Question about Casio Watches
Current time not displayed only parts of figures
  • 831 Answers
CASIO has a wonderful support program on their website. I would see if your issue is there or contact them at:
http://www.casio.com/support/techsupport/timepieces
Posted on Aug 23, 2010
How to set for 24 hrs.
Dec 29, 2015 | Watches
Diesel DZ7221 Time 2 not displaying
same here after getting the stem replaced under warranty, now the digital time is blank... is there a separate battery for the digital time?
Nov 30, 2012 | Diesel DZ7221
I just bought an adidas ADH4033. I have read through the manual thousands of times and have figured out how to change the hours on the watch but still cannot change the minutes, date, 12/24 hour, or any...
this might help. press and hold top right button to change to T1 or time 1. press and hold top left button and u will see ' light on/off' on display. press bottom left button to set chime. press again watch will show 24hr/ 12hr and current time set on watch. 12hr/24hr should be blinking. press top right button to change to preferred hour. press bottom left button to navigate to hour, min,sec use right buttons to select numbers.
Aug 27, 2011 | Watches
I cant figure out how to set time and date
Hi idarr,
Please follow these steps to set the time and date of your Armitron Digital Sport #40/8125BLK Watch.
1. Press the MODE button once. This will put you in the timer.
2. Press and hold down the MODE button. This will put you in the alarm set display.
3. Press the MODE button once more and it will put you in the time set display.
4. Use the ST/SP button to change the blinking portion of the time. Then use RESET button to move you thru the different parts of the time/date.
Hope it helps.
Thank you for using FixYa.
Mar 13, 2011 | Armitron 40/8125BLK Digital Sport Watch
I want to change time zones on my casio edifice. I can't work it out.
Press the button on the top left-hand side of the watch until the display shows the current hour and the letter "P," "M," "C," or "E" which indicates the current time zone. (Pacific, Mountain, Central or Eastern.) If the time zone is not correct, press the button on the top left-hand side of the watch until the correct time zone is displayed.
Feb 28, 2011 | Casio Watches
How do you set the time and date for a pokemon c watch form trend setters?
you press down on the two buttons on the right as hard as you can until it shows the time settings. It took me a long time to figure it out but i was super excited once I got to set mine xD Hope that helps!
Jan 04, 2011 | Watches
I purchased a Ollie Watch OLK90001-1 and the instructions that came with the watch are not the correct ones. I cannot figure out how to change the time. Please advise. Thanks!
For most ollie watches, hold down the lamp/adj button until the display starts flashing. Then, use the mode button to select what part of the time you want to change (hour, minute, day, etc). Use the start/stop button to increase the number.
Dec 25, 2010 | Watches
I have bought a couple of lupo watches but there are no instructions so I dont know how to set them to the correct time can you help
This LUPO anion watch emits negative ions and infrared which make you calm. It soothes and relaxes your mind. How to set the time and date: This unique watch can display month, date, time & minute. 1.Press A button twice. (Date and Time displays when press once) 2.When the month figure appears, press M to set the month. 3.Press A button once again, the date figure appears and press M to adjust the date. 4. Press A button once again, the hour figure appears and press M to set the time. 5.Press A button once again, the minute figure appears and press M to set the minute. When you adjust one of among the month, date, time, minutes, just keep press A button until the desired figure appears and press M to adjust. Press M to see the date. Generally A button is to select the function. (Month, Date, Time, Minute) M button is to adjust the function.
Dec 09, 2010 | Watches
Reset watch
Hi
Thanks for using FixYa. You can set the time on your accurist watch by following this procedure--
TIME SETTING--
1. Push the bottom right hand button until the mode hand indicator points to TME.
2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position.
3. Select the time zone on the digital display by pressing the upper right button or the lower left button.
4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time.
5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00.
6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time.
7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time.
8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour.
9. Push the lower right button back in.
SET THE CALENDAR--
1. Push the bottom right hand button until the mode hand indicator points to CAL.
4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month.
5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date.
6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year.
7. Push the lower right button back in.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 31, 2009 | Watches
WATCH
Press MODE 5 times until you see H-SET on the right side of the dial in the box. Then press the ADJUST button. You will now notice the current TIME you have already set on your watch will appear in the box and flash where H-SET was. This will help you know what time to set the hands on. While holding down the FORWARD button you will see the hand start to move. I could not move mine in reverse, only forward. Simply set the time and you are finished.
Jul 18, 2008 | Casio G-Shock G511-1AV Wrist Watch
Watches Logo
21 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
