Question about Swisher 60" 13 Hp Trailmower #T1360h
Battery good, fuse good, key start wont turn over starter. Al
My 1999 cougar clicks but wont start up when i turn key
first make sure battery is charged if so then then check the relay in the fuse box under the hood find the relay that marked "ing" pull that relay then find a nother one to inter change with it, if car still wont start then ou will need to see if the in line fuse on the starter wire is good or blown if its good then you will need to pull the starter and replace it. hope this helps you
May 07, 2014 | 1999 Mercury Cougar
03 wrangler wont start
A problem on the ignotion?
____________-
wifi obd tool for ipad iphone
Oct 08, 2012 | 2003 Jeep Wrangler
Replaced the battery and the starter but the truck wont start.when u turn the key to start it nothing happens
The problem could be in the key switch, In the starter relay switch, solenoid, fuse pannel, or a fusable link. Good luck.
Dec 10, 2010 | 2004 Ford Explorer
It wont turn over battery OK what could be wrong? starter or fuel pump
If it will turn over, and not start, you are missing either fuel or spark...Those need to be checked. (No fuel doesn't automatically mean bad fuel pump, as injectors need to "fire" the fuel.)
If it won't turn over, or clicks, and your battery is good, it might be the starter motor.
Aug 19, 2010 | 2000 Dodge Durango
96 Olds Aurora wont start nothing happens when i turn the key,battery is good.
CHECK THE INSTRUMENT CLUSTER FOR POWER TO GAUGES TO SEE IF THEY WORK WHILE IGNITION IS IN THE ON POSITION.IF NO CHECK THE 40 AMP IGNITION FUSE.IF FUSE GOOD IGNITION SWITCH IS BAD OR HAS A LOOSE OR BROKEN WIRE.IF FUSE GOOD ALL GAUGES IS WORKING.I BE LOOKING AT STARTER AND STARTER SOLENOID.REMOVE THEM HAVE AUTO ZONE TEST STARTER.OR YOU CAN GET A REMOTE STARTER SWITCH AND SET OF BATTERY CABLES.HOOK BATTERY CABLES TO A BATTERY.WITH STARTER OUT OF CAR TAKE BATTERY CABLES HOOK NEGATIVE BATTERY TO STARTER BODY FOR GOOD GROUND.TAKE POSITIVE BATTERY CABLE HOOK TO STARTER POSITIVE TERMINAL WHERE POSITIVE BATTERY CABLE GOES.THEN HOOK THE REMOTE SWITCH RED WIRE TO STARTER POSITIVE TERMINAL AND THE OTHER REMOTE SWITCH WIRE TO THE S OR SWITCH TERMINAL ON STARTER SOLENOID.PRESS THE REMOTE SWITCH IS STARTER RUNS GOOD WITH NO FUNNY NOISES ITS GOOD IF STARTER DONT RUN THE STARTER SOLENOID OR STARTER IS BAD. THE PROBLEMS IN YOUR CAR COULD BE A BAD KEY TRY ANOTHER KEY YOUR CAR HAS THE THEFT DETERRENT MODULE SYSTEM BEST TO HAVE CAR SCAN TO CHECK THE THEFT SECURITY MODULE AND THE TRANSMISSION NEUTRAL SAFETY SWITCH IF ITS BAD STARTER WONT WORK.ALSO CHECK THE THEFT DETERRENT MODULE RELAY. BEFORE REMOVING BATTERY CABLES TURN OFF RADIO SO YOU WONT LOSE YOUR RADIO PLAYING CODE.
May 20, 2010 | 1998 Oldsmobile Aurora
My truck wont start battery is brand new all gueges work when i turn the key but it wont crank?
If you look down where the starter is you will see al little round selinoid with to things sticking out that look like screws and have nuts and wires going to them. Take a good gauge wire and jump across them. If the starter does not kick in or spin over then your starter is bad. If it does kick over then there is a good chance that the ignition switch has gone bad.
Apr 10, 2010 | 1991 Ford F250
Jeep wont start yj with 4.0 l
make sure ground wire is properly routed and the starter cable from battery to starter is in good shape and not all corroaded if the battery is good then the problem is in the cables or starter
Mar 23, 2010 | Jeep Wrangler Cars & Trucks
My 1992 Mx5 Miata just wont start!!
remove the key from the ignition get a 21 mm socket and wrench and try to turn the crankshaft clockwise to see if it moves if it moves try to push start the car push the car to about 1 to 2 miles an hour with the key in the on position all dash lights on eg. check engine, air bag, etc. put in second gear and drop the clutch if it starts it's likly you have a bad starter
Nov 12, 2008 | 1992 Mazda MX-5
Swisher 60" 13 Hp Trailmower #T1360h Logo
56 people viewed this question
Top Swisher Garden Experts
Tim Whalen
dannydoesita
ray gallant
Are you a Swisher Garden Expert? Answer questions, earn points and help others
