Try 1023
Hello. Here is a link to a free manual for you to download. Just follow the instructions on this link. http://support-manuals.com/search.php?cmarque=TRUTECH&modele=TT320
What is the remote model #?
Thanks!!
Trutech is a product from dawoo. Use the following Dawoo codes: 10451,11661, 10092, 10672, 10019, or 1062.
Here is a somewhat generic instruction set to program your remote:
Trutech is a daewoo product
For Trutech tv owners try the codes under Goldstar tv brand. Or such
other brands as , AOC, Candle, Envision, Kenwood, Nec. In UEI made
remotes, its code 0030.
You can program the remote without codes as well:
If your brand is not listed at all, you may wish to try searching for
your code. To search for a code for your television:
1. Turn on your television set.
2. On the remote control, press [TV] once, then press and hold [SETUP]
until the [TV] key blinks twice. Once it does, release [SETUP].
3. Enter 9-9-1. The [TV] key will blink twice.
4. Aim the remote control at the television and slowly alternate
between
pressing [POWER] and [TV]. Stop when the television turns off.
5. Press [SETUP] once to lock in the code.
Try pressing and holding the setup button for 5 slow seconds. Then press the power button slowly and repeadedly until the unit shuts off, then press the set or enter or ok button to store the code.
thanks, that was a good try , no results . I found these numbers inside the battery cover . is this the remote control model # (j x-8006 c ) hope so R.J.
when will you reply to my 8/23 question?
my tt remote has a power and setup no tv button . please more info . R. J.
solution #2 did not help . My remote is (not universal ). It is a trutech w/ setup , power, but no ( tv,vcr) button. The dvd player is a tt320 trutech. The remote has no model no. on it, just the name trutech. thank you, R. J.
the remote is a trutech. (no model # on it) it is the remote for the trutech model tt320 dvd player. thank you ,R. J.
the remote is a trutech, (no model # on it) it is the remote for the tt320 trutech dvd player thank you R. J.
remote #j x -8006-(c)
remote control # j x -8006 (C)
