although the timer is working
IF your hearig a click when you push the start button then the button and relay are good check the saftey switch on the door to see if it has come loose and follen down or moved back if the switch is not pressed the motor will not work also I have seen the switches go bad you need to unplug the dryer and cross the too wires togeather plug the dryer back in and press the start button if she starts order a new swith. The motor could also be bad you nees to remove the back cover and check to see when the button is pressed if you are getting the correct voltage you will need a volt meter to check this they cost around 10- 20 bucks if you have correct voltage from the wires and the conections to the motor are ok the motor is no good and needs to be replaced hope this helps...
Jul 07, 2009 | Kenmore Dryers
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
There is a clicking sound when you press start.
If you heat a click when you push the button,but the drum doesnt turn your belt is broken. About $15 and simple to install.
Oct 20, 2008 | Kenmore 63942 Dryer
Kenmore 62602 Electric Dryer Logo
301 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
