Question about GE GSS20DBPWW / GSS20DBPCC Side by Side Refrigerator
Freezer woorking ok fridge not cold model GSS20DBPC WW
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
GESS25LGMB WW Side-by-side fridge/freezer won't cool.
call a repair service it probably need freon added to system and that is not a consumer FIX
Aug 27, 2017 | General Electric Refrigerators
Frige conparment is not working but the light still comes and the frezer is in good woorking order
heatman101
Mar 31, 2011 | Smeg FAB40PS Top Freezer Refrigerator
I have a ge side by side fridge model number GSH22JFXL ww and the freezer is working great but the fridge is not cold at all.
If the freezer is working great and you don't have frost build up on your coils (this would be a defrost problem) and your fan is running in the freezer, then first check your control settings.
put both your freezer and refrigerator controls in the middle position. your refrigerator gets its cold air from the freezer. the freezer control is actually the thermostat control. this controls the compressor. the refrigerator control is basically an air damper that allows more or less air in from the freezer.
by placing both controls on 9, you may think that you are turning both controls wide open when you are actually making the compressor run longer yet the air damper is keeping that cold air mostly in the freezer.
allow 24 hours for stabilization
Jul 02, 2010 | Refrigerators
Have a gs201eta ww refrigerator ice maker problem Unit makes ice, light works and water dispenses from the door. However ice cubes and crushed iced does not dispense from the door. The dispenser motor...
The fridge gets its cold air from the freezer through a vent between the freezer and fridge. the fan in the freezer blows air through it. there is a flap you adjust with the fridge temp. control.
Make sure it's opening and closing when you adjust the fridge temp. try to chec in the user guide.
Hope helps.
Jul 07, 2010 | Refrigerators
GE Model # DSS25PFMD WW, lights and fan are working not cooling
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 21, 2009 | GE GSS25JEM Side by Side Refrigerator
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Fridge side not cold-freezer great
there is a three prong replay that hooks up to your compressor sounds like it needs to be replaced
Sep 01, 2008 | Refrigerators
GE GSS20DBPWW / GSS20DBPCC Side by Side Refrigerator Logo
182 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
