Question about Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look
Just hooked up whirlpool model ed5hhextloo fridge and when i turn water on then dispense waterr the water will not stop
applianceboy
  • 77 Answers
SOURCE: Water dripping on GE Fridge model TFX24ZR
check your water filter. water preasure is important in the operation of the water valves. if the filter is ok replace the valve. water filter should be changed at least once every year.
Posted on Sep 26, 2007
fridgetech
  • 473 Answers
SOURCE: How to hook up Ice & Water dispenser on freezer door
The water valve is on the back of the refrigerator. The water line connects directly to that valve. If there is no line available then you will need to run one from a cold water line in the plumbing using a drill type (1/4") saddle valve on that pipe. Hope this helps. If you need more instruction let me know!
Posted on Oct 06, 2007
  • 33 Answers
SOURCE: Amana Side-by-Side Fridge Model SBD21VPSE
If there is a reset button on your ice maker try pushing it. Many ice makers have two holes for reset. A general rule of thumb is if the ice maker fingers are stopped in a slightly vertical position then your ice maker unit is working. If the fingers are stopped anywhere else then it needs some sort of attention or replaced. Make sure there is water, or ice in the ice maker tray, if not then the problem is with water supply.
Posted on Nov 29, 2008
tborn6
  • 700 Answers
SOURCE: My whirlpool fridge, ice makerMy Whirlpool is not making ice. It has an in door ice dispensing system. It stopped making ice yesterday - what could be wrong?
lift the bar up to shut the maker offf and then turn it bakck on and wait.
Posted on May 27, 2009
BIKER T
  • 909 Answers
SOURCE: Samsung side-by-side fridge freezer model
these side by sides use an auger motor in the fridge to open and close according to the temp demand. If its eratic, either the auger is icing up at the outlet possibly due to product being to close to the outlet. On occation i have had to replace them due to being faulty.(to check, adjust the temp. and notice if there is any change on the auger.)
Posted on Sep 17, 2009
Testimonial: "Thank you. Have followed your advice and temp has been stable continually since. Many thanks, you've saved me a few bob!"
Whirlpool side-by-side fridge water dispenser stopped working this morning. When I depress the lever, I can hear it buzzing, but no water comes out.
Have you checked the water pipe is actually producing water
- Not kinked
- Vale turned on at wall
If you are still making ICE... your drinking VALVE is defective.
Without a model number we can speculate no further.
Carnac the Magnificent
Apr 26, 2017 | Whirlpool Refrigerators
Whirlpool refrigerator WSF26C2EXF01 water dispenser not working
This sounds like the water inlet valve has gone bad.. First before u replace it check to see that you have water coming to back of fridge as it could be restricted causing no water to reach the fridge.
Apr 04, 2014 | Whirlpool Refrigerators
In-door water dispenser for Whirlpool ED25UEXHW00 stopped working
Sounds like the water valve for the water dispenser is not opening..You can search the internet for you model number and order a new valve online..I just order a duel water valve for my whirlpool and it was 80 dollars..Got it from www.partselect.com Hope this helps
Mar 16, 2017 | Whirlpool Refrigerators
The cold water dispenser in my whirlpool refrigerator stopped dispensing water about 2 years ago. Recently it just started dispensing water and does not shut of. I had to close the valve to the water and...
Hi copy;
You may like to try the Water Valve (Solenoid) sounds like it may had stuck once now has become free and stayed open allowing too continually flow. It is behind fridge where the mains water is connected into fridge... Cheers
Mar 16, 2010 | Whirlpool GS5SHAXN Side by Side...
I have a whirlpool side by side fridge with no water pressure
no fuse for the valve. did both of these fail at the same time? i would guess not since you wont see 2 things go wrong at the same time.
most likely the water inlet valve is bad. you can just replace it and see if you get water then.
and just because you have water at the valve doesnt mean you will have enough volume to force water into the i/m or water dispenser. make sure you have a good volume of water at the copper water line. then try the dispenser again. it should have good flow thru the door.
then let the i/m cycle and see what size cubes you get. if you get 8 cubes and they seem to be similar in size then it is ok.
most of the time the "piercing valve" is the trouble and is where the unit hooks up to your house lines.
shut off the piercing valve all the way and then turn back on. this could clear the valve and allow water to flow again.
Jan 08, 2010 | Refrigerators
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Hi, I have a side by side S20D RBB32-A/G Fridge Freezer with ice and water dispenser. The frezeer and fridge stopped working. I called a local repairer who took away a part for repair. However, the fridge...
Try checking the mesh screen which is in the water line where the water supply connects to the water inlet valve on the back. It can get stopped up with sediment.
Sep 29, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Warm water out of water dispenser
If this is a new hook-up please be sure that your water line is connected to the cold plumbing on the house and not the hot.
IF it is on the hot the fridge is cooling it down to warm.
Please let me know if this helps you.
Jan 06, 2009 | Whirlpool Refrigerators
Whirlpool water dispenser not working model ED25RFW00
It is possible that you have an airlock in the chilled water section but not very likely. I would be more inclined to suspect that the water storage section in the fridge compartment (below salad section) has become frozen as I have experienced this before. I would suggest defrosting the cabinet completely and trying again, ensuring that you push the water valve for a long enough duration. Hope this is of some help.
Mar 13, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool 25.4 Cu. Ft. Side-by-Side Refrigerator w/Thru-the-Door Ice & Water - Satina Stainless-Look Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
