Question about Citizen 8700 BL8000-54L Wrist Watch
My miniute hand has stopped my watch still keeps time and date and day but the ticking minuite hand has stopped at 12 oclock
  • 161 Answers
SOURCE: Citizen eco-drive problem.
Hi Try www.citizenwatch.com for your manual of instructions.
Try Leaving watch in direct strong sunlight or under bright light for at least 12 hours.
Posted on Nov 02, 2008
  • 161 Answers
SOURCE: When setting the date & month the second hand doesn't stop directly under the month.
Hi Try www.citizenwatch.com For full instructions on watch resetting.
escapement
  • 2334 Answers
SOURCE: Watch has stopped
All you have to do is to reset your watch. If you lost instructions, visit this site:
http://www.citizenwatch.com/CUK/English/settings.asp
Enter the numbers or caliber and find instructions how to reset your watch.
Don't forget to rate, please.
Posted on Jan 14, 2009
salinasg
  • 6 Answers
SOURCE: date on my watch
It sounds like your still off by 12 hrs. You can usually set the date between 12 am and 11:59 am on most watches, but the best thing to do in this case is to set the date right after midnight, to be sure.
Posted on Feb 24, 2009
  • 6771 Answers
SOURCE: citizen eco drive watch is brand new, but the
You should take the watch back to the dealer for exchange or refund since it would be under warranty, taking the watch apart will void your warranty leaving you unhappy with your purchase.
Posted on Dec 18, 2010
How to set my movements on my watch
Unscrew, then pull crown out 2 clicks. Spin crown, advancing hands clockwise. Keep turning until you notice the date changing at the 12 oclock mark. This is midnight. Then set time as needed.
Push crown in all the way. Then pull out one click. Turning crown sets day of week and day of month, turning opposite way.
Push crown all the way in and slightly depress as you screw it down until it stops.
Oct 19, 2014 | Renato Mens T-Rex Swiss Quartz Stainless...
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
How do I change date
mcdevito75 here, If it"s just the date on your watch, you may have to pull the stem out to the set position and simlpy keep turning the hands, every second time around to 12" O"clock the date should change it may even be at 1 or 2" Oclock..
Jun 12, 2010 | Timex 27191 Wristwatch
Setting day and date - the day and date change at the wrong tome of day
To sync the correct 12 hour with your day you need to set the date to the day before (if today is Wed 21, then make sure the day window reads Tues 20). Then spin the analog hands until the the date window turns to Wed 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm. The day (Mon thru Sun) sometimes needs to be set seperately from the day; it may take a couple of tries but use the directions above and patience and you will achieve your goal.
That's how you do it. If you need more clarification let me know.
Oct 20, 2009 | Seiko Watches
Cascio
To sync the correct 12 hour with your day you need to set the date to the day before (if today is 21, then make sure the day window reads 20). Then spin the analog hands until the the date window turns to 21. At this point your watch is reading 12 AM (midnight). Then keep turning to set the correct time. If it is 9 am then stop the hands the first time you hit the 9 marker. If it is 9pm, then keep turning until the SECOND TIME your hour hand meets the 9 marker. This is now set for 9 pm.
