Kenmore 60 series top loader will not empty - Washing Machines
  • 5,911 Answers
The most common cause of the problem you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price of a replacement lid switch is about $25 - $35 if you perform the repair yourself. The lid strike is usually less than $5. Prices will vary between sites so shop and compare.
Another cause of a no drain issue can be a clogged drain pump or drain line. The following link explains how to access the drain pump and replace (if necessary):
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
These pumps are strictly mechanical (no electrical connections) and have one moving part - the impeller. You will need to remove the drain lines to inspect the pump interior as these pumps do not come apart. Check the drain lines and impeller area for any lodged items.
CAUTION: You will need to drain the wash tub PRIOR to removing any of the drain lines. A quick and easy way is to use a wet/dry shop vac to remove the water. If you do not own a shop vac, simple gravity will work by placing the drain hose on the ground and allowing the water to run out. If this is not feasible because of the washer location, you will need to bail.
If you have questions, or need additional assistance, please post back with your complete MODEL NUMBER and let me know. These are very simple repairs that you can easily perform without the assistance of a repairman.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Aug 23, 2010
I have a Kenmore 500 series top loader and after I do a cycle with bleach it will still get bleach on next load. Why is that?
ou are best run a quick wash on an empty machine after using bleach there is always water left in machine
Oct 14, 2014 | Kenmore 500 3.5 cu. ft. Top-Load Washing...
Kenmore top loader washer - No spin - motor rattles - wtr pmp ok
Bad/broken coupler/ http://www.davesrepair.com/DIYhelp/DIY285753.htm
Sep 01, 2009 | Kenmore Washing Machines
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Jun 27, 2009 | Kenmore 22422 Top Load Washer
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Where do i put the softener
some model units do not come with a softner dispenser, ask sales rep at sears it might have been an upgrade model in the 90 series that had that dispenser??
May 16, 2009 | Kenmore 23012 Top Load Washer
Kenmore Washer Top Load Series 60 won't drain
The water pump is a belt-driven device actuated by a clutch. Your problem could be:
1. Stuck pulley - break it loose and WD-40 it
2. Broken belt - replace
3. Bad clutch - call repair or replace
There is almost nothing that can go wrong in the pump itself. It's probably one of these three.
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Same problem
ck lid switch blocked pump would not prevent spin unless it was locked up then probably wouldn't agitate either
Jul 20, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
