Question about ASUS Computers & Internet
How to set up a password on ASUS RT-G32 wireless router so others cannot access my internet services.
  • ASUS Master
  • 4,134 Answers
Open a browser. Type in the router IP 192.168.1.1. Login to the router using your user id and password. If you have never set up a user id or password, then use the factory default ones to access. Once into the router settings, change the admin password to avoid anyone later accessing the router and changing your settings. Once you save the admin password change, you will be kicked out and must login again with the new password. Once in, go to wireless settings. Here you will able to set a wireless password (security key) for your wireless LAN. Once you save and exit, you will need to go to all your wireless devices and modify them with the security key in order for them to access the network. Once the key is in the router, your network is secure from outsiders getting in without knowing the key.
Posted on Nov 04, 2016
5 Suggested Answers
SOURCE: Hi I am using ASUS router
My asus rtg32 wifi wireless router is not getting connected to net. It shows connected (router with laptop) but its not connecting to net. I am not able to openany site. I m using BSNL connection. It shows no internet access.\r\n
Please suggest me what to do, what procedure to follow. Mine is windows 7 , 32bit OS
thx
shubham
shubhamformeATgmail.com
Posted on Feb 09, 2011
SOURCE: Hi, I bought Asus Wireless
You need to enable WEP or WPA or WAP in wireless security. For that access your wireless router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless then wireless security then enable WEP security enter Password then apply and save settings then restart router . Then only those can connect who know that password. . Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 09, 2010
  • 80 Answers
SOURCE: How do I get the
For Windows XP/VISTA/7 users:
1. Click Start>All Programs>Accessories>Command Prompt
2. A command prompt window will appear and type: ipconfig /all
3. Scroll down and look for "Physical Address" then look across there will be a set of 12-digits that looks like this XX-XX-XX-XX-XX-XX it can have both letters and numbers in it like this: 00-21-EA-13-91-25.
That will be your MAC address.
Posted on Oct 04, 2010
  • 59 Answers
SOURCE: when i try connecting my
try reinstalling the router then it would ask you for a new network key
Posted on Feb 14, 2011
I have Asus RT-G32 and it works max 10 mbits. How can I change it's speed to 54G
its your ISP that limits you. you probably have a 54G connection between you and your router and a 10mbits connection to the internet. so, when you run a speedt test you show 10mbits...
your service is working fine...
and FYI: when you do a download and it says your downloading at 56k or something that has nothing to do with you or your ISP, thats how fast the person hosting the file can send it to you.
yup, the internet is one bottle neck after another!
Nov 14, 2013 | ASUS RTG32 Router
Hi, I have got RTG32 router installed for a small business (5-6 ) machines .From machines I can see and update router settings but I can't see internet line working from router. Internet is working...
Do you use a username and password provided by your ISP on the computer to connect to the internet? If yes, these need to be entered into the connection settings of the router. Are you connecting the internet line to the WAN port on the router? Did you install to your computer the ASUS utilities? Try the EZ Setup utility. You can download the manual from this link http://www.asus.com/product.aspx?P_ID=gEbdYWdf5mjkJUKc
Mar 09, 2011 | ASUS RTG32 Router
When i try connecting my ASUS wireless router model no: RT-G32, it is asking for network key
Feb 14, 2011 | ASUS RTG32 Router
Forgot asus RT-G32 router login password. How to change the password?
You must perform a factory reset using the reset button on the rear the device. You will then have to login using the factory default user id and password, create your new password, then reconfigure your router to your system as all settings were reset to factory defaults.
Dec 19, 2010 | ASUS RTG32 Router
Hi I am using ASUS router rt-g32 . whenever I connect my inernet via ausu it is not working but through ADSL modem internet is working fine. please help.I have reinstall and instaleed software of ASUS...
thx
shubham
Aug 14, 2010 | ASUS RTG32 Router
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
I lost my wireless router setup cd and cannot make it work! Please help!
You can set your router settings without disk too.
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
If you need user name and password for connect to your service prtovider then configurayour router as PPPOe .
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Feb 08, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
Computers & Internet Logo
795 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
