Question about Raymarine Smartpilot Autopilot St6002 S1g Hydraulic Inboard Pack
ST6001 when press auto it engages but within seconds turns hard to port and stays engaged until we turn off the power at A/P switch.
  • 64 Answers
Try reversing the motor leads on the CPU. If this doesn't work you will have to check the rudder feedback to see if it is operating properly. The easiest way to check this is to steer the wheel from port to starboard extremely slowly and make sure the readout on the control head has a smooth transition when you turn the wheel.
Posted on Sep 01, 2010
I have a Cub Cadet 2135 mower deck issue: Started OCCASIONALLY shutting off on turns and down slopes. Turned the switch off then on and it worked until another seemingly random time as above. Now, deck...
repair the seat first remove seat and reinforce metal use metal plate on top and washers on bottom or reverse make sure seat is secure so that u do not loose the ground contact on safety switch their is also a safety switch on shifter lever and brake pedal check them for rust and a tight contact
Nov 02, 2013 | Garden
No electrical power to AC Compressor. The switch light comes on in car when AC power button is turned on.
  1. Check if air blows with the fan setting turned to high.
  2. Check that the radiator cooling fan engages when the A/C button is pressed.
  3. Locate the compressor.
  4. Turn on the A/C.
  5. Check if the compressor's clutch has been engaged.
  6. If the clutch engages, the fault is elsewhere.
  7. If the clutch does not engage, check for power to the clutch.
These steps might help find the problem.
Sep 16, 2013 | 1997 Ford Escort
I have an Oster Bread Machine model 5839. The display and timer work but nothing else does.
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
All breadmaker use a belt and pulley system. If your breadmaker powers-up but the mixer won't turn when it's supposed to, your belt is probably broken. You
Jun 15, 2011 | Oster Kitchen Appliances - Others
When turn on, the red light is on (stop blink), but after some seconds the red light is blinking again and the tv remain off
Im not Guarantee This will Work but give it a go
Multi-Region:
  • Turn On the unit with the remote controller
  • Wait until "no disc" appears in the unit's display
  • Press Pause, 3, 1, 4, 1, 5, 9
  • The word "CODE" should appear in the display
  • Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
  • Again, within 5 seconds, press Pause and Power
If the above fails to work then you may wish to try the following:
  • Put the player into Standby mode
  • Press 1 and Return on remote for region 1, 2 and Return for region 2, and so on. Use 0 and Return to return player to default region settings
  • Press P-Mode and Return to play DVD's with the selected region, auto-switching is Off
  • Press Audio and Return for auto-switching On
  • Press Angle and Return for MacroVision On
  • Press Subtitle and Return for MacroVision Off
hope this helps you out
cheers Little Dish Fitter.
Sep 24, 2009 | Toshiba Televison & Video
Power locks don't engage when driving
this is form the owners manual, page 19:
The Automatic Door Locks can be enabled or disabled by
performing the following procedure:
1. Close all doors and place the key in the ignition
switch.
2. Cycle the ignition switch ON/OFF four times ending
in the OFF position. (do not start the engine)
3. Within 10 seconds of the final cycle, press the interior
driver’s door lock switch to the LOCK position.
4. A single chime will sound to signify that you have
successfully completed the programming.
You can turn the feature back on by repeating the above
mentioned procedure or by performing the procedure in
the Electronic Vehicle Information Center (EVIC), Customer
Programmable Features section on vehicles so
equipped.
Aug 14, 2009 | 2005 Dodge Grand Caravan
1999 Lincoln Town Car Cartier door locks
U may need to program the auto lock feature again, the instructions are this
Autolock can also be activated or deactivated using the following
procedure:
You must complete steps 1 through 7 within 30 seconds or the procedure
will have to be repeated. If the procedure needs to be repeated, you
must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control on the door panel three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition key back to ON. The doors will lock and unlock.
6. Press the power door unlock control. The horn will chirp once upon
successful toggling of the Autolock feature.
7. Turn ignition to OFF.
May 15, 2009 | 1988 Lincoln Town Car
Turning on
If your iPod does not turn on or it appears to be frozen... you may need to reset it...
  • Toggle the 'Hold' switch on and off. (Slide it to Hold, then turn it off again.)
  • Press and hold the 'Menu' and 'Center (Select)' buttons for about 6-10 seconds until the Apple logo appears. This step may need to be repeated.
Note: When you reset your iPod all your songs and files are saved. Some of your customized settings may be lost though.
More Tips If Your iPod Does Not Turn On Make sure that your iPod isn't on 'Hold'... Check the 'Hold' switch and make sure that it isn't set to the 'Hold' position... if you see any colour, your 'Hold' switch is engaged.
You might also try toggling the switch to the 'Hold' position, switch it back off, and then try turning it on.
Make sure that your battery is charged... Your iPod won't turn on if the battery is depleted. Instead, a low battery screen may appear for about 3 seconds when you try to turn it on.
To charge it, connect it to a high-powered USB 2.0 or FireWire port on your computer, or to an Apple iPod Power Adapter that's connected to an electrical outlet, using the cable that came with it.
If your iPod still won't turn on, reset it...Press Menu and Select buttons for six seconds until the Apple logo appears.
When you reset your iPod, all of your songs and files are preserved, however, you may need to reset some customized settings.
Let your iPod battery drain... In rare cases, your iPod might get into a state in which the battery needs to be drained completely before you can reset it.
May 13, 2009 | Apple iPod nano
Anti-theft has engaged
sounds like the transmitter in the key head is defective or it lost programming, try these programing steps, if that doesn't do it u need another key made.
Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door
locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle to confirm
programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will cycle again to
confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Apr 19, 2009 | Mercury Mariner Cars & Trucks
It's not a toyota tacoma it's a 90 Lexus ls400
Your starter drive is staying engaged. Either the starter has failed, or your ignition switch is keeping the starter engaged. Try moving the key back from "start" while the noise is occurring. More than likely, the starter is the culprit.
Jul 10, 2008 | 2002 Toyota Tacoma
Raymarine Smartpilot Autopilot St6002 S1g Hydraulic Inboard Pack Logo
281 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
merc racing
Level 1 Expert
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
