Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Top oven toast function not operating/element not burnt out but will not heat
  • 6 more comments
  • crobak Aug 23, 2010
    How do you open the cook top to locate the fuse
    have located circuit diagram part/file 8119p133-60. unable to read to determine if fuse is in line for toaster, can you assist
    upper broil element not functioning when broil request entered, it may be effected by the fuse also. How is top opened to assess if fuses located there
    Thanks for the fuse info. the diagram has a sq. with zig zag line inside a box . Is that the fuse indicator? and if so the upper broil element is fused and i"m assuming it also controls the broil/toast function.
    if you have access to service manual16023417 7/04 Please assist with top removal instruction
    WHERE IS FUSE PANEL ON JENN AIR JDR8895AAS
    Back panel and top removed . What will a fuse look like as i see no breaks in the wire which would indicate an inline fuse. No fuses apparent on main circuit control board, no fuses sold from parts list from jenn air
    no inline fuses visible, back panel off cook top off nothing that appears to be a fuse is visible what gives?
    Genius:
  • 1,478 Answers
The fuse on the oven may be burnt, this will not allow the oven to be hot, while other parts will be functioning. Check your owner's manual to see if your oven ignition system has a fuse. some are located under the cooktop, though locations vary. Replace it with the same size fuse if the fuse element is burnt.
Take care.
Posted on Aug 23, 2010
My calphalon toaster oven will not toast top of bread? Why?
The upper heating element may have failed or the toasting function may not have been selected.
Oct 06, 2014 | Calphalon Convection Oven, Extra Large
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
Oven won't brown food properly
sounds like the upper element is burnt or the fuse is burnt.check the fuses first,by opening the access panel at the top and rear of the range,check the fuses to verify that they are good,if okay then open the oven door and remove the element and inspect the contacts and element for burn marks or breaks.if so replace either the element or the burnt contacts.
Nov 21, 2011 | Kitchen Ranges
Grill is not working
Is The small amount of heat you are getting coming from the bottom element in the top oven or is half the top Grill element working.To start with you have a double grill element and either the whole element has gone or just half the element.This is controlled by a selector switch which could be at fault or the Thermostat that controls the temperature.
Hope this helps.
Jul 07, 2010 | Electrolux Insight EKC6049X Stainless...
Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
It appears that the ring element for the oven has burnt out and will need replacing.
Hope this helped.
May 13, 2010 | Ovens
Burnt pie
YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
Apr 13, 2009 | Toaster Ovens
Top element broken
Oster 6233 toaster oven top heating elements don't work
Nov 11, 2008 | Toaster Ovens
Toaster does not work!!!
I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Black & decker toster oven
Black and Decker Toast-R-Oven Countertop Oven/Broiler Mfg Part No: CTO650
same problem here, toaster works, then when I go turn on the oven ........nothing!
Oct 29, 2007 | Black & Decker CTO649 Toaster Oven with...
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
102 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
