Washing Machines Logo
Posted on Aug 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It's on control lock - Whirlpool Washing Machines
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Aug 23, 2010
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2735645
Points
22413
If you are referring to the Control Lock on a Whirlpool Duet, Kenmore Elite, or Maytag Epic series front loader, this is actually a safety feature that enables the consumer to lock the control panel to prevent children from manipulating the controls and accidentally starting the appliance.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite, Maytag Epic or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more significant problem other than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
I have a 2008 Chevy Malibu inside door locks don’t work like theirs no power no does not click on inside to lock when you’re in the car nor outside when you put the key in the outside lock it only locks...
Probably not a whole lot your going to be able to do ,Unless you have a factory or some other professional type scan tool to check for DTC'S - diagnostic trouble code's , an have service repair info for power locks for your car . Computer controlled (BCM) - body control module .
Door Lock System Components
The Power Door Lock System consists of the following components:
• Body control module (BCM)
• Driver door lock switch
• Front passenger door lock switch
• Reversible door lock actuator in each of the doors
• IBCM (PWR) 15-amp fuse
• Driver door cylinder switch, if equipped
Door Lock System Controls
The Power Door Lock System is controlled by the body control module (BCM) and can be activated by any one of the following:
• A door lock switch lock or unlock actuation
• A keyless entry transmitter actuation
• An automatic door lock or unlock actuation
• A last door closed locking (LDCL) actuation
If the driver door cylinder switch feature of the vehicle is functional, the locks may also be operated by a driver door cylinder switch lock or unlock activation
Power Door Lock Switch Operation
Each door lock switch is wired to the body control module (BCM) through a separate door lock/unlock signal circuit. While these circuits are separated between the BCM and respective door lock switch, they are connected into a single circuit within the BCM. The BCM supplies voltage through the door lock/unlock signal circuits to each door lock switch. When either door lock switch is operated, this supply voltage is pulled to ground, providing the BCM with the required lock or unlock signal. In order for the BCM to distinguish between a lock and unlock signal, the lock switch contains two separate paths for this voltage to flow to the same body ground. When the switch is operated to the unlock position, the supply voltage flows to ground through a 1.5 K? resistor. When the switch is operated to the lock position, the supply voltage flows to ground through a different part of the switch circuit, which has no resistor. The BCM then interprets the flow of voltage as a lock or unlock request and powers the door lock actuators to the appropriate lock or unlock position.
Power Door Lock Actuators
The body control module (BCM) powers the reversible door lock actuators by providing battery positive voltage and ground to the appropriate lock and unlock control circuits of the actuators. The Lock control circuits of the driver and passenger door lock actuators are all connected together, however, the Unlock control circuits are connected in a slightly different way. While the unlock control circuits for the passenger door lock actuators are connected together, the driver door lock actuator has a separate unlock control circuit. The system is designed this way so that the keyless entry transmitter may be used to unlock only the driver door. Despite this difference, all of the lock actuators perform much the same way. When the door lock actuators are not active, all actuator Lock and Unlock control circuits are at ground potential within the BCM. Transitioning of the lock actuators to the lock or unlocked position depends upon which control circuits receive voltage and which control circuits receive ground.
• If the BCM is commanding the door lock actuators to Lock, it momentarily switches the lock control circuits to voltage. Since the unlock control circuits are at ground potential within the BCM, the actuators transition to the Lock position.
• If the BCM is commanding all door lock actuators to Unlock, it momentarily switches the unlock control circuits for both the driver and passenger door lock actuators to voltage. Since the lock control circuits are at ground potential within the BCM, all lock actuators transition to the Unlock position.
• If the BCM is commanding only the driver door lock actuator to Unlock, it momentarily switches only the driver door actuator unlock control circuit to voltage. Since the lock control circuit is at ground potential within the BCM, the actuator transitions to the Unlock position.
Power Door Lock and Unlock Operation w/Keyless Entry Transmitter
The keyless entry transmitter may be used to unlock only the driver door. When the unlock button of the keyless entry transmitter is pressed once, the body control module (BCM) receives the unlock request from the remote control door lock receiver (RCDLR). The BCM interprets this single press as an unlock driver door request and responds by switching only the driver door lock actuator unlock control circuit to voltage. With the lock actuator lock control circuit for the driver door at ground potential within the BCM, the driver door lock actuator transitions to Unlock.
