Question about Dell Computers & Internet
How do i get rid of several vertical lines down the screen of my dell laptop
  • 942 Answers
There is only one way to get rid of vertical lines on your desktop, that is to reseat the video card if the card is separate with the motherboard. Otherwise, you need to call a technician to check your laptop for repair. To check if the video card is separate, turn off the laptop, remove the cables and battery, press and hold power button for 8 secs, remove the screws inside your pc, remove the hard drive, remove the optical drive, remove the fans & heat sink, remove the power supply. Then check if the video card is embedded on the motherboard or not.
Posted on Aug 23, 2010
How to get rid of white vertical line on my laptop
may be an bug in the os or driver or hardware damage check it
Mar 21, 2013 | Dell Computers & Internet
I have a black flashing vertical line running down my screen. How do I get rid of it?
I think I might have the same issue. I have an NV7919u and I have noticed that several times after emerging out of "hibernation", the screen has columns of strange looking black lines from top to bottom of the screen.
What I have found is that if I open an application or maximize one that has been minimized, it clears the screen. I am sorry that I can't help much more than that but I am also looking for the cause in the event I had an opportunity to repair it...!
May 24, 2010 | Gateway NV7923u 173Inch Laptop (NightSky...
White lines in my laptop's screen
its your screen problem of your laptop pls change it,
Apr 15, 2010 | Dell Inspiron 6400 Notebook
I have several verticle lines on my screen, how can I get rid of themm?
Vertical lines on your LCD usually tells you that your screen is failing. You can do a quick verfication by plugging in an external monitor - and if the external monitor looks normal, then that ought to confirm it.
Once you have vertical lines on your screen, there's no way to get rid of them - it's pretty terminal unless you're into repairing microelectronics. For replacement screens, eBay would probably be your best bet.
Mar 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
How do i get rid of vertical lines in my latitude d820 laptop
try to update BIOS and uninstlal reinstall video driver. connect external monitor to check if have same problem. perform Built in self test on LCD - to do it, make sure computer is off then press and hold "D" and press power button. if still have vertical lines on screen, need to replace LCD
Feb 20, 2010 | Dell Latitude D820 Notebook
Vertical colored band down right side of monitor
you may haave a bad disc capacitor. they are little round , mostly tan , soldered onto the board. when the go bad you usually get a line down the screen. youw ill have to replaace them one at a time till the line is gone. you may also have a bad screen.
Nov 29, 2009 | Dell Computers & Internet
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Vertical red line in display
I had a similar problem with a flat screen lcd for my desktop comp, and it turned out that I needed a new screen if i wanted to get rid of it, but it doesnt really cause much of a problem, so i didnt bother replacing it. If your laptop is still under warranty, (i dont know how long your warranty lasts) I'd look into getting it replaced if it really bothers you. But yes, its definitly the screen.
Aug 08, 2008 | Dell Latitude D505 Notebook
Computers & Internet Logo
135 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
