Question about JVC Ks-U58 Input Adapter To Stereo Mini Plug
My jvc kd-sx995 car stereo wont recognise my ks-u58 aux input adaptor in the stereo manual it says it needs a ks-u57 would my adapter also work or do i need to replace it. \r\nps. current adapter in perfect condition
3 Suggested Answers
SOURCE: diagram for adaptor ks-u57
There's nothing to it--look 'inside' the connector and you'll see three metal contacts close the metal connector (somewhat similar design as a USB jack). The center is common for the line out, and the left/right are the positive for the left and right channels. The metal connector itself is not part of the circuit.
So if you were connecting RCA jacks to it, the outer ('negative') of both RCAs connects to the center contact on the KS-U57, and the center ('positive,' or 'signal') of the left and right RCAs go to the contacts bracketing the center.
KS-U58 and KS-U57 are wired the same.
Posted on Jul 30, 2010
  • 9 Answers
SOURCE: jvc model kd-g502 in my car it has an ext adaptor
1. Press and hold SEL till the preferred setting mode (PSM) comes up. 2. Scroll through the modes till you see EXT IN (You may need to set CD as the Source to see this.) 3. Adjust the value by moving the knob around the SEL button. 4. You should now see LINE IN.
Good Luck
And let me know how you went?
Posted on Mar 05, 2011
Jvc firmware
If you are using adapter, KS-PD100, it is possible that new iPods wont work with this older adapter, I would recommend to connect your iPhone via AUX on the front of the unit
Jul 30, 2014 | JVC KD-G421 CD Player
My JVC KD-G310 won't switch to EXT IN after plugging in a KS-U58 cable (j-link to 3.5mm connector) into the external component port. How do I get this set right?
did you ever figure this out? i just replaced a broken KS-U58 cable on my JVC KD-G310 and now i can't get it to switch to EXT. everything else on my stereo (CD, radio) works fine.
Jun 10, 2011 | JVC KD-G310 CD Player
Jvc model kd-g502 in my car it has an ext adaptor ks-u57 at the rear of the unit for c/d changer or other ext device. To operate ext device "line in" must be displayed on the screen in order to...
Good Luck
Mar 05, 2011 | JVC Ks U57 Line In Adapter
Diagram for adaptor ks-u57
Oct 31, 2009 | JVC Ks U57 Line In Adapter
JVC car radio looses configuration and stations when car is off
Sometimes positive and the switched positive are switched round on some cars. normally red and yellow but check first with multimeter
Aug 02, 2009 | JVC Ks-U58 Input Adapter To Stereo Mini...
How do you turn off the demo on the jvc car radio
Hello gusjandreau,
Press and hold the SEL button until the receiver enters the PSM mode (until the display changes). Use the left/right rocker switch until the display reads DEMO. Turn the volume knob until display reads DEMO OFF. Briefly press SEL to exit PSM mode.
Hope this helps.
Jul 22, 2009 | JVC Ks-U58 Input Adapter To Stereo Mini...
KS-U58 JVC Input Adapter Cable
Just installed a 'generic' KS-U57 (same as the KS-U58, but terminates in a RCA, $7 on ebay) that has the same black box--except I cracked the black box open and found that it is empty (only contains soldered connections). I imagine that the authentic JVC is the same.
I have a noise problem (engine static), but it is because my mp3 player is charged by the cigarette lighter--unplugging it eliminates the noise, so as far as I can tell, there is no need for a noise filter inside the KS-U57.
Dec 04, 2008 | JVC Ks-U58 Input Adapter To Stereo Mini...
Does not switch to Ext Input
You have to enable "Line in" in the Stereo menu. Once you enable it when you press CD/CD-CH it should change to "Line In" and display Line in on the screen. Check the manual on how to enable line in...
Jan 30, 2008 | JVC Sirius KD-LH300 CD Player
Using an external mp3 player on my JVC KD-LX111
You could try using an FM transmitter which plugs into the earphone jack on your Mp3 player, then all you have to do is tune the radio to pick up the transmitters frequency.
Nov 13, 2007 | JVC KD-LX111 CD Player
JVC Ks-U58 Input Adapter To Stereo Mini Plug Logo
96 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
