Question about Minolta EP1083 CS/PRO Copier
I am working on minolta ep 1080 copier and the drum is bad, how do l replace it, or how do l replace the cleaning blade
  • 40 Answers
If you dont have any idea about how to change drum and C.blade please dont touch it because maybe you break it again or scratch drum
Posted on Sep 01, 2010
SC23-14 FOR BIZHUB 1050 KONICA MINOLTA
Drum motor failure to turn.
There may be foreign material in the drum unit locking it up. Also possible motor failure or board failure.
Mar 10, 2014 | Konica Minolta DEVELOPER - BLACK - 120000...
Minolta cs pro ep 1085 errore code c0010
Sir/Mam the Drum Motor is failing to turn the drum it self mite be jammed. Not allowing the motor to turn . Remove the drum cartridge. And see if you can turn the drum with your fingers DO NOT TOUCH The color part of the drum turn by both thumbs on the edge of the drum TURN CLOCKWISE if you turn Counter clockwise you will flip the cleaning blade that is not good. The cleaning blade removes the old toner before the new image is placed on the drum if it looks yellow then get a new one and replace it. IF you think the drum is stuck to the cleaning blade then for about a half inch push the drum counter clockwise the then clockwise. Also might remove he drum to see if its jammed. Also the motor might be bad or the circuit board that replaces it.
Nov 23, 2013 | Minolta Office Equipment & Supplies
I have a minalta cs pro ep 1085..when I tried to take copy the paper jumed and errore code apeared (c0010) ,, any help will be greatfull
Sir/Mam the Drum Motor is failing to turn the drum it self mite be jammed. Not allowing the motor to turn . Remove the drum cartridge. And see if you can turn the drum with your fingers DO NOT TOUCH The color part of the drum turn by both thumbs on the edge of the drum TURN CLOCKWISE if you turn Counter clockwise you will flip the cleaning blade that is not good. The cleaning blade removes the old toner before the new image is placed on the drum if it looks yellow then get a new one and replace it. IF you think the drum is stuck to the cleaning blade then for about a half inch push the drum counter clockwise the then clockwise. Also might remove he drum to see if its jammed. Also the motor might be bad or the circuit board that replaces it. Hope this works for you
Hope this works for youH
My minolta ep 4000 copier prints with thick black streaks imprinted on page. what's wrong? is it the corona, the drum, or something else?
Most likely it is the drum cleaning blade. One indicator of the drum cleaning blade going bad is that the black lines will get worse as you run multiple copies. So if you make 10 copies for example, the last copy out will be streaked worse than the first copy out. Drum cleanig blades are about $30 bucks plus whatever your local service guy charges for a svc call.
Good Luck and Thank You for using Fixya.
Jul 21, 2010 | Minolta EP4000/5000 CS/PRO Copier
Minolta ep 1080 copies have vertical grey stripes with a white halo around the text
You need a drum cleaning blade. This blade cleans the drum between copies.
You can verify this by opening the "clamshell" or lifting the top half of the machine like you do when removing a paper jam. Then look under the top half of the machine on the inside. You should see a reddish or greenish colored cylinder called the drum. It is about in the middle from right to left. If you see the same black bands on the surface of the drum as you do on your copy then the drum cleaning blade is bad.
This cylinder should normally be clean.
Good Luck.
Nov 18, 2009 | Office Equipment & Supplies
I have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
Oct 12, 2009 | Minolta EP1031/1031F CS/PRO Copier
There are black spots and lines on my paper when I
Clean the optical section(mirrors,lens,glass).Remove tje IU unit,change the OPC drum cleaning blade and clean the drum,charge corona and transfer/separator corona,after perform F5.
Sep 25, 2009 | Minolta Office Equipment & Supplies
Minolta EO 1080 Copier-Error Code C05
Did you do anything to the fusing unit (ie cleaning thermistors or replacing the fuser roller?) That code means you have a temperature problem.  It will also come up if your power cord is loose.  You can check it by taking off the back cover of the copier and pressing in the trouble reset button while the copier is on.  It's a small black button. If the code goes away, you're good to go. If it comes back, you might have to replace some of your fuser components.
Oct 13, 2007 | Office Equipment & Supplies
341 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
