Question about Frigidaire FEF336BC Electric Kitchen Range
No response from the oven control panel.....no lights, clock, nothing Stove top controls work fine.
  • 5,911 Answers
The Electronic Range Control (ERC), also known as an Electronic Oven Control (EOC), controls all the features of the oven. This is your clock/timer assembly. The surface burners work independently of the oven and usually have electrode type igniters that get their power from a spark module. Since you mentioned your clock display is blank, more than likely you have a defective ERC board. The following link explains how to replace one:
http://www.fixya.com/support/r3727366-replacing_control_kitchen_range
A replacement control board can be purchased from any of the following webistes:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: In most cases the overlay (preprinted plastic display covering with all the numbering and lettering on it) does NOT come with the control board. If your overlay is still in good condition, it can be easily removed from the old control board and reapplied to the new one. Just make sure you properly orient the overlay so the buttons all match up. If you need to replace your overlay, you may need to order it separately. Read the part descriptions carefully to see what your replacement parts include.
The part number for a replacement ERC is 316455400, the overlay (if required) is 316220701 for BLACK. The parts are listed as items 20 and 20A, respectively, under the "Backguard" parts listing.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this helps you.
Posted on Aug 23, 2010
GE JS900 electric range stovetop works fine but no lights or clock on control panel so the oven cannot be turned on.
You will probably have to replace the main control board- the cooktop operates independently of the ovens, so your symptom is not uncommon... GE Range Stove Oven Oven Control Board WB27T10416
Jan 09, 2016 | GE Kitchen Ranges
GE Stove tope range not working
If the phenomenon is intermittent, and you get it going and coming as you restart the oven, then it is likely a bad wiring or a bad connection.
Ensure first that the circuit breaker is ok and well in place, then proceed testing wirings.
Check connectors to buners, hobs, and controls panel.
If all wirings and connections are OK, the what reamins is a faulty control panel or a fault on some of the knob controls.
Sep 04, 2008 | Kitchen Ranges
I had new countertops put in and they took they drop in stove out. When complete tegy put the stove back in and everything worked fine. Within 5 minutes the control panel went off. Oven light works and...
The control panel must be on and in manual mode for the oven to work. Turn the power off for a moment and then back on. If the panel starts to flash, set the time and set it to manual and the oven should work. If the panel does not light up it is faulty and requires replacement.
Feb 26, 2011 | Frigidaire Cooktops
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
My oven and stove top in inoperative. the clock,
If everything checks out fine, and you have no wires grounding out, then the issue is the control or circuit board( same thing).
Jan 02, 2010 | Frigidaire FEF366 Electric Kitchen Range
Oven doesn't work, stove does
If it's a Whirlpool or Kenmore oven (or one of several other brands that are made by Whirlpool) then this error code means:
F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC)
The system believes that the control board has failed and needs to be replaced.
This page has a list of diagnostic codes by brand and model number. You should check there to look up your particular brand to confirm what I just said.
Aug 04, 2009 | Ovens
Oven does not work
Open the control panel to expose the clock/oven control.
With a volt meter verify incoming voltage to the clock control.
Check all wires for good contact.
If it still does not work replace the clock.
Remember to unplug the range to check the wires for good contact.
Mar 04, 2009 | GE Spectra JBP78 Electric Kitchen Range
Admiral Electric Oven Control Panel Issue
that is a part number to the clock assy, assuming you have 110v to L1 on back of the clock and no display , that s a preyty safe bet youll need to replace that clock assy
Nov 09, 2008 | Admiral AAV7000A
Oven burnout
replace the oven control
Apr 25, 2008 | Kitchen Ranges
Frigidaire FEF336BC Electric Kitchen Range Logo
209 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
