Question about Sirius Starmate ST2 Satellite Radio Receiver
Starmate reciever (about 6 years old) shows message "CALL SIRIUS to SUBSCRIBE", Sirius account is active and paid, they sent signal a few times, on change on screen, 3 bars show on signial, channel descriptions show.. but still "call sirius" message exists.
  • jcrensha Aug 23, 2010
    Thanks. Tried this but recieving same message and same result after speaking wiht Sirius directly.
  • neostrawberr
    neostrawberr Feb 23, 2012
    not sure if anyone is reading this but did you ever figure out the problem ... mine is doing the exact same thing ... thanks!
    Brigadier General:
  • 5,158 Answers
Unhook the power to it for about ten to 15 minutes. hook the power back up and let it "boot" up. that should fix the issue
Posted on Aug 24, 2010
  • 2,272 Answers
Try reset to factory default settings:-- the features of the Receiver to the factory defaults, do the following: 1. Use the channel up and down buttons to highlight “Factory Default”, and press the select button. 2. Use the channel up and down buttons to select “Yes” to restore all settings to the settings from the factory, or select “No” to leave them as-is and return to the Menu Options menu. Restore Settings? Yes No 3. If “Yes” is chosen, a confirmation is displayed. Use the channel up and down buttons to select “Yes” to restore all settings to the settings from the factory, or select “No” to leave them as-is and return to the Menu Options menu. Are You Sure? Yes No 4. If Yes is chosen, the Receiver will revert to the original factory settings. 5. When the Factory Default is complete, the Receiver will place you in Channel 184 the SIRIUS preview channel and display, “Call 1-888-539- SIRIUS to Subscribe”. The Receiver is still subscribed to the SIRIUS service. After this procedure is done.Then check out. Check out.keep updated.Thanks.
Posted on Aug 23, 2010
I have a message to call Sirius to subscribe to sat. I called and the account is good and active with correct receiver number. Codes were re-sent by Sirius several times to no avail
wrong electronic ser# you might be paying for service but the wrong box is receiving or bad unit or possibly antenna problems
Mar 14, 2010 | Car Audio & Video
Receiver not "receiving"
where is the antenna located make sure it is not covered by anything. Also make sure there are no kinks or breaks in the antenna wire
Sep 11, 2009 | Sirius Satellite Radio Sirius Starmate ST1...
Sirius Starmate Power
My Sirius ST1 receiver froze. It reads "Sirius Radio" with the logs but goes no further in booting up. Any solutions?
Nov 12, 2008 | Clarion SIR-CL1 SIRIUS Radio Receiver
I have the same problem. It happens even more with a generic universal power cord instead of the Sirius brand one.
Apr 16, 2008 | Sirius Starmate ST2 Satellite Radio...
Sportster 4
Dick,
Did u go to the menu to get the Sirius ID# or ESN# or did u get it from the box or back of the unit itself?? I used to work in activations department for sirius and the most common reason that a plug and play unit would not activate is a mismatch in ID #'s. I have seen units with one ID number, but the box or the back of the radio actually being labeled with a different number. By the way,only one signal can be sent to the radio every 20 minutes or so and most reps you talk to don't even know this. So after sending the first signal, all they are doing is clicking a button on the screen and getting a message back that says "Duplicate Provision" meaning that the signal cannot be sent because it is already sent. If you were hearing audio on channel 184 when the signal was sent and you made no adjustments during this time, and the SID or ESN number is the correct one for your unit, and the radio doesn't activate, I would get a replacement. But this never happens in my experience unless there are other signs of defect.
Hope this helps!!
Feb 29, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Starmate 4 acquiring signal
With the antenna plugged in, it may take a minute to aquire the signal. If it takes more than a minute there is a problem with the antenna or the reciever.
Sep 09, 2007 | Rio SIRIUS Starmate Replay Receiver
Sirius XTR1 Receiver cycles on dog screen with beep - keyboard locked
Hello, I had the same problem with my xact xtr1 and I was advised by xact that they have no repair process in works and most likely wont. They did say let it run for 10 minutes and once you have a menu switch to factory defaults which proves to be a worthless fix. I would have to pay $39.95 for a new radio...horrible customer service. The bright side is that Sirius will not charge me the $75.00 transfer fee as a good faith gesture. I have decided to switch to another radio and leave the Xact brand out of the equation, if there is no upgrade or modification to the existing equipment why set yourself up for a future failure.
Aug 05, 2007 | Xact Communication XTR1 SIRIUS Radio...
Sirius Starmate ST2 Satellite Radio Receiver Logo
171 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
