Question about Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
I have a Craftsman brand shop vac [model # 113.77420]. It is still picking items when I sweep with it, but it has developed a very high pitched squealing sound whenever I turn it on. The sound makes it almost impossible to use. Any thoughts? Thanks, Bruce
I have the same problem with a CTC Shop Vac. It's he bearings ... they're worn out and dry ... no lubrication. I've trid taking the motor apart and lubricating the bearings, then it runs super for a few uses but then the squealing starts again. Oitch it and buy a new one.
Posted on Oct 12, 2010
Shop vac whistles
If you let it continue, you will have a piece of junk. You take the bolts off holding the motor cover on and you lubricate the upper bushing with oil. They are oil impregnated bushings and will soak up a thin type oil best and last longer. Use 10W or 3-in-1 oil or Marvel Mystery oil.
Jan 01, 2014 | Shop Vac Vacuums
Who made craftsman wet/dry shop vacs in the late 70's?
here is a link that may be helpful
http://vintagemachinery.org/craftsman/manufacturers.aspx
it details the manufactuars that craftsman used based on then model and OEM number
Feb 08, 2013 | Vacuums
NEED TO REPLACE BLOWER FAN FOR CRAFTSMAN SHOP VAC. CAN IT BE DONE?
Yes it can. Below is an item # for a 2HP motor being sold on Ebay: Item number: 280564320553.
If yours is a different HP, do a search on Google for "Shopvac motor replacement". I also recommend that you call sears - maybe your vac is still under warranty? Good luck.
Sep 27, 2010 | Vacuums
Dust shoots out the back of my shop vac...
Use collection bags or change the filter.
Jun 04, 2010 | Vacuums
Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
I do not have my users manual and have never vacuumed wet with this vacuum. How do I change it from a dry to wet vacuum. Can't find my manual and I need to use the shop vac for water in basement, do I...
Vacuuming Liquids
1. When picking up small amounts of liquid
the filter may be left in place.
2. When picking up large amounts of liquid
we recommend that the filter be
removed. If the filter is not removed, it
will become saturated and misting
may appear in the exhaust.
3. After using the vac to pick up liquids,
the filter must be dried to reduce the
risk of possible mildew and damage to
the filter.
4. When the liquid in the drum reaches a
predetermined level, the float mechanism
will rise automatically to cut off
airflow. When this happens, turn off
the vac, unplug the power cord, and
empty the drum. You will know that the
float has risen because vac airflow
ceases and the motor noise will
become higher in pitch, due to
increased motor speed.
IMPORTANT: To reduce the risk of damage
to the vac do not run motor with float
in raised position
May 06, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum Logo
1,183 people viewed this question
Top Shop Vac Vacuums Experts
Mike
Jim Parker
Jim Parker
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