If the unlock button of the keyless entry transmitter is pressed a second time within three seconds of the first press, the BCM interprets this second press as a request to unlock the passenger doors and responds by switching the passenger door unlock control circuits to voltage. With the lock actuator lock control circuits at ground potential within the BCM, the passenger door locks transition to Unlock.
To lock all doors with the keyless entry transmitter, a single press of the transmitter lock button is all that is ever needed. The BCM receives the lock doors request from the RCDLR and responds by switching all lock actuator lock control circuits to battery voltage. With the actuator unlock control circuits at ground within the BCM, all actuators transition to Lock.
1helpful
Where are the fuses for the power dock locks on a 2006 montecarlo06ss
DR/LCK fuse 25 amp . located in the I/P block
Fuse Block - I/P
In the right front kick panel
Power Door Locks System Components
The power lock system consists of the following components:
• Driver door lock cylinder switch
• Front passenger door lock cylinder switch
• Door lock actuators in each of the doors
• DR LK Fuse 20-amp
• A door lock cylinder switch unlock actuation
• An automatic door lock actuation (Personalization function)
• An automatic door unlock actuation (Personalization function)
Door Lock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the lock position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the lock position.
Driver Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the left front (LF) door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the body control module (BCM) detects a transition of either of the door lock switches to the unlock position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked separate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed).
CONTROL LOCK GE GAS DRYER
  1. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to lock the control panel.
  2. Listen for a double beep and observe the "Control Lock" status light is lit when the control lock is in effect.
  3. Press and hold for 3 seconds the "Control Lock/Unlock" button on the control panel to unlock the control panel. The "Control Lock" status light is goes out when the control panel is unlocked.
Jan 31, 2015 • GE Dryers
5helpful
Controls locked
The Control Lock prevents unintended use of the washer. You can also use the control lock feature to prevent unintended cycle or option changes during a cycle. When CONTROL LOCKED is lit, all buttons are disabled except for Pause/Cancel and Start. You can lock the controls while the washer is operating. To lock the controls: Select and hold DRAIN & SPIN for 3 seconds. The CONTROL LOCKED status light glows. To unlock the controls: Select and hold DRAIN & SPIN for 3 seconds or until the CONTROL LOCKED Status light turns off.
2helpful
The controls locked is displayed. what causes this and how do i get the controls unlocked.
2helpful
Control locked
If you want to enable the Controls Lock/Unlock Feature:-
To enable the Controls Lock feature when dryer is running: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds. The control is locked when a single beep is heard and the Controls Lock status light is on. This feature allows you to lock your settings to avoid unintended use of the dryer. You can also use the Controls Lock feature to avoid unintended cycle or option changes during dryer operation.
■When the dryer is off, it is not necessary to press the Control On button before activating the Controls Lock feature.
For unlocking: Press and hold the CONTROLS LOCK/UNLOCK button for 3 seconds to turn this feature off.
NOTE:- When the dryer is running and Controls Lock is on, the dryer can be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
Good Luck and have a nice day
Rating the solution is highly appreciated.
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
36helpful
Control Locked
Locking controls
lit, all buttons are disabled. You can lock the washer while it is
operating.
Select and hold END OF CYCLE SIGNAL for 3 seconds.
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
1helpful
Kitchenaid superba stove
Control Lock
unintended use of the oven. The Control Lock is preset off;
however, it can be enabled.
When the control is locked, only the TIMER SET/START and
TIMER CANCEL pads will function.
Before locking, make sure the oven, the Timer and Timed Cooking
are off.
To Lock:
1.
Open the oven door.
2. Press and hold the number pad 3 CONTROL LOCK for 5
seconds.
A single tone will sound and “START?” will appear on the
display.
3. Press START. “CONTROL LOCK” and a picture of a lock will
To Unlock:
1.
Open the oven door.
seconds.
A single tone will sound and “CONTROL LOCK” and a picture
of a lock will disappear from the display.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
