OCE cm4521 states, trouble code c-3425. How do you reset this / fix this?
2 Suggested Answers
  • 118 Answers
SOURCE: Oce vs. Xerox Recommendation
I can't speak for the OCE model, but I have worked on the WCP 7345 (I'm a trained Xerox tech), and I find them to be very reliable when it comes to recommended repair cycles and overall wear-and-tear of consumable parts.
Posted on Aug 21, 2009
Testimonial: "Thanks, that's the kind of advice I'm looking for. "
My oce fx 2081 trouble code 05 help me pleas
OCE clear error message replace toner oce fx 2081 ... - Fixya
www.fixya.com/tags/clear_error_message_replace...oce_fx_2081/.../oce
Ask your Clear error message replace toner OCE fx 2081 questions. ... ...error code0501 message, though we've vacuumed it the toner as best as possible. ... ...error 2201 switch on/off messages very frequently on my oce 9400 machine, any solution!!! thanks Might be NTC6, which is located in ... 05 is appearing on the.
clear error message replace toner oce fx 2081 Questions ...
www.fixya.com > Forum > Tags
Find solutions to your clear error message replace toner oce fx 2081 question. ... ...error code 0501 message, though we've vacuumed it the toner as best as possible. Well ... ...error 2201 switch on/off messages very frequently on my oce 9400 ...
Sharp ARM 550/620/700 Reset Machine with Error Code ...
Dec 15, 2015 | Office Equipment & Supplies
I have error coad c-3425
If the code comes back after conducting this procedure, do not reset again as the machine can catch on fire that will ruin a perfectly good day call a tech
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Feb 05, 2014 | Konica Minolta Bizhub C550
Hi, oce 3165 machine is giving error 1104,kindly help me get a solution to this
Output OP paper rejection roller drive malfunction.Try to reset the malfunction code to Open/close the front door.If not reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn On the copier.
Keep pressed the Utility key and wait while Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier ,wait 1 minutes and turn ON.
Apr 19, 2013 | OCE 3140 Copier
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Error code c-2152
C 2152 : Transfer belt separation.Check the main motor connector for proper connection,check the image transfer pressure/retraction position sensor and clutch.For reset the error turn OFF the copier press and hold pressed the Utility key and turn ON the copier,wait to Trouble reset message appaire on the display and release the utility key and touch the trouble reset ,turn OFF the copier ,wait 1 minutes and turn ON.
Mar 03, 2013 | OCE Office Equipment & Supplies
Oce Varioprint 6250 is telling me I have paper in the Preheat Unit and TTF. Everything is cleared but it won't reset.
To reset turn OFF tghe copier press and hold the Utility key and turn ON the copier and wait then the display scree trouble reset.Touch the screen and turn OFF the copier,wait 1 minute and turn ON.
Feb 20, 2013 | OCE Office Equipment & Supplies
Aug 21, 2009 | OCE Office Equipment & Supplies
Open Questions:
235 people viewed this question
k24674
jasbo
jasbo
