Question about Convair Portable Air Conditioner
Where can I get a small rubber belt for the fan and pump for convair westwind
    President:
  • 3,773 Answers
Try www.marcone.com
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 23, 2010
Need belt for CV-600 convair swamp cooler
you can get a belt by calling18009266824, seeley international
Aug 13, 2011 | Convair Portable Air Conditioner
I need a belt for convair westwind swamp cooler Model M800CB UL serial #08 211046 Prod #: 008950 Belt runs from back of fan to the drive for the water pump. If you know where I can get one I would...
Hi John, your best bet for this, is to get the name and or number off of the belt, or take it off and go to any auto parts store and match it up. That's what we do in the field. If you try and order one, you will run in circles. Also, any appliance parts house will have one.
Shastalaker7
A/C Contractor
Jun 06, 2011 | Convair Portable Air Conditioner
I suspect the water pump needs replacement, since there is liquid like fluid below engine. what are the steps one must take, to replace the water pump. Why is it not simple to do? Looks like alot of...
1.3L & 1.6L Engines
  1. Remove the timing belt cover, timing belt, tensioner, plate and spring.
  2. Remove the water pump mounting bolts.
  3. Remove the one (1.6L MFI engines) or two (1.3L and 1.6L TFI engines) small rubber seals from between the water pump and the oil pump, and the water pump and the cylinder head.
  4. If necessary for clearance, remove the oil level dipstick tube retaining bolt from the engine block and the alternator adjusting brace.
Exploded view of the water pump mounting
Click to Enlarge
WARNING
Do NOT use a prybar between the water pump housing and the engine block to separate the two components; this can cause scratches and/or gouges, which can prevent proper sealing.
  1. Pull the water pump off of the engine block. If the water pump is difficult to remove from the engine block, use a soft-faced mallet to tap the water pump housing until it loosens.
Do not disassemble the water pump; if the water pump is damaged or defective, the entire unit is replaced.
  1. Thoroughly clean the water pump gasket mating surfaces of old gasket material and corrosion.
The drive belt can be used to hold the fan stable while loosening the mounting fasteners
Loosen the fan bolts, then either remove the drive belt before the fan and shroud ...
... or wait to remove the belt, along with the water pump pulley
Once the cooling fan and shroud are removed, access can be gained to many of the engine components, including the water pump
To install:
  1. Along with a new gasket, install the water pump on the engine block. Tighten the water pump mounting bolts to 88-115 inch lbs. (10-13 Nm).
  2. On 1.3L and TFI 1.6L engines, install two new rubber seals: one between the water pump and oil pump, and the other between the water pump and the cylinder head. The MFI 1.6L engines only use one rubber seal, located between the water and oil pumps.
Be sure to install the two rubber seals between the water pump, oil pump and cylinder head before installing the timing belt cover-1.3L and 1.6L TFI engines
The 1.6L MFI engine uses only one rubber seal between the oil pump and water pump
  1. If removed, install the alternator adjusting brace and the oil level dipstick retaining
Apr 19, 2011 | 1991 Suzuki Sidekick
I have a Convair Westwind air cooler that you fill with water. I have lost the plug that holds the water in. Can you send me one (or two) of these plugs?
Howdy, we have no affiliation with Convair corp. As we are a general solutions and technical assistance with everything website.I have, however found the contact info for them :
CONVAIR COOLER CORPORATION
I hope you found this useful, thanks for using fixYa.com. Farmerbear
Sep 02, 2010 | Samsung AW1203B Air Conditioner
I own a Convair Magicool and the fan belt has gone. Finding a replacement is proving to be dufficult. Can you suggest what to do?
very simple take old belt to a-c supply store or get a string wrap around both pulleys mark it and take it to a auto store or local a-c supply house
Jul 01, 2009 | Heating & Cooling
Breezair swamp cooler parts
Contact Convair cooler corporation.
Phone # 1- (602) 353-8066
Will send your parts out the same day.
Jun 28, 2009 | Heating & Cooling
Remote control possibley defective
Does your remote have a variable control for the bright and dim for the light??sounds like yu have it in the dim mode..
Mar 26, 2007 | Westwind Classic Hugger Polished Brass 52"...
Convair  Portable Air Conditioner Logo
406 people viewed this question
Top Convair Heating & Cooling Experts
Donni Steen
richie46
ray gallant
Are you a Convair Heating and Cooling Expert? Answer questions, earn points and help others
