Question about Hotpoint Washing Machines
How do I split the outer drum on a hotpoint wml540?
    President:
  • 670 Answers
The drum is a plastic welded type, and can not be taken apart. You need to replace the entire tub assembly. Sorry.
Posted on Aug 23, 2010
Hotpoint WMF760 fills but won't wash
http://www.how-to-repair.com/help/faqs/hotpoint-wml540-washing-machine-that-wont-start/
Aug 30, 2016 | Hotpoint Washing Machines
Hotpoint wml540 - I want to replace the drum bearing
Jim,
I have checked a couple different websites and apparently, there should be more to your model number than what you have in your question. Without the full model number, we cannot find the correct information to help you.
Jun 24, 2015 | Hotpoint Washing Machines
Does the outer drum on a hotpoint WT540
All outer tubs on most Washing Machines these days are sealed.
Therefore you cannot split the tub to get inside and change the bearings. instead you have to change the whole tub assembly as a complete unit. Not an easy job.
Oct 27, 2014 | Hotpoint Washing Machines
Instructions hotpoint wml540
Check belt hasn't snapped/ come off,,,then check motor action,,,,put on spin and tap motor gently see if it helps
Jun 16, 2013 | Washing Machines
I need to know how to remove the bearing from the drum. I have split the outer drum but can't get the shaft out of the back of the outer drum? My washing machine is a Hotpoint WT 960
this just takes a bit of mucle and time.
remove rear pulley and then refit screw (without washer) into shaft. screw the whole way in. then using a lump hammer knock shaft out. may take a good bit of hammerin.
knock bearing out then and also unclog the weep hole in bearing housing.
grease the bearing housing and press in new bearing and seal.
if old shaft damaged ( which prob is if hard to knock out) you will need to replace it.
screws holding shaft to drum usually impossible to undo so drill them out using a 8mm bullet bit.
fit new shaft, put some bearing grease on the bearing seal and re-assemble the drum
Oct 19, 2010 | Hotpoint Washing Machines
How to split the outer plastic drum on hotpoint washi theres something stuck between the outer and rotating drum
Unless you can see actual screws securing the 2 drum halves together, then it is not possible to seperate the drum.
More recent models have a one piece moulding which makes it impossible to seperate.
If it has screws, then the whole intrior of washer has to be removed complete, a difficult job, unless you know what you are doing.
Best way to tackle the problem, is to remove the lower rear panel of washer , remove large black hose on bottom of drum, and have feel around from the bottom of drum, and see if you can locate the item that way.
Hope this helps with your problem.
Jan 17, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wma64, How to get drum out of its caseing ---unscrew?? knock out with hammer? thanks to anyone who cane help.
you need to remove the tank assembly from the cabinet,you will then find approx 15 torx headed screws around the middle of the tank assembly,removed these and the outer tank will then split into two halfs,remove the pully motor and belt,then knock out the drum with a copper mallet.
Jul 05, 2009 | Hotpoint WMA64 Front Load Washer
Hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Jun 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
392 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
