Question about Dremel 1800-01 Scroll Station 18" Variable Speed
Breaking blades My Blades keep breaking, is it the speed,saw or type of blade?
    Champion:
  • 313 Answers
Check the linkage at the if worn.
Posted on Jun 05, 2008
You have to use 127 mm pin end blades, and if you apply a side pressure they will keep breaking
Posted on May 06, 2008
Hi I have a Black and Decker Jig Saw 7588 Type One that works fine but I can not find replacement blades for it here in San Diego, California. Where can I find the blades?
I have the blades and the 7588 jigsaw. thinking about selling on ebay. search for black & decker jigsaw w/ blades in next couple days if interested in buying saw with 6 blades. thankyou, makthriftsales
Jan 14, 2013 | Black & Decker Single Speed Jig Saw
Will not keep proper tention, bounces around and keeps breaking blades.
Don't make your tension too tight! You may want to try some different speeds. Try different blades.
Jan 06, 2013 | Skil 1.2-Amp Variable Speed Scroll Saw...
My original blade broke so i bought a new blade from wickes 10tpi now when i use it i saw on the line i have marked but on the other side of the 2x2 it is about quarter to hallf inch out how can i make...
There are good blades and there are cheap blades. Good blades are straighter but less tolerant of poor technique and so tend to break, cheap blades can and do bend far more. You can keep the blade straighter by not forcing the blade through the work and allowing it to cut at it's own rate and by experimenting with the speed settings on the jigsaw. It also helps if you pick the correct blade for the job: 10tpi is a bit too coarse for ripping a timber batten along the grain but fine for rough cutting chipboard. Also, it's difficult to keep the foot of the jigsaw absolutely level on 2x2 which adds to your problems.
Aug 15, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
How can I sharpen blades on a Norelco T765
You can not sharpen these blades. To sharpen them, you would have to be able to remove each blade frm the plastic cartridge tht holds them. This type blades are manufactured in such a way that there is no way to take out each of the two individual blades without breaking the part that holds them.
Feb 13, 2010 | Norelco T765 Beard Trimmer
KEEP BRAKING THE BLADES ON MY SCROLL SAW.
chances are you might be trying to feed the wood to fast or your speed is set wrong or the blades are not right for the job.
Oct 24, 2009 | Saws
Proper blade tension to speed tips
If you are like most people, (from your description you probably are), you might be feeding too fast. I did the same thing, and many other people I know did also. I learned by trial and error, and using scrap, watched from the side as I fed. Sure enough, when that little blade bent just a little too far...SNAP. It is much slower sawing than I imagined, even with the coarsest blade. I learned the best and broke the fewest with spiral blades. I always set the tension by sound. Again, trial and error. Take your sweet time! Have fun!!
Mar 30, 2009 | Saws
Grinder support
They range in blade composition, number of teeth (cutting bits or surfaces), the amount of set (the width of the kerf removed by the blade), and the blade quality. * One of these circular saws will probably have a plain HSS (high speed steel) saw blade in it when it is bought new. * TCT (tungsten carbide tipped) blades are much more durable, especially in tough hardwoods. Also plywood and composite boards are hard on blades so TCT blades are needed on them. o Blades with fewer teeth (say 28) and with less rake to the face of the teeth, are designed for ripping along the length of timber, with the grain. They typically give a quick rough cut. They are cheap to buy and cheap to sharpen, since they have less teeth. o Blades with more teeth (say 40) are designed for crosscut type work. They give a lot neater cut in most circumstances. * Abrasive blades are made from carborundum or other abrasive materials bonded together in a resin or other synthetic binding material, and are used for cutting concrete or metal. They tend to wear away rather quickly, but for small projects, they are inexpensive and make fast cuts. * Diamond rim blades. These blades are made of special alloy metals with industrial diamonds embedded in the rim (around the outside diameter of the blade), and are for cutting hard concrete, cement composite materials, and masonry products like block or brick. * Special tempered allow blades. These blades have tempered carbon steel teeth, which are very fine (small, and closely spaced) for cutting sheet metal like galvanised roofing metal, or aluminum, copper, or brass tubing. * Dado blades. These are blades which can actually be adjusted to cut different width kerfs (the width of the material removed in the blade path). These blades make it much faster and easier for cutting dados and rabbetts, used for joining lumber. * Trim and panelling blades. These blades have fine teeth for making smooth, accurate cuts on finished materials like mouldings and panelling.
Aug 27, 2008 | Speed CGW ABRASIVES 35606 "24 GRIT" HIGH...
Jig Saws Blades Types
High Speed Steel - Used for wood and light metal cutting Bi-Metal - Also used for wood and light metal cutting. Cobalt Steel - Tougher and lasts longer than Speed steel and Bi-Metal. Used for wood and metal. Carbide Grit - Strictly used to cut masonry board. Scrolling - Thinner than the regular jig saw blades and are used for tight turning cuts.
Aug 27, 2008 | Milwaukee Tool Milwaukee Orbital Jig Saw...
Blade Types
remember to match the blade width to the type of cutting you are doing. Also keep in mind: * Narrow Blades can make much tighter radius cuts, but tend to twist and wander when making long straight cuts. * Wide Blades can't make the tight turns that narrow ones can, but they hold a straighter line than their narrow counterparts. * The tpi determines the speed with which the blade cuts through stock. Blades with high tpi cut slower but leave a very smooth edge. They are best for detail work on thin stock. Blades with low tpi cut quickly and leave a slightly rough edge. They are great for resawing or long rip cuts. * Steel Blades are inexpensive and work well for cutting softwood. Steel blades, however, dull quickly in hardwood. * Bimetal Blades are made of high-speed steel and can cut thin metal or wood. * Carbide Blades are for wood cutting only. They are more expensive than other blades but stay sharper longer than steel or high-speed steel.
Aug 27, 2008 | Dewalt Variable Speed Deep Cut Band Saw...
Blade type
blades are available for different applications. A few common blades include:Steel Blades are inexpensive and work well for cutting softwood. Steel blades dull quickly in hardwood. High-Speed Steel Blades are harder than steel blades and stay sharp longer. Carbide-Tipped Blades are more expensive than other blades, but they stay sharp much longer than steel or high-speed steel.
Aug 27, 2008 | Jet 708100 Jwts 10 1 1/2HP Workshop Table...
Dremel 1800-01 Scroll Station 18" Variable Speed Logo
212 people viewed this question
Top Dremel Drills Experts
richie46
Tom Chichester
Are you a Dremel Drill Expert? Answer questions, earn points and help others