Aug 07, 2008 | Casio Marine Gear AMW320D9EV Wrist Watch
Crane and Viceroy ladies RC watch
Hi, Klik and Crane & Viceroy are excellent and robust watches, but due to the radio control batteries need to be changed more often than ordinary watches. Instructions for resetting the time on a Klik or Crane & Viceroy watch. With the watch face upwards and the buttons on the right assume the buttons to be; top button - "A", middle button "B" For setting the watch to GMT all hands need to point to 12 oclock exactly. To achieve this press Button A until the hands start spinning. Stop the spinning when the time reaches a couple of minutes before 12 oclock by repressing A. Inch the time forward by repressing Button A until all hands are at 12 oclock.(EXACTLY). Press Button B within 10 seconds and the time will advance 1 hour and stop. The radio signal will be picked up automatically and time will set itself in a few minutes. Notes: If you have radio dead spots avoid these when resetting the watch and do it away from magnetic or large metal objects. i.e. trays etc. If you are refitting a new battery and have a battery that isn't quite dead, do the advancement of time with the old battery and fit the new one near to 12 oclock to get the best life out of the new battery. If for any reason you want the watch to be in radio mode but read a time other than GMT ( no adjustment is needed for BST ), then instead of stopping the watch at 12 oclock stop it at the time in relation to 12 oclock. i.e. if you wanted the watch to read 30 minutes fast then stop the watch at 12.30. if you want any other info my email is; Charles@adept.fsbusiness.co.uk
Jul 15, 2008 | Watches
Tag wk 1113-0
The crown is probably a screw down style. The screw down stem is designed to keep the water out and should be screwed shut when not adjusting the watch. Look at the watch stem from the side, look from the 3 oclock to the 9 oclock, you should see the end of the stem. Now turn the stem counterclockwise. After a number of turns, the stem should pop out a bit, it is now ready to set. Most waterproof automatic day/date watches have 4 positions for the stem:
1: screwed down (locked)
2: unscrewed position A
3: unscrewed position B (stem pulled out to first "click")
4: unscrewed position C (stem pulled out all the way.)
Position A:
This is usually used to wind the watch, although some automatic watches cannot be wound by the stem.
Position B:
Used to set day/date. Turning the stem one direction will advance the day and turning it the other direction will advance the date.
Position C:
Used to set the time. Some watches will "hack," a term used to describe the ability to stop the second hand for accuracy purposes.
Be sure the watch is at least a little bit wound before starting theis procedure or it will not run when you get it set!
Unscrew the stem and pull it all the way out to position C. Now turn the stem to advance the time clockwise. Continue turning until the day/date advances, now you know you are in the AM 12 hrs of the day. It is important not to advance the day/date with the stem during the 3 hours before and the 3 hours after midnight, so go ahead and move the time to 8 am.
Now push the stem in sligthly until you are in position B. Sometimes it is easier to go to position A, the out to position B. Once in position B, advance the day/date until it is set for the current day/date.
Pull the stem out to position C. Adjust the time to one minute past the current time. Watch your reference timepiece until it matches your watch and push the stem in when they match.
Your watch is now set! Screw the crown down and wear it in good health.
Hacking. If you stop the second hand at 0 seconds, and wait for your reference timepiece to reach 0 seconds also, you can set the watch to within a second accuracy.
Movement slop. If you advance the time past the time you wish to set your watch and then "backup" to your chosen time, you will remove the slop from the geartrain and make your watch set more accuretly
Jul 14, 2008 | Tag Heuer 2000 Classic WK1113.BA0311 Wrist...
Klik r c watch.
problem solved.
regards.
Matt.
Apr 17, 2008 | Watches
Set date
hello..this is not abig problem..just a sincronization one...ususlly I set the date around the 12 oclock in the night..the 0 hour..its easier...if you dont want to do this...well..then just count the hours ..remember you have the 24 hours /day..and remember the date is changing in the night around 12 oclock..
for instance...lets say..now you want to set the date..you count the hours until tonight at 12...you put it lets say...with 12 hours back..and wait the change in the midnight..
the easier way is to set it at midnight
oh...by the way..I saw watches which change the date around 2 oclock in the night..but this is a very small %...99% are set to do it at 12..
good luck
Feb 03, 2008 | Seiko SNA553 Alarm Chronograph
Aquatech Sport Chronograph Watch
quickly press the bottom-left button twice.
then, press the bottom-right button once, and then the top-right button once. this should add 1 to the day. keep pressing the top-right button until u get the right day, the press the top-right button again.
now, how do u change the time format back to twelve hr. ?
Dec 20, 2007 | Watches
Citizen 8700 BL8000-54L Wrist Watch Logo
140 people viewed this question
Top Citizen Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Citizen Watch Expert? Answer questions, earn points and help others
