Question about Jensen VM9410 Car DVD Player
MY JENSON VM9410 IS SAYING INCORRECT REGNAL CODE WHEN I INSERT A DVD HOW CAN I SOLVE THE PROBLEM
  • 3 more comments
  • biggy786 Aug 23, 2010
    HI STEVE THANKS FOR THAT I HAVE TRIED THAT THE SETTING IS ON AUTO AND I CHANGED IT TO PAL AND TRIED THAT BUT IT STILL COMING UP WITH THE SAME THING
    I HAVE TRIED CHANGING THE SETTING TO PAL AND AUTO BUT STILL SAME PROBLEM ICORRECT REGNAL CODE WHAT CAN I DO
  • biggy786 Aug 24, 2010
    THANKS 4 THAT THE CAR IS A IMPORT I THINK THE UNIT WAS FITTED ABROAD DO U THINK IF I TRY A VCD INSTEAD OF THE DVD WOULD THAT WORK IT PLAYS CDs BUT TITLE DOES NOT COME UP
    THANKS ALOT FOR YOUR HELP PROBLEM SOLVED I JUST TRIED COPY DVD IT WORKS FINE I AM REALY HAPPY MY KIDS CAN WATCH THEIR DVDS KNOW THANKS AGAIN
    THE EXPERT WAS REALY HELPFUL MY PROBLEM IS SOLVED I WILL RECOMEND THIS SITE TO EVERYONE I GIVE THIS SITE FIVE STAR RATING THANKS
  • Jensen Master
  • 11,800 Answers
DVD's have in them an anti piracy code. If the code from the disk doesn't match with the code from the unit then the unit will refuse to play it. It's impossible to change that code on your unit so you must be sure that all the disks you will try to play have the same region code.
Posted on Aug 23, 2010
  • Azrael SRL Aug 24, 2010
    The region code is inserted only in original dvd's. VCD's and personal copies of dvd's will work just fine.
    BTW for the title to come up it must be in the file properties of the mp3 and the unit must be able to read it .
  • 1,675 Answers
Hi, depending on the region of the cd/dvd it should automatically choose the type. ie, ntsc or pal, as these are the only regions it plays, anything else is incompatible with the unit, if you would like to find out more, or maybe you might want a second opinion, you can call the number below for clarification...hope this helps please rate this thanks Audiovox Electronics Corporation 150 Marcus Boulevard Hauppauge, NY 11788 Technical Assistance: 1-800-323-4815 these are the people who manufacture your unit
  • steve morris
    steve morris Aug 25, 2010
    i read up on these systems, and what i can see is, that if lets say it was from America, the vehicle it is in, and that is where it was purchased, that is all it will play, apparently they are set to a single region , i did also check in my memory bank of dvd player regional codes to make them play any, and there is not one for this system either, so it looks to me that you are not going to be able to change it..
Jensen DVD player (JDVD 4301) does not show picture when DvD is inserted. Message on screen "Warning Stop Watch Video" display on blue screen although I can hear the movie playing. Did I connect...
Jenson requires the green wire to be connected to the vehicle parking brake.(Safety feature) this green wire requires a negative switch to activate the screen.
Jul 29, 2011 | Car Audio & Video
I had the ground wire and the yellow power wire com out of the back of my jenson vm9410 what places do the go back in?
the yellow wire needs to goto a permanant power source such as the battery or a wire that stays live, the ground wire needs to goto another ground wire, or to a part of the car frame.
Jan 12, 2010 | Jensen VM9410 Car DVD Player
When the disc is loading it stops and says
pls. check regnel code seting .
use remote cantrol on setup menu open and selact regnal code set Adealt . or all regnel code after then use disc is play caractly
if not then problum is inside your disc player .
Use. lance clenar disc and clenig your disc player lance.
Oct 20, 2009 | Venturer 3.6" Portable DVD Player
Bypassing E-Break
Just connect the emergency brake wire to earth (vehicle body)
Jun 17, 2009 | Jensen VM9410 Car DVD Player
Pe-wee dvd codes
i am looking for bypass code for a xdvdn8190 can you please help me.
Aug 03, 2008 | Jensen VM9410 Car DVD Player
Audio problem
I'm not sure about the cd's and dvd's getting ejected, but you can ground the parking brake wire to any ground in the car and you will be able to watch ur movies.
Mar 30, 2008 | Jensen VM9410 Car DVD Player
I dont have a code 4 my jensen vm9410 i need 1
wire the parking break wire from the deck to the ground and it will work like a charm, until your crappy vm9410 all of sudden won't turn on any more :( It seems no one has a solution for that PROBLEM!!
Feb 03, 2008 | Jensen VM9410 Car DVD Player
GPS
Probably not or not worth the bucks to do it.as these radios are made with the componets for GPS and are active so they can be used, So the manufacturer wouldnt install a board with gps on it and not acytivate it. And to get this in the radio you would need to change the entire RF board assy. But just for giggles you should try calling Jenson at the # in your owners manual or at this # 888-866-5487 Good Luck
May 25, 2006 | Jensen VM9410 Car DVD Player
Unknown cd
This could be a case of one specific bad disc or If this is a non original CD(Burned CD/DVD) some DVD players don?t support burned media If it?s happening with all you?re Cd\s DVD\s It could be a problem of dirty lance In this case a CD lance cleaner could solve the problem
Jan 18, 2006 | Jensen VM9410 Car DVD Player
Jensen VM9410 problem
two things might be wrong is there 12 volts and is there a good ground . hope this might help.
Jan 03, 2006 | Jensen VM9410 Car DVD Player
Jensen VM9410 Car DVD Player Logo
202 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
