Question about SanDisk Sansa View 8GB MP3 Player - Black
My Wheel Rolls EXTRA Slow!
I only had it a few months. I dont hardly play it. I keep it in my purse all the time. Me and my sister have the same exact one. Her wheel glides. My Wheel rolls slow....If I put alcohol around the wheel then it glides, If I dont then It rolls extra SLOW
I need some suggestions
Thanks
--Kayla
  • Mickeyfasho Jun 26, 2008
    Thank You Soooo Much. That really did help alot!
Hey Kayla,
I had the same problem. What happened is i left mine in my car while i was working. This was not the first time either and when i got out of work in the late afternoon i noticed my sansa's wheel was incredibly hard to turn. I went home and searched for solutions and found your very same problem. I went downstairs and found that my dad had a pressurized can of Super Lubricant. 1 small, quick shot directly onto the wheel top and button got the spray lubricant on there good and i just wiped the excess lubricant into the wheel seams. Immediately start turning the wheel in either direction (try to switch back and forth) and it'll start to spin freely. The Heat of an enclosure like your purse or my car in the sun dries out lubricants just like the lube sansa applies in their factories to these products so just try this and tell me how it worked for ya if you still have it.
Sincerely,
Ben (belmont1@gmail.com) ( :
P.S. stop applying alcohol. That's more of a cleaner and all it will do is temporarily fix the glide sticking problem while simutaneously drying it out. Bad method...go with your every-day spray-lube.
Posted on Jun 26, 2008
If my son has XBox Live Gold Membership do we just need an internet connection to play or do we require extra GB per month to play?
The xbox live gold membership is paid for when you buy it. It never runs out until you have used all of the time you bought. Like say you bought a 12 month subscription it will last you the whole year until the day you bought the last one and activated it. Only time you use money is when you want to buy something from xbox live. All you need is the internet wifi or direct cable works. You can actually use your xbox live account on any xbox. Say if his friend has an xbox and has xbox live he can then use his account on his friends xbox to play online with his friend. You dont have to worry though every time he goes to an xbox he has to recover his xbox live account info so no one else can use it while he is using it. There is also a few new updates to keep his account safe as well when he does want to do something like that. also you can go into family settings and make it so he cant buy anything with out a pass code even put a timer on it with a pass code to limit time of play. So inclosing no you dont have to buy GB it just uses your internet connection and it does cover the cost of play for as long as you bought the subscription. Hope this helps :)
Feb 22, 2014 | Microsoft Xbox 360 Console
What do i do?
It has more to do with the device memory when your talking about it running slow , if she has a lot of music or media advise her to move them to the SD card instead of keeping it on the device memory itself .
Dec 29, 2013 | Tablets & eReaders
Hard to handle when idling slow
Hi Anonymous, and the usual suspects are:
1. Improperly loaded motorcycle. Non standard equipment on the front end such asheavy radio receivers, extra lightning equipment or luggage tends to cause unstable handling.
2. Incorrect air suspension pressure.
3. Damaged tire(s) or improper front-rear tire combination
4. Irregular or peaked front tire tread wear.
5. Incorrect tire pressure.
6. Shock absorber not functioning normally.
7. Loose wheel axle nuts.
8. Excessive wheel hub bearing play.
9. Improper vehicle alignment.
10.Steering head bearings improperly adjusted.
11. Tire and wheel unbalanced.
12. Rims and tires out of round or eccentric with hub.
13. Rims and tires out-of-true sideways.
14. Shock absorber improperly adjusted.
15. Worn engine stabilizer links.
16. Damaged rear engine isolation mounts.
17. Swing arm pivot shaft nut improperly tightened or assembled.
Good luck and have nice day
Jun 03, 2012 | Harley Davidson FXDWGI Dyna Wide Glide...
External hard drive (fujitsu), 120 GB, SATA, when plugged to my laptop, laptop is getting slow. please assist. thanks in advance.
any extra hardware added to your computer will slow it down you may close some programs that are running all the time or uninstall ones you dont want/use
good luck
Aug 25, 2010 | Fujitsu MHV2120AH 120 GB Hard Drive
VCR take up reel suddenly does not turn (play, record, forward).
that is a common failure with VCRs.. you will see a rubber wheel that shifts between the two reels .. the rubber tire on that wheel becomes hard, contaminated or oxidised ... replacing the wheel is the best fix but you can try cleaning it .. dont use alcohol because that can remove the elastomers in the rubber ... you can use just water and a lintless cloth, or special cleaner for "idler wheels" .. you can also clean up the surface of the wheel with a common eraser .. if the rubber has become hard with age then the cleaning fix will only last a few months .. new idler wheels are avalible for popular brands but often not for others .. while you are cleaning the rubber idler, also clean the driven areas where they touch .on the take up and rewind spindles .. for really bad rubber idlers that cant be replaced .. there is a special high friction compound that can be applied .. unfortunatly this seems to only lasts a few months and then must be reapplied .. . if the rubber is soft and in good shape then usually just cleaning does the trick ...
Dec 07, 2009 | Dishwashers
My pc is very slow running.
A lot of the time.. well more like 99% of the time, if a virus has infected your computer, your installed virus protection program will no be able to detect it. So what to do?
-Disable your "system restore" first. 95% of viruses live in your system restore. If a you don't, than the next part will be a waste of time.
-Go to http://housecall.trendmicro.com/ . Run the scan....
good luck!
Jan 30, 2009 | EliteGroup P4M800PRO-M Motherboard
Power steering
Try filling the P/S pump resevour and slightly turning the steering wheel side to side just enough to activate the P/S pump. Remove the return line from the pump and keep turning the wheel until you have a really good flow out. Be sure to keep adding P/S fluid while you're doing this. If it's still hard to steer, the pump bearings are now bad. Time to replace it.
Aug 03, 2008 | 1998 Plymouth Breeze
Rio forge 512mb problem.
When this happens to me (it does every few months), I re-flash the software following the instructions that come with it. Then the annoying "upgrader" message goes away for another few month. I use version 1.33 in my 512 forge.
Oct 31, 2007 | Rio Forge Sport Digital Media Player
Please help
hi Ruthie, dont get tense,there are so many data recovery software available on net, just download it and recover your sister's wedding photo. but i think you did not format your memory card regularly,that's why it happened. so dont forget to format regularly after recover your photos. good luck...
Jul 30, 2006 | Nikon Coolpix 4200 Digital Camera
SanDisk Sansa View 8GB MP3 Player - Black Logo
108 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
