Question about Maxtor OneTouch 4 Mini 160GB External USB 2.0 Hard Drive
When i plug my drive in..it starts making a scratching sound and doesn't open on my computer..what should i do? have i lost everything?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 198 Answers
Suggest downloading Seatools from Seagate's website which may be able to diagnose or repair it. It can also advise as to whether it is still in warranty
Posted on Dec 13, 2010
How do i remove everything off of my dell inspiron 531s and start from scratch
Open the command prompt. If you do not see it go to run and type in "cmd.exe" then hit enter. when you get to the screen type in "C:\format" if that doesn't work try "format c:\\\" This will literally erase everything on your computer and allow you to completely start from scratch.
Dec 20, 2011 | Dell Inspiron 531 Athlon 64 X2 4400+...
I have the SimpleTech Pininfarina 320GB Hard Drive and was working great for a while. Then all of the suddent it just stoppped working. The light doesn't come on anymore on the unit. I've tried...
Hi Angela ,
You' re probably facing a power or usb issue . Consider opening the enclosure ( will be lost , i presume ) and placing the drive in an external usb box ( available in any computer store starting from 20 $ ) to be reconnected to your pc . If this doesn' t help , it means your device is dead . There then still is a small opportunity to recover the lost data by using a recovery software like Recuva ( free ) or TenorShare Recovery ( payable ) .
This should help you solving your issue .
Best regards ,
fanaudi .
Sep 28, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Rear right speaker doesn't work, no matter what we tried. We switched the speaker and cables with one of the others, but just that position (surround right) doesn't work.
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there also if you have the right ones selected
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Sep 09, 2011 | Spherex Xbox 5.1 Surround Sound System...
The pc does not detect the usb drive, the usb flashes. But nothing comes up
Make sure it is inserted all the way into the usb port. If nothing comes up, this doesn't mean it isn't connected, it just means autoplay isn't on. Once it is plugged in, go to the start menu > computer. This will open a folder with all your drives, both internal and external. Double click on your flash drive's icon to open it.
Jul 03, 2011 | SanDisk 32GB Ultra Backup USB 2.0 Flash...
Loaded everything onto drive, now computer doesn't recognize drive when connected.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 25, 2011 | Iomega HDD Portable (32379) 30 GB Hard...
Scratching sounds coming from laptop
There is lint or small scrap of paper rubbing on the cooler fan.
Without disassembly, Blow compressed air into the exhaust port while power is off, this might dislodge the debris.
Otherwise you have to remove outer cover and clean out that way.
Jul 29, 2009 | Toshiba Satellite A135-S4527 Notebook
Transplanting Scratched Hard Drive Pallets?
NO IT WILL NOT BEST BET is you've lost your data as the scratched heads and exposure render it close to imposible for you to recover data the only way is to call a data recovery outfit for a solution .
good luck
Mar 28, 2009 | Western Digital My Book Essential 500GB...
From few month i ahve a problems of my harddisk. i have a problems on my hardisk here is my problems 1. scratch sound comming from my harddisk. 2. slow a booting up the system. thats all
Sounds like you have a DIEING Hard Drive.
Go into:
MY COMPUTER> (RIGHT CLICK) C:/ DRIVE> TOOLS> THE FIRST (TOP) CHECK NOW BUTTON AND WHEN OPEN TICK THE UNTICKED BOXES> RESTART COMPUTER AND LET WINDOWS CHECK FOR ERRORS. DO NOT CANCEL
If any problems are fixed and HDD still making noise take it to a Computer SHop where the people will check it out.
HOPE THIS HELPS
Dec 26, 2008 | Rane Serato Scratch Live Computer DJ...
Computer Sound Sporadically Cuts Out
i would advise trying the sound card in a different computer. it may not be possible for you, but maybe you have a friend that will let you try it on their computer. also, can you make the problem come and go by wiggling the connection? on my computer i have to have the wire just right or i lose the left speaker. i think you can solve this without having to reformat. what about headphones? do they work when plugged into the headphone jack?
Oct 15, 2008 | Computers & Internet
Simpletech 320gb hard drive
the hard drive inside of the external device is damaged. probably the drive head scratched one or more of the platters inside of the drive. this is a common occurance with laptops and computers when they take a dive off of a desk.
need to either get a replacement drive or another external hard drive.
Jun 21, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Maxtor OneTouch 4 Mini 160GB External USB 2.0 Hard Drive Logo
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
