Question about Electric Demolition Jackhammer
Plug in the hammer and no response when you push the trigger
  • 885 Answers
To trouble shoot, easiest to hardest:
1. Check both brushes, they should be 1/4" long or more and evenly worn, the spring should push carbon firmly against armature. If there is a small pin pushing out of the center of the brush it is worn too far and needs to be replaced. The pin is designed to push excessively worn brushes off the armature so as not to damage it. >
2. Check for power at cord going into the switch with a multimeter, if 0V replace the cord, if 110V; push trigger and check for power coming out of the switch, if 0V replace the switch, if 110V >
3. If these are all OK you need to check the armature on a growler to see if it's OK.
Posted on Aug 23, 2010
  • slaves Sep 03, 2010
    Have same problem, sure brushes are worn down, can these be purchased any where?.
How can I reverse the direction on the drill?
Above the trigger there is a black slide switch that will reverse the direction if its in the colckwise direction the richt side is pushed in if counter clockwise the left side is pushed in.
Apr 06, 2016 | Black & Decker Black and Decker FIRESTORM...
Cva optima .50 cal hammer won't lock back
Try pushing the trigger forward while cocking it, if it locks it's probably a bad trigger spring. Remove the hammer/lock assembly, it's only two screws, and have a look inside. The lock is very simple and should become obvious once you're in there.
Oct 14, 2015 | Cars & Trucks
Trigger problem on my Yugoslavian SKS rifle. when the bolt and carrier are locked in the firing position it pushes down the pin on the trigger group and the hammer will not fire. If you pull the bolt...
I'm having trouble visualizing which pin (firing pin???) you're talking about. How sure are you that the rifle has been reassembled correctly? Could you post a picture so we can see how it's assembled? One shot (no pun) of the assembled trigger group would be good, then another shot of the bolt & carrier.
Aug 07, 2014 | Optics
OLD PUMP WINCHESTER RIFLE - THE SAFETY BUTTON APPEARS TO BE STUCK, YOU CANNOT FIRE THE RIFLE.
Model 61, 62a, the 61 is hammerless and the 62a has a hammer, the safety on the 62 is the hammer, the safety on the 61 is a cross bolt, sounds like it is gummed up, or busted, I would take out the trigger houseing and clean it up and check it out. If the cross bolt is stuck, something is blocking it, like the hammer at half c0ck, try pushing the trigger forward and see if it moves, whatever happens, I would still take it apart and clean it, don't screw it up, it is a very collectable rifle.
Oct 23, 2010 | Winchester Optics
I was hammering for a little less than an hour this morning. The plug got disconnected while the hammer was running. Upon plugging it back in, the hammer will not come back on. I checked the breaker and...
did you have the trigger in the locked position, some tools have a safety that you need to release the trigger after plugging back in to reset the switch. try that first.
Sep 21, 2010 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
D25600 does nothing when i pull the trigger
take it to a repair shop.could be broken wire in lead,could be burnt out armature,could be crook trigger switch,try a new plug on the lead
Jul 05, 2010 | Dewalt D25600K Electric Rotary Hammer
How do i change the drill bit
you will get a better response by adding more information. like its a hammer drill and the type of bits being used.
im gonna guess and assume its a hammer drill.
there is a collar at the front of the drill that will pull down / back toward the trigger as this is pulled down you can pull the bit out.
Mar 01, 2010 | Bosch Drills
Te 76 service light is on, brushes are new.
Take all the screws from the handle to the motor housing out and unplug handle. While holding the trigger in the on position plug in power cord and still holding trigger remove plug, reassemble and try it. Sometimes you have to plug in and then squeeze trigger and hold it and then unplug but either one should work. If not you might have a switch problem. Let me know if you need more help and if I have helped you would you please rate this response accordingly. Thank you.
Oct 01, 2009 | Hilti Drills
Cannot load staples
At the back of the staple gun is a flat shaped metal piece. It's at the bottom. Push in, pull down, then pull the mechanism out. You'll see it's a metal rod with a spring, that is attached to that flat metal piece. The spring pushes against another flat metal piece, that has a hole in it, and travels back, and forth on the rod.
The flat metal piece that the spring pushes down the rod, pushes against the staples.
Remove this spring mechanism, slide the staples down the rails. The staples will be in the position of an upside down U. Replace the spring mechanism, and lock it back into place. (Push in, pull up)
Should, your question be in reference to the fact that you have staples loaded, but upon pressing the trigger nothing comes out:
In the front of the staple gun, is a flat metal piece that pushes down on the staples. One staple at a time. The flat metal piece is shoved down by spring pressure. The spring pressure is applied to the flat metal piece each time you squeeze the trigger. (Flat metal piece = Hammer)
Sometimes, Two staples try to come out. When they do, this flat metal hammer is stuck up in the gun. To free the flat metal hammer, remove the spring mechanism out of the back of the staple gun. (The spring mechanism discussed above) Remove any staples in the gun.
Try to use a flat blade screwdriver, and see if you can shove the flat metal hammer in the front of the gun -> UP.
(DO NOT have the staple gun pointing at your face! DO NOT squeeze the trigger! DO NOT use excessive force)
If this method is of no avail for you, you have to disassemble the gun, and remove the metal hammer, and stuck staple/s.
Jul 29, 2009 | Arrow T50P ARROW STAPLE GUN
Jammed makita an923 nail gun
On most all nailguns when the trigger is activated air pressure is released from the headvalve causing the headvalve to open and fire the piston. If air leaks through the headvalve orings or through the headgasket port to headvalve, it will not fire. Try applying light grease to headvalve orings and make sure that headgasket is sealing around vent hole. If it fires then replace orings in headvalve for long term repair. Secondary problem is worn safety parts and trigger or trigger pin. If these parts are worn the trigger will not push the trigger valve pin all the way in when you bump fire the gun. With air supply disconnected, apply pressure to safety while depressing the trigger and check thet the pin is moving all the way into the trigger valve. Adjust or replace as necessary. Enjoy
Sep 13, 2008 | Air Tools & Compressors
Electric Demolition Jackhammer Logo
580 people viewed this question
Top Electric Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Dan Webster
Dan Webster
Are you an Electric Hammering Expert? Answer questions, earn points and help others
